Nichicon HM's or Rubycon ZLH's
  • trowakage
    • May 2007
    • 6
    Hey everyone:
    I am planning to recap my Shuttle FG31 motherboard (picture) that has recently start to bulge. I picked up a bunch of Nichicon HN's from Newark and for the 8x 1000uf 6.3/10v 8mm cap listed on the replacement kit here I picked up some Rubycon ZLH's because they were in stock for that size and spec.
    I checked the ZLH's specs just now and found that it had almost twice the ESR as the HM's which have now come in stock (still not HN stock).
    Should I order the HM's or stick with the ZLH's? Any advice would be much appreciated.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Nichicon HM's or Rubycon ZLH's
    The ESR of a ZLH would be a bit high for motherboard use IMO. HN or HM would be fine.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • trowakage
      • May 2007
      • 6
      Thanks! I'll go ahead and order the HM's then.
      • trowakage
        • May 2007
        • 6
        Upon further inspection, the original OST RLP's on the board have specs that are already worse than the ZLH's
        RLP, 0.11ohm,730mA
        ZLH, 0.045ohm, 1250mA
        HM, 0.018ohm, 1870mA.
        So it would seem that the ZLH's should be fine to use (unless the board designers totally spec'd the board wrong). Going to try to use a few of the ZLH's before my HM's come in and see if there are any issues. Wish me luck!
        • c_hegge
          • Sep 2009
          • 5219
          If the ZLHs are better than the original caps, they will be fine.
          • trowakage
            • May 2007
            • 6
            Recapped the whole board over the weekend with the HN's for the OST RLX's and ZLH's for the RLP's. Board is working great and holding an overclocking on my E7200 as well. Thanks for all your help everyone!
            • withalligators
              Looking for best replacements for Capxons, but can't find data sheets
              by withalligators
              Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
              1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
              1 x Capxon 1000uf35v...
              03-25-2022, 02:30 PM
              by momaka
              03-15-2023, 10:17 PM
            • DrewPhillips
              Capacitor Diarrhea - Nichicon PL Series
              by DrewPhillips
              Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
              The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
              03-02-2025, 10:18 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • burom
              Xbox 360 Xenon Modern Capacitor Replacements
              by burom
              I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
              I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
              06-07-2024, 05:10 PM
