Microwave Oven Capacitor Testing
  • genuineguy
    • Sep 2015
    • 46
    • india
    Hello Experts
    Need help with my experiment to test a Capacitor from microwave oven
    Its a High voltage capacitor. 1mfd, 2100V AC.
    A DMM test across its terminals show infinite/open resistance.
    The capacitor has a 10Mohms shunt resistor internally.
    1. Connected 100w bulb in series to the capacitor. AC supply 230v connected. The bulb did not light up. This proves the capacitor is NOT shorted
    2. Connected capacitor in series with a diode and 10ohm, 10W resistor. Connected AC supply 230v. I was hoping DC voltage reading of 300+ volts across the capacitor, because the capacitor will charge to peak of 230v rms and hold it there... However, DMM shows 100V DC.
    Any corrections to my experiment #2 ? Is the capacitor leaking ?
  • bestsystem
    • May 2011
    • 59
    Re: Microwave Oven Capacitor Testing
    1. May be shorted with higher resistance so the bulb cannot noticeably light up
    2. Calibrate your dmm or get an extra one to cross check
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      In experiment #2, what if you tried a known good capacitor or what if there's no capacitor there at all, what is the voltage? Just want to also rule out a weak diode...
      The reactance of a 1uF capacitor at your line frequency is a bit over 3K ohms. I'd expect a good capacitor to dimly light up a 100W@230V lamp with a 230VAC source in series. You really need a DC voltage to truly test leakage.
      Right now given the information seen here that capacitor is questionable but need to confirm your testing apparatus first.
      • genuineguy
        • Sep 2015
        • 46
        • india
        I connected the diode in series with the 100w bulb. The bulb did light up, it was flickering and somewhat half the brightness than a normal 230v connection. I recognise this light as I have connected diodes in the past to 100w bulb. so i am concluding the diode is good.
        I also used a 12V battery to connect to the diode and test using DMM. The forward reverse test did succeed.
        So , the diode appears good to me.
        I am doing this experiment to confirm my capacitor is good or bad. I do not have a new capacitor. Looks like I have to go buy a new one.
        • genuineguy
          • Sep 2015
          • 46
          • india
          Turns out the capacitor was indeed faulty. I got a new one and the microwave oven is working. I had to replace the magnetron too. Hopefully this sustains and does not fail again.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            Magnetrons and traveling wave tubes are vacuum tube and have a finite life due to the heater, which is necessary for operation. They also have a high operating voltage, often several thousand volts (the TWTs I worked with at a previous employer had a cathode voltage around -4 KV).
            PeteS in CA
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • valvashon
              Toshiba EM131A5C-BS microwave oven- noisy EE16 2.7 mH inductor
              by valvashon
              This poor microwave oven was purchased by my former employer in 2019 (it's a 7/2018 build) and lasted for about 3 months before making a terrible noise when in use. I determined that it was the main transformer and contacted Toshiba. They asked for a picture of the cord cut in half and the serial number, and then credited my boss' credit card. Rather than sending it to the e-waste, I bought a transformer on eBay and thought I'd try flipping it. Discovered that used microwave ovens aren't worth much but in for a penny, in for a pound as they say. It sat in my basement getting kicked and shoved...
              02-20-2024, 10:38 AM
            • goodpsusearch
              Daewoo microwave oven repair
              by goodpsusearch
              One day my microwave oven stopped heating.
              It would turn on and rotate the plate but no heat.
              I removed the cover and checked components with digital multimeter.
              Found that the high voltage fuse was blown.
              This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
              Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
              I replaced fuse and tried to heat up a glass of water.
              Strange noise...
              01-24-2021, 03:56 PM
            • tmhobadcap
              Can a microwave oven be used to reflow solder joint?
              by tmhobadcap
              I heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
              Is that possible? I do not want to try this unless I have a spare microwave oven.
              (I do not mean to suggest somebody to try this. It may be...
              10-30-2020, 08:38 PM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
