Re: Teapo capacitor quality
there is no dust in a machine designed for 24/7 use.
you presurise the case with more fans pushing in than sucking out and fit filters on them.
i have lost track of the number of dead machines i'v fixed because they didnt use filters & the cpu heatsink got clogged-up.
I have been looking at quite a few FSP units (SPI "ATX-350-PN") from systems that are a few years old... They use all Teapo caps, some low-ESR "SC" series and some general purpose... So far, they all exhibit the same two bloated +5VSB Teapo "SC" caps (Which is probably because of overstressing, not lack of quality). None of the other Teapos are ever bloated (I re-cap them all anyways), and I would be very curious to check them if they are indeed in spec...
So I suspect that Teapo are generally OK in PSUs... I've even seen Compaq P4 towers that have Teapos scattered throughout, they seem to do ok as long as they're not in the VRM, and they don't arbitrarily bloat like KZG/TK/OST caps do.
SZ is similar enough to Nichicon HM to be used on CPU VRMs. I wonder if they were/are a reliable series.Leave a comment:
in hot country's or 24/7 buildsLeave a comment:
in hot country's or 24/7 builds,
you want the psu fan doing what it's designed to do - move a lot of air.
non of that wisper/thermal management shit - it's a psu killer.
take the fan out and hook it to 12v - if it feels like it moves a lot of air - use it.
if not ( most of the cheap 120/140mm fans are junk) then put something better in.
As for Teapo's capacitor quality... I have been among the fortunate and have not seen that many failures from them myself, but given the amount of failures I've read from others, I'd say Teapo capacitors are terrible, like any other 'mediocre' Taiwanese brand. Of course, no 'lytic lasts forever and heat is the ultimate enemy of even Japanese lytics, especially aqueous ones.
EDIT: Momaka observed that Teapo SZ fail very very often on motherboards. I doubt they're reliable by any stretch of the word.Last edited by Wester547; 05-14-2014, 10:07 PM.Leave a comment:
There's no way in the world I would do that. I hate fan noise, and if a PSU needs the fan to be running at maximum speed, then you're doing it wrong. Any decent PSU should be able to last 10+ years of heavy use with the fan staying silentLast edited by c_hegge; 05-14-2014, 08:55 PM.Leave a comment:
antec have ball-bearings and good flow rate if yur buying from a computer place,
or salvage a delta or a papst or some other decent fan from something else!Last edited by stj; 05-14-2014, 08:31 PM.Leave a comment:
With a lot more experience now, I can say that probably 15-20% of the Teapo caps I have encountered that failed, failed without showing any visible symptoms.Leave a comment:
I had good experince with Teapo capacitors I wont say they are excellent but in my friends old computer had teapo caps he had the system running much of the day for 8 or so years before the motherboard chipset went bad, I have the PSU (HIPRO) running in my computer now which is going well... nowdays he has another machine it has a coolermaster unit it is running windows 7 it was one of the last windows 7 stock machines before they went to 8 and i used the rest of his old system for parts. but still those caps just keep on going they could die tomorrow or they could die in 5 years or keep on ticking longer... then again im using it for daily internet and using a old AMD athalon 64 which is well for internet so light load will be fine on the thingLeave a comment:
My old gaming rig that I'm letting my best friend use was having some issues when he tried gaming, It would always freeze when loaded up. It is a MSI TurboStream 600W (Solytech unit), and I opened it up to find 2 dead Teapo's. It has all Teapo as the single Primary cap (has APFC) and Teapo on the secondary. The 2 caps that died are fairly small, unfortunately I can't see the uf and V numbers. But all of the 4700uf, 16V and the primary are fine. The single primary cap is rated at 85C and the rest are rated at 105C...I'll post some pics when I get home. I'm not sure if I'd be able to replace all the caps without taking off the heatsinks...The soldering is sloppy....and there are some what look like brown burn marks around some of the solder but I can't tell if it's from burning up or not...The PCB says Deer 600W Ver:1.2 But anyways this is what it died powering:
Core 2 Duo 3GHz
8GB 1066 RAM (4x2GB)
Single 320GB HDD
BFG GTX 260 Maxcore 55
I bought it used in April, 2011 for $20 and it was insanely dusty when I bought it. I cleaned it out before I put it in this computer. Probably got another 2,000 hours of use out of it so it must have had some heavy use by the previous owner. It has dual 80mm fans so it should have had decent cooling, dust doesn't help though.Last edited by Pentium4; 06-05-2012, 02:08 AM.Leave a comment:
Sanyo and Panny both make reliable caps, so no surprises there. What is a surprise is that Acer would have such good caps in their PCs. I've found Acer to be total junk. Most of the boards I've seen them use had OST, G-Luxon, TK, and Chemi-con KZG caps.Leave a comment:
Haha, I saw that exact same video before I signed in here - it was one of the first results for the model number in Yahoo search!
