Bad Soundia Caps?
  • jamesm113
    • Aug 2012
    • 9
    Bad Soundia Caps?
    From an audiosource subwoofer built in 1999. Subwoofer is hums with no RCA line connected to it or when the receiver is off.
    Is that stuff glue or busted caps?
    Thanks!
  • selldoor
    Slow Learner
    • 7870
    Re: Bad Soundia Caps?
    Bad caps
    • Rulycat
      • Apr 2010
      • 724
      • United Kingdom
      Looks related to Anodia caps..
      • mariushm
        • May 2011
        • 3799
        Looks like they're right after the bridge rectifier, maybe used to create a split power supply.
        It's possible there's quite some ripple from the transformer coming into the caps - replace them with a good brand capacitors (panasonic, nippon chemi con, nichicon) and consider replacing them with 35v rated ones, those will handle larger ripple better..
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          that your hum right there.replace all of them.
          • jamesm113
            • Aug 2012
            • 9
            I replaced those 2 with 470uF 35V RadioShack ones (only ones i could get on short notice)
            Hum is definitely improved, but still present. The other caps didn't look to have any issues
            • selldoor
              Slow Learner
              • 7870
              If your not going to follow the advice given, there is little point in our trying to help?
              • jamesm113
                • Aug 2012
                • 9
                I'm sorry, the only advice I saw last night before I replaced them was "Bad caps" so I replaced them.
                Is the RadioShack brand bad? Should I replace the rest of the caps on the PCB even though they don't have signs of failure?
                I've attached the schematic. I *think* I replaced C7 and C18
                • mariushm
                  • May 2011
                  • 3799
                  You mean c17 and c18 .. it's the two by the bridge rectifier D1.
                  Radioshack buys general purpose capacitors from various companies and rebrands them.
                  They're generally not suited for use in locations that are subjected to excess heat or ripple, or if they need to be low esr.
                  It may work now, but they may go bad sooner or later.
                  If you're going to buy a proper set, I recommend also changing the capacitors after the linear regulators , C15 and C16 ... both 100uF 16v. Replace them with 100uF 25v, preferrably Panasonic FC, FM, FR, Nichicon HM, Nippon Chemi Con KZE
                  The reason is mostly because those two ICs U5 and U6 are linear regulators, which means they take 14-16v and output stable +12v and -12v but the difference is dissipated as heat into the area around.
                  If those 100uF 16v are near the linear regulators, they would be constantly under heat from those ICs. Going to 25v is not required, as the capacitors will only see 12v on them, but usually capacitors rated for 25v are just a bit larger and more resistant to heat. From the pictures, it looks like you can fit slightly larger capacitors.
                  Check the badcaps online store, should find both these capacitor values+voltage ratings or use digikey.com / newark.com etc
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    I don't know about yours but my local Radio Shack only has Lelon caps on hand, which are trash, so if they are those I'd buy some better ones like already suggested.
                    • jamesm113
                      • Aug 2012
                      • 9
                      Sorry for the delay, got a little sidetracked.
                      Anyway, I replaced C15 and C16 with 100uF 25V. Hum is still the same
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4958
                        • New Zealand
                        They can go bad without visible symptoms.
                        What about C12 and C13 too? They look related to the power supply..
                        -David VanHorn
                        • jamesm113
                          • Aug 2012
                          • 9
                          Ok, I can try replacing those. Any others?
                          • mariushm
                            • May 2011
                            • 3799
                            Check the ones that are close to the speaker output connectors - follow the leads from the connectors towards the insides and check those for capacity and resistance (if you don't have an esr meter)
                            Just on a rough and fast look I see there C8, c11, c14, c24... might as well replace c6 though it should cause issues...
                            I see mainly 4.7 uF 16v, 100uF 16v and 100uF 35v - you can replace all 100uF with 100uF 35v or 50v (if you get a better price for getting a 5 pack or 10 pack, you know what i mean), and it wouldn't hurt replacing the 4.7uF ones with higher voltage rating caps.
                            They're all small in capacity and cheap, all shouldn't be more than 3$ or so at digikey but for this one you can probably use the cheap radioshack capacitors if you don't want to spend a lot.
                            Without an ESR meter it's hard to pinpoint exact issues, or something to measure if the capacitors leak, letting DC go through to the speakers.
                            • lti
                              • May 2011
                              • 2548
                              Radio Shack charges $1.49 for a 100uF cap.
                              • mariushm
                                • May 2011
                                • 3799
                                Ouch! Wasn't aware of that.
                                I actually ordered today (among other stuff) 50 pcs x panasonic fm 100uf/25v from Farnell for 39.7 RON ... 11.5 dollars.
                                I don't know, probably the guy who invented Radioshack is rolling in his grave...
                                • jamesm113
                                  • Aug 2012
                                  • 9
                                  These were the caps immediately next to the speaker leads (the red and black wires). Just ordered replacements for them + all those suggested above
                                  • jamesm113
                                    • Aug 2012
                                    • 9
                                    Well I replaced all the caps suggested and the two big ones pictured, and there is no improvement
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Is it possible that you have a ground loop somewhere?
                                      Is it buzzing with NO input wires connected?
                                      Have you checked the rectifier diodes to see if they could be leaky?
                                      Muh-soggy-knee
                                      • jamesm113
                                        • Aug 2012
                                        • 9
                                        It's humming if the sub is the only thing plugged into the wall - no input wires connected at all
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
