I have a bad Sapphire ATI Graphic card X1600Pro, when it was mounted on my desktop PC, no image display on my PC monitor and also the fan on the grahic card is not turning.
I checked and found one cap leaking, its a SMD capacitors with the marking
67Z
100
6V
I am not very sure if I am right to assume its a 100uF 6V capacitors
. The diameter of the cap is about 6.3mm.
Greatly appreciate anyone can help to confirm this so I can get the correct cap for replacement.
67Z
100
6V
. The diameter of the cap is about 6.3mm.Greatly appreciate anyone can help to confirm this so I can get the correct cap for replacement.
