Re-Cap and No Post
  • MisterGank
    • May 2006
    • 9
    Re-Cap and No Post
    MSI 694D Pro AR Ver 1.0
    Ok, my computer was becoming un-stable... I could burn DVDs and Play Counter-Strike:Source for hours, but when the computer would go idle I got BSODs... Even screen savers would lock the PC up. After seeing that I had 7 blown caps (electrolite fluids coming out) I decided to order a re-build kit. I ran a system back-up onto my file server and took it all apart.
    I only found 19 caps that I could replace with what was available in the kit, the only ones that I didn't replace would be the 16-volt chips, but as I've been reading in the forums those don't seem to fail.
    Once I was done capping I decided to test my solding joints first by using an Ohm meter on the ground and testing the ground of every cap. All have tested ok. I then went the power plug and found the correct pin to ohm out each of the positive lead, and each one has a slight resistance, but showing a working solder joint.
    Time to power up i thought... I put the whole system back together... Plugged power cable in, and I get nothing...
    After 2 days of fussing, testing with an ohm meter I can't get a beep or a blip or even a puff of smoke when connected to the power supply.
    I now only have the power supply connected to the mobo, and both CPUs with heatsinks in with no ram and nothing in any slots... I can't get anything to power up... I've check the mobo with a magnafine glass and a spot light and I can't find any chips that might have been hit with a screw driver or what. I just removed the battery, and was going to try again in an hour or so...
    Does anyone have any suggestions as to what to test next? or a method of powering up?
  • MisterGank
    • May 2006
    • 9
    Re: Re-Cap and No Post
    Oh, and yes, I've tried 3 power supplies... and none of them can get it power up...
    • tiresias
      • Feb 2006
      • 489
      Welcome MisterGank
      First thing you'll want to do is to try to narrow down the problem a little. There's a few things you can investigate to gain some insight into where the problem actually lies - often it can be an easy-to-fix issue which you may have overlooked.
      1. With the PSU attached and powered up, is there a 5Vsb at the ATX connector?
      2. Can you measure any potential between the two pins on the motherboard leading to the system 'on' front panel button?
      3. Short these two pins for a second or so - have the PSU's other output "appeared" at the ATX connector now?
      These are just three extremely simple initial steps, and yet you'd be surprised how often a seemingly "dead" motherboard turns out to be the result of a loose wire leading to the chassis' power button!
      Let us know.
      PS. Have you tried starting up the motherboard outside the chassis? With only CPU's installed but no RAM, cards, or anything else (it should at least beep).
      • Rainbow
        • Aug 2005
        • 1375
        Have you checked board traces for damage? Mainly around the replaced caps but also near CPU sockets.
        • MisterGank
          • May 2006
          • 9
          Right now there is no board trace damage. I tested the 5v and they were not active. Both acted as a ground... I had my father-in-law look over it, he did soldering boards for a job once. He said there were a few bad joints, and he suggested just to re-do them all just to be sure. I'm going to do that tomorrow night. I'll update then and let you know if it posts...
          • MisterGank
            • May 2006
            • 9
            I de-soldered every cap, and re-soldered them all, they are all shiney and look perfect now. I ran through with Ohm meter again, and all check out. With power supply on, I still get nothing. With power supply on I flipped the board over, and wanted to test the 5v from supply to see if it was going to any caps with board off. None of the caps have power. Is this normal?
            As for the terminals for the power switch, both are a ground... Neither have a 5v to them...
            I then tested the green wire from PS (PS says this is the "PS-ON" & "REMOTE") to make sure 5v was coming from the unit with my voltage meter, and it stuttered and all four sys fans flickered on for a sec. I tried it again, and I can not replicate what I did. If the board is not turning on, is there a way to "hot wire" the power supply to kick on so that I can even see if my board will post? Would this NOT be suggested?
            Anybody have any ways of testing other than what I have stated?
            • triplelatte
              • May 2006
              • 10
              You could try a ATX power supply tester. You can find them cheap a most comp stores. Also check your ATX connector on your Mobo to make sure no gunk or something is in there. check all wires on the PSU for breaks as a hidden bad wire can make you want to drink and check your caps in the PSU since its all apart anyhow.
              • MisterGank
                • May 2006
                • 9
                I've got 4 power supplies, tested all on other boards... PS is ok...
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  If you ground Pin14 on the ATX connector the powersupply will turn on
                  If you can not start the powersupply this way (with it connected to the mainboard but alone is fine) then you probably have a short somewhere
                  • kevthegerbil
                    • Jun 2006
                    Have you fitted them the right way in ???? AMD M/B sometimes will not work again the faulty caps damage the north or south bridge ics & the AMD cpu????
                    • tazwegion
                      • Jun 2006
                      • 444
                      I've purchased motherboards before (both used & new) that behaved in a similar manner, quite simply all they needed was a reset BIOS
                      BTW I don't think the board will POST without RAM in the first memory slot, additionally in some unfortunate cases... too much heat during cap extraction/soldering can damage surrounding components
                      Viva LA Retro!
                      • arneson
                        • Sep 2005
                        • 1267
                        Taz is right, I also have a board that needs a special keyboard hold to tell it not to monitor the cpu fan, otherwise it does nothing.
                        Jim
                        • davmax
                          • Dec 2005
                          • 899
                          If 5 volts does not appear this is very often due to a short circuit, the power supply self protects and will not start. If the board had 5 Volt before you recapped the most likely suspect is that one or more of the cap soldered joints that is surrounded by the earth plane is shorted. Look very carefull with a magnifying glass and make sure each cap has a small insulating ring around one terminal ( for the major VRM caps usually). Very difficult to check this with an ohmeter, the resistances are too low in the circuitry.
                          Re-capping the motherboard is not enough. The power supply caps must be checked and if necessary replaced. Often faulty PS caps can take out Mb caps.
                          Hope this is helpful.
                          160Gb WD SATAII Server grade
                          Nvidia 8500GT 256Mb
                          Samsung 18x DVD writer
                          33 way card reader
                          Windows XP Pro SP3
                          17" Benq FP737s LCD monitor
                          • MisterGank
                            • May 2006
                            • 9
                            Oh well... board, CPUs and HeatSinks going up for sale... I got a new board, CPU, and ram...
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                              09-06-2024, 05:59 AM
                              Recap an Adjustable Power Supply DC 0-48 / 0 to 10 A going to use it to charge battery packs
                              I have a 24 volt version of the same type of switching power supply but that one I am relocating to meter module and I might do the same thing with this one but I have to modify an enclosure that is not made for this type of switching power supply in fact I am not sure exactly what type of switching power supply it actually fits because none of one's that I have the screws holes do not line up and not even close but the switching power supply fits in the enclosure
                              So I have take out the switching power supply board out of its enclosure and drill the hole so that it can be mounted...
                              04-14-2024, 05:45 PM
