Fake nichicon PJ series?
  • jm20101
    • Sep 2012
    • 51
    • Netherlands
    I bought these caps (20pcs) a few weeks ago from eBay for just $2.
    The seller said they are good quality, but I don't think that I have genuine capacitors for this price....
    Can someone tell my the date of the manufacturing, and if these capacitors are fake?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Fake nichicon PJ series?
    Show us the bungs
    • jm20101
      • Sep 2012
      • 51
      • Netherlands
      When I take a look at the bungs, I realized that they have 2 sorts of bungs.
      The most are flat, but some have a circle on it.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        fake...
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Fake. The font gives them away too.
          A working TV? How boring!
          • jm20101
            • Sep 2012
            • 51
            • Netherlands
            I thought so... but now it's definitely that they are fake.
            I gave the seller too fast a positive feedback.
            Thanks for the help.
            • Rob Northen
              • Jan 2010
              • 137
              • Denmark
              I'am SO shocked they are fake. You must be shocked too
              • Clutchbox
                Cap Clutcher
                • Sep 2011
                • 41
                • The Netherlands
                @ jm20101:
                They are fakes, why do you buy from ebay?
                Youre from Holland, you can buy genuine Panasonic FC & FR low-esr caps on the Conrad website. They are cheaper there than Farnell or Mouser.
                Panasonic FC 2200uF 16v (Ø x h) 12.5 mm x 25 mm (Low ESR)
                Panasonic FR 2200uF 16v (Ø x h) 12.5 mm x 20 mm (Lower ESR than FC, longer life)
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  fake in size alone.look like 10x16mm.
                  no 2200@16 by ANY mfr in that size.
                  • jm20101
                    • Sep 2012
                    • 51
                    • Netherlands
                    Originally posted by Clutchbox
                    @ jm20101:
                    I just bought from eBay because the price, but later when I take a look at this forum (and bought a capacitance meter) I see that I can better buy genuine caps.
                    Maybe I can use this capacitors in cheap ass power supplies, just to replace the worser capacitors.
                    I also bought (in the past) some fake Sanyo's, the sleeve said 4700uF but they are just 3300uF.
                    I installed this capacitor in a PSU, and it works for just a few minutes.
                    The second time I turned it on there come a big bang, and the PSU was dead... Luckily the motherboard was good.
                    And I never going to buy fake caps from eBay anymore.
                    • Rulycat
                      • Apr 2010
                      • 724
                      • United Kingdom
                      That fake "Sanyo" is a Teapo. Strange that it blew up the PSU - I bet they lied about the series as well.
                      • japlytic
                        • Oct 2005
                        • 2086
                        As far as I know, Nichicon PJ Series have a brown sleeve.
                        • jm20101
                          • Sep 2012
                          • 51
                          • Netherlands
                          Thats true, the datasheet says 'Printed with white color letter on dark brown sleeve'
                          • DrewPhillips
                            Capacitor Diarrhea - Nichicon PL Series
                            by DrewPhillips
                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                            03-02-2025, 10:18 PM
                          • chth96
                            Is there datasheet for nichicon LXJ series?
                            by chth96
                            I want to calculate capacitor ESR referring to below guide.
                            https://forum.digikey.com/t/calculat...-from-tan/2633
                            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                            11-20-2022, 08:11 AM
                          • chth96
                            Is there any datasheet for nichicon RT(M) series?
                            by chth96
                            A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                            https://www.badcaps.net/forum/troubl...e-been-blew-up
                            and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                            But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                            I have spare console...
                            11-28-2023, 03:36 AM
                            ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 03:28 PM
                            ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
