Yamaha RX-479 PSU exploded
  • Satdude
    • Aug 2020
    • 19
    • Czech Republic
    Hi, I have a Yamaha RX-497 receiver, and one day I came home to a burnt smell and the breaker was tripped. Upon opening the receiver, I saw extreme damage to the main power board. C254 was exploded, R261 was burnt, D255 was shorted, Q254 is open circuit, D261 (bridge rectifier) is also open, traces to IC252 (TC4013BP) are vaporized right off the board. Not sure about any other damage, I'll have to desolder the flip flop to test it. Also the transformer T251 is getting hot when plugged in. What could have caused such extreme damage just sitting plugged in? Only repair that was done in the past was a replacement of C254 when the receiver didn't power on anymore. I can of course replace all of the components mentioned, but I don't want to have the PSU blow up again. Can this fault also take the main board with it? If there are any experts in these Yamaha receivers please let me know. I attached some pictures and a schematic of the two boards that are interconnected.
  • petehall347
    • Jan 2015
    • 4429
    i might be checking ac and dc voltages at t251 .
    • Satdude
      • Aug 2020
      • 19
      • Czech Republic
      So after replacing the MOSFET Q254 K3850 with a 2761i, C254 with a .22 WIMA Capacitor, IC252 TC4013 with a Tesla MHF4013 CMOS D-FlipFlop, D261 SN1B60 recitfier, D255 with a 10V zener (2x 5.1V) and repairing the burn traces, the amp came back to life. We found out the board touched the metal casing, so I put some electrical tape there to stop it shorting in the fu ture.
        • 31139
        why the hell does it have a mosfet that shorts the bridge rectifier output?
        • redwire
          • Dec 2010
          • 3912
          It's a triac Yamaha has made using the mosfet+bridge rectifier, like an SSR. But this takes much less current overall to turn on, compared to a triac. The section is powered by a capacitive dropper C254.
          Any power surge, mains transient, lightning, electric utility wiring cross-connect etc. would kill the circuit as in the pictures. There should be other electronics damaged in the house as well, which can prove it.
          You need MOV's or gas tubes for surge protection.
            master hoarder
            • May 2008
            • 12175
            That sounds like a clever and a silly circuit at the same time.
            In any case, I would suggest OP to use an X2 -rated cap for that position, given that the capacitance is rather small. While X2-class caps won't necessarily always go open-circuit in the case of a surge / over-voltage, they are usually a little more tolerant of abuse / line voltage spikes. So using one as a capacitative dropper might yield better reliability.
            • redwire
              • Dec 2010
              • 3912
              It's only 22nF, a very low power circuit.
              In many Yamahas that mosfet or dropper cap frequently fails. 2SK3850 rated only 600V, C254 630V - in something blocking mains. I think they needed an MOV to cover mains surges but then you'd need a fuse too, that would break the piggy bank lol.
              The circuit is clever and hard to troubleshoot - they have power-on reset off, zero-cross switching, undervolt detect IC251, overvolt detect IC253 with the 10V VSB.
              But a say 1,000V spike will kill it all like OP has shown.
              • Satdude
                • Aug 2020
                • 19
                • Czech Republic
                I think the damage happened after the metal case somehow touched one of the pins of the chip, because there is a darker spot on the case and one of the legs was completely gone. The amp was fine for 2 years but was recently moved and now did this. I added some electrical tape to the case to prevent it shorting in the Future.
                • redwire
                  • Dec 2010
                  • 3912
                  I think that is from smoke and soot, blast damage going on the case. I'm not sure if the case is grounded, it can be through HDMI to the TV etc. - oddball paths. But you could be right.
                  I would consider adding a surge-protector power-strip maybe. Not sure how good power quality at your place.
                  • sanalelevenstar
                    Yamaha RX-V485 receiver. After encountering a "version error"
                    by sanalelevenstar
                    I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                    After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                    I managed to find the service...
                    09-10-2025, 01:54 AM
                  • Pete D
                    Yamaha HTR-5460 Receiver protection code info.
                    by Pete D
                    Hi Guys, My first time on the forum.
                    I have a Yamaha HTR-5460 Receiver that I have used for a few years. It has recently developed a problem of giving a pop in the speakers and then shutting down. This is intermittent and might happen after an hour or a couple of days of playing.
                    I have put it into Diagnostic Mode and it comes up with code “PS PRT 020 B”. According to the service manual “PS PRT” signifies a power supply problem in the mains transformer, 5V or 12V DC supplies. I'm assuming that the “020 B” part of the code would define which one of these...
                    11-03-2023, 07:00 AM
                    Acer Aspire Aspire One D255 Netbook One Specification for Upgrade or Repair
                    This specification for the Acer Aspire Aspire One D255 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One D255 boardview and Aspire One D255 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-06-2024, 05:27 AM
                  • alfredomfr1
                    YAMAHA AV Receiver RX-V585 No Power
                    by alfredomfr1
                    120v ok, No voltage on the connectors, Fuses OK, 165v DC on the main capacitor...
                    09-12-2023, 09:47 AM
                  • CDNBrewer
                    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                    by CDNBrewer
                    Hello Everyone,
                    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                    Symptoms:
                    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                    • I swapped the Left and Right surround
                    08-05-2025, 09:29 PM