Good times, first I find Fuhjyyu caps and then come across a blown up version of the PSU I decide to install! Hopefully mine fares slightly better.
The motherboard itself has a mixture of Sanyo and Panasonic/Matsu caps, and not one has bulged in the 6½ years of constant on-time this Acer T310 desktop has had. This PC was an Xmas 2005 present, and has never skipped a beat, even with its original 40GB Seagate drive still in use as C: (it has a larger secondary drive for games and the like, but Windows and non-game programs can have the C: drive all to themselves).
The only thing I've inadvertently blown up was a Pentium 3 system, plugged in the power socket without disconnecting the cable from the wall, and blew the fuse immediately. Instead of repairing it I just scrapped the PSU for its caps (although they were all cheap ones like Viva/CapXon/Su'scon, they still might come in useful just for the odd swap/test).Last edited by Heihachi_73; 06-02-2012, 05:34 PM.Leave a comment:
Thermal masters are "high-end" Sun Pro builds. They are better than the dirt cheap $20 Sun Pros, but still not fantastic. See http://www.youtube.com/watch?v=wOjJOXIJNt4. I load tested one and it exploded when I asked for 100% Load.Leave a comment:
Teapo. I only had to look at this thread the other day (prior to registering), and my PC died an hour ago!
What did I find in its Acer OEM, FSP Group FSP200-60ATV power supply from December 2005? Four bulged Teapos (at least) and a fifth non-bulged one looking like the Leaning Tower of Pisa.
Funnily enough, this PC has been on 24/7 since 2006 and only failed when I had to turn it off to test a PCI SCSI card. Once I hit the power button, it went on for about half a second and went off straight afterwards, the classic "bad cap" symptom. Obviously it just couldn't draw the current to spin the hard drives, fans and power the rest of the PC. After draining the power, it wouldn't even turn on at all.
Luckily, I had a brand new-looking (and new-smelling) 2010 model Thermal Master 420W unit lying around which I picked up for $2. Unfortunately, I can see Fuhjyyu primaries without even opening it, and it also has a -5V rail for some reason, but at least it works for now.Leave a comment:
Yes, but in Thailand (and even Australia), that's easier said than done.Leave a comment:
So I suspect that Teapo are generally OK in PSUs... I've even seen Compaq P4 towers that have Teapos scattered throughout, they seem to do ok as long as they're not in the VRM, and they don't arbitrarily bloat like KZG/TK/OST caps do.Leave a comment:
The GX 450 is a relatively well built unit OEMed by Enhance which is a good manufacture so the odds of catastrophic failure are low. Just keep an eye on those Teapos they may fail allowing excess ripple through. This is also one of the few CoolerMaster PSUs that can actually do its rating(Most CoolerMasters are overrated by 10-20%).Leave a comment:
That's going to put some stress on the PSU. Standard grade PSUs are not really designed for such use especially in temperatures like that. You may want to consider a server grade unit or at least a high end standard unit (SeaSonic, Delta, Antec HCP/HCG, PC Power & Cooling, etc.) or plan on replacing them every 2 or 3 years.Leave a comment:
I'd be surprised if they lasted 3 years.Leave a comment:
by chth96I want to replace samhwa RG 250v 1uf capacitor which has no ESR value and has capacitance less than 280pf.
It is possible to purchase WCAP-ATG5 in local electronic shop.
But I want to know that whether WCAP-ATG5 capacitor has similar or better quality than smahwa capacitor or not.
Is there anyone who has experience to replace any bulge or faulty cap with cap from Wurth Elektronik?
https://www.we-online.com/en/compone...ucts/WCAP-ATG5-
Channel: General Capacitor Questions & Issues
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
I know that these capacitor will not last as long as nichicon capacitor...-
- Loading...
