Help Identify
  • Himay
    • Jul 2012
    • 5
    Help Identify
    I know nothing about this stuff but i do know that the picture of this resistor/capacitor is the problem. This is off a digital speedometer display for a custom chopper. I have had no one to this point in any of my local electronic stores able to find out what this is or a replacement for it. Please help
  • selldoor
    Slow Learner
    • 7870
    Re: Help Identify
    Hi - I believe it is one of these
    RXEF017 60V 0.17A DIP-2 X60 XF017 Polyswitch, Resettable Fuse, PPTC
    http://www.digikey.com/product-detai...017-ND/1045822
    I am surprised that if you dont know what it is, you know that it is faulty?
    How did you test it?
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Help Identify
      Maybe from the crack on the right leg?
      --- begin sig file ---
      --- end sig file ---
      • Himay
        • Jul 2012
        • 5
        Re: Help Identify
        Thanks for your help! I know its faulty because the guy at one of the electronic shops tested it somehow and told me it wasn't working but he was unable to find a replacement part as he couldn't figure out exactly what it was. And yes that made me skeptical...sorry about the way i posted those pictures.
        • Himay
          • Jul 2012
          • 5
          Re: Help Identify
          Would you mind telling me what this part does? Basically I have a board that sometimes comes on then goes off immediately. Im hoping this part fixes the problem.
          • retiredcaps
            • Apr 2010
            • 9271
            Re: Help Identify
            See
            http://en.wikipedia.org/wiki/Resettable_fuse
            • thesame
              DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
              by thesame
              Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
              The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
              02-27-2024, 04:31 AM
            • silver60618
              Lenovo Legion 7 - Help Identify IC
              by silver60618
              Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
              I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
              Any help would be appreciated...
              07-02-2025, 12:16 PM
            • ranchhandbumper
              1992 Toyota Truck Speedometer
              by ranchhandbumper
              I am working on a 1992 Toyota pickup that has an electric speedometer. It is an analog needle speedometer and is driven by electricity.There is no cable. The transmission has a reed switch that sends a 12 volt pulse to the speedo 4 times per tire rotation.
              According to GPS, the speedo is showing speed progressively slower below 50mph and progressively faster above 50mph. This also affects the odometer.
              I've included a photo of the findings. The "control" is information I found on the net that correlates expected MPH based on a given hertz.
              I removed...
              11-12-2022, 08:12 PM
            • chth96
              How can I identify varistor which have been blew up?
              by chth96
              I mistakely pluged 100v japanese retro game console to 220v outlet.
              So It seems that glass fuse and varistor have been blew up.
              I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
              Is there any way to identify varistor type in my sega saturn PSU?
              Any reply would be appreciated.
              EDIT:
              It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
              11-26-2023, 08:52 AM
            • freakorio
              Need Help To Identify Component on Ymain LJ41-05120A
              by freakorio
              Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
              05-21-2024, 02:32 AM
