Typical Tolerance in Capacitors
  • Amarbir[CDRLABS]
    • May 2012
    • 11
    • India
    Guys ,
    i have a large junkyard of these and i plan to sort them out now .Could you please tell me the typical +- tolerance levels of caps .I am doing my maths for 20% .If this ok or there could be more then this also .
  • mariushm
    • May 2011
    • 3799
    Re: Typical Tolerance in Capacitors
    Capacitance value is pointless. You need an ESR meter to determine if the capacitors are worth keeping or not.
    Electrolytics usually have 20% tolerance, some old axial capacitors are -20% - +40%, some are worse.
    • Amarbir[CDRLABS]
      • May 2012
      • 11
      • India
      Sir ,
      Well i am typically doing the following
      1 : discharging capacitor ,checking on analogue meter for short or open in resistance range
      2: discharging it again and testing capacitance using a digital multimeter
      3 : discharging again and checking esr with esr meter .
      while doing some of these today i noticed that i have a handful of capacitors in the 330 micro farad range ( different voltage rating ) that have value like 200 micro farad to 230 micro farad .Short/Open/ESr Is Fine .My ESr Meter Measurements are as typically this
      1 : 330 micro farad 200 volts .07 esr
      2 : 330 micro farad 250 volts .06 esr
      3 : 330 microfarad 400 volts .08 esr
      4 : 330 microfarad 450 volts 0.9 esr
      my point is that if the caps are having 200 to 230 value can i use them or shall i throw them .
      • c_hegge
        • Sep 2009
        • 5219
        Anything within 20% of the original value is fine. However, 230uF is off by just over 30%, so those are bad and should just be used as firecrackers.
        • Amarbir[CDRLABS]
          • May 2012
          • 11
          • India
          Hi ,
          While Testing 220 Microfarad I Am Getting ESR Of 2.5 in some cases .ESR should be 0.2 to 0.5 approx .My question is can i still use these caps in some projects in capacity and short/open circuit testing is ok
          • c_hegge
            • Sep 2009
            • 5219
            ESR should be more like 0.02 or 0.05. Any higher than that and the cap is bad, so toss it a fire and watch it go pop.
            • dragon3x
              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
              by dragon3x
              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
              power on.
              Here are some examples :
              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
              switching supply area).
              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
              than 6.3 V.)
              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
              I replaced capacitors with aluminum-polymer.
              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
              03-21-2025, 02:46 PM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
              by sam_sam_sam
              After all of...
              07-13-2024, 08:14 PM
            • Cama
              Solar Inverter - SMH-II - 2 missing capacitors
              by Cama
              I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
              My model is : EASUN SMH-II 7 KW
              Mother Board : P/N 18947-002401250250
              Maybe the EASUN SMH-II 4.2 KW have the same capacitors
              Thank you...
              09-12-2025, 02:50 AM
            • Taurus12
              Optiplex 3050 micro 2 blinks followed by 3 blinks issue
              by Taurus12
              Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
              I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
              i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
              Any recommendation on what I have to do next? Thanks in advance
              06-10-2025, 05:05 PM
