Typical Tolerance in Capacitors
  • Amarbir[CDRLABS]
    • May 2012
    • 11
    • India
    Guys ,
    i have a large junkyard of these and i plan to sort them out now .Could you please tell me the typical +- tolerance levels of caps .I am doing my maths for 20% .If this ok or there could be more then this also .
  • mariushm
    • May 2011
    • 3799
    Re: Typical Tolerance in Capacitors
    Capacitance value is pointless. You need an ESR meter to determine if the capacitors are worth keeping or not.
    Electrolytics usually have 20% tolerance, some old axial capacitors are -20% - +40%, some are worse.
    • Amarbir[CDRLABS]
      • May 2012
      • 11
      • India
      Sir ,
      Well i am typically doing the following
      1 : discharging capacitor ,checking on analogue meter for short or open in resistance range
      2: discharging it again and testing capacitance using a digital multimeter
      3 : discharging again and checking esr with esr meter .
      while doing some of these today i noticed that i have a handful of capacitors in the 330 micro farad range ( different voltage rating ) that have value like 200 micro farad to 230 micro farad .Short/Open/ESr Is Fine .My ESr Meter Measurements are as typically this
      1 : 330 micro farad 200 volts .07 esr
      2 : 330 micro farad 250 volts .06 esr
      3 : 330 microfarad 400 volts .08 esr
      4 : 330 microfarad 450 volts 0.9 esr
      my point is that if the caps are having 200 to 230 value can i use them or shall i throw them .
      • c_hegge
        • Sep 2009
        • 5219
        Anything within 20% of the original value is fine. However, 230uF is off by just over 30%, so those are bad and should just be used as firecrackers.
        • Amarbir[CDRLABS]
          • May 2012
          • 11
          • India
          Hi ,
          While Testing 220 Microfarad I Am Getting ESR Of 2.5 in some cases .ESR should be 0.2 to 0.5 approx .My question is can i still use these caps in some projects in capacity and short/open circuit testing is ok
          • c_hegge
            • Sep 2009
            • 5219
            ESR should be more like 0.02 or 0.05. Any higher than that and the cap is bad, so toss it a fire and watch it go pop.
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
              After all of...
              07-13-2024, 08:14 PM
            • Taurus12
              Optiplex 3050 micro 2 blinks followed by 3 blinks issue
              by Taurus12
              Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
              I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
              i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
              Any recommendation on what I have to do next? Thanks in advance
              06-10-2025, 05:05 PM
            • Ady2017
              Are there any datasheets available for Elna RJG capacitors?
              by Ady2017
              I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
              05-25-2025, 02:19 PM
