Computer Grade capacitor testing
  • microfarads
    • Feb 2012
    Hi --- I have hundreds of large, high capacitance computer grade caps -- what equipment do i need to do basic tests to see if they are in good working order?
    Thank you!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Computer Grade capacitor testing
    ESR meter. it puts a 100Khz signal into the cap and reads the impedance
    • microfarads
      • Feb 2012
      Thank you uranium - much appreciated
      so by using an ESR meter and applying the 10khz signal into the cap -- it'll tell me if the capacitance of the cap?
      sorry, i'm trying to learn ---
      • mariushm
        • May 2011
        • 3799
        The capacity can be told by a regular multimeter and it's generally pointless to measure it, as capacitors are from the factory rated for +/-20% their capacity value and also the capacity will vary a bit depending how they're used.
        To put it simply, a capacitor will have a certain capacity value when tested with the multimeter, and a different value when on a motherboard or a power supply.
        The ESR value can only be "measured" by an esr meter. And it's 100 kHz frequency... the esr meter will apply a 100kHz frequency something into the capacitor and measure how the capacitor reacts to that.
        The value is not a Good or Bad result... the value will depend on the series of a capacitor and its purpose.
        On general purpose capacitors, it's normal for the value to be a bit higher, on capacitors usually used in power supply, motherboards etc the capacitor series used on those usually have a very low esr value.
        The value also varies with the capacity and the size (diameter and height) of the capacitor.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          you may need to reform them to get the leakage in spec to test.
          otherwise measure esr and compare to specs.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Moved out of FAQ.
            sigpic
            (Insert witty quote here)
            • Agent24
              I see dead caps
              • Oct 2007
              • 5038
              • New Zealand
              Ultimately you should test their ESR, Capacitance and Leakage current to ensure all are within specification. You can find out what these should be in the datasheets.
              But high leakage is more likely in NOS (New Old Stock) and ESR problems are from ones that are just plain crap.
              -David VanHorn
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • genuineguy
                Microwave Oven Capacitor Testing
                by genuineguy
                Hello Experts
                Need help with my experiment to test a Capacitor from microwave oven
                Its a High voltage capacitor. 1mfd, 2100V AC.
                A DMM test across its terminals show infinite/open resistance.
                The capacitor has a 10Mohms shunt resistor internally.
                1. Connected 100w bulb in series to the capacitor. AC supply 230v connected. The bulb did not light up. This proves the capacitor is NOT shorted
                2. Connected capacitor in series with a diode and 10ohm, 10W resistor. Connected AC supply 230v. I was hoping DC voltage reading...
                09-21-2020, 12:56 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • Sparklingx
                SMD ceramic capacitor capacitance & voltage
                by Sparklingx
                what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
                09-12-2024, 01:04 AM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
