TAICON Capacitors?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    TAICON Capacitors?
    Have an ASUS P4B266-E p4 board here. Computer has some issues (could be related to other issues) but is generally stable the caps look good. Saw some fast fluctuations on the power rails????
    Funny thing is if you check the caps. It has :
    Rubycon YXG 6.3 1000mf (nice) 18x
    Rubycon YXG 6.3 1500mf (nice) 1x
    JEC 100mf (???) 6x
    Various small caps
    then wait for it :
    TAICON 16v 1200mf (wtf??) 3x
    TAICON 6.3v 3300mf (wtf??) 6x
    wtf is TAICON? probably no good (Taiwan). Anybody see any failures with TAICON? Anyway, what kind of idiot put Rubycons with taiwan caps.
    I am swapping it out with a new intel board anyway cos the secretary whose computer it is complains way too much. Put in a slower CPU also - be nice and you will be rewarded, otherwise.....
    So any ideas whether i should use this board for something else or do the caps have to go?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I've got an Intel SIA2 server board packed FULL of Taicon caps. The board runs perfectly... Although, it's not very old. I've never heard of Taicon, and they don't look like the highest of quality, but the board is still working fine, so I havent changed them out.
    You don't have to worry about the Rubycon caps, those aren't common to failure, so if the board is acting flaky, you might try swapping out the Taicons just to eliminate them as a factor.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Thanks for the info TC. Interesting to see the SAi2 having taicon. Intel are usually careful with their components which is why I am installing Intel exclusively presently for office computers.
      I was looking at the SAi2 board on ebay. Does it use only ECC ram or is normal SDRAM possible?
      I know the rubycon are good, always nice to see them Ks.
      Think i will take that asus board for a media pc (...er I mean for extensive testing.) Anyway we have probs on our net though it looks like we will have some good funding for upgrades. Anyway we will see if the problems related to this board are replicated on the new install or not next week.
      Can you please elaborate on the power rails fluctuating issue which I think you posted as related to bad caps although I cannot find the post.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        The SAI2 uses ONLY ECC memory. NON-ECC will not work. I've been using it as a SQL/file server with a pair of 1.4GHz tualatin-S CPU's, and it's a remarkably stable box. I have not recapped it, it still has the Taicon caps, and they run cool... I've never heard of Taicon, but on the brighter side, I've never seen a bad Taicon either... The board has been running non-stop for about 2 months, a year down the road should tell the tale as to the quality of the caps, but I'm not worried. If they do croak, I can recap it...
        You were asking about voltage fluctuations in VCORE and other voltages... The prime suspect for that would be power supply. If you are using a known good supply and the voltage is still erratic, you might look at your caps. Bad capacitors WILL cause your system voltages to be sporadic, out of tolerence, or look like noisy garbage under a scope. Even if they aren't bloated and swollen, this can happen. I have seen brand new motherboards be flaky out of the box because of poor caps, and since the board was new, they weren't swollen, but the boards were unstable and unusable. One was an ECS D6VAA dual socket-370 board, the other was a Gigabyte (forgot the model #)... New boards with bad caps isn't common, but it does happen...
        Team : 49813
        Join in!!
        Team Stats
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Thanks for the info. Sounds like a kickass server. I will check the mobo with an Addtronics PSU I have lying around. Its good only for testing really because the fan sounds like a vacuum cleaner (gotta change it some day with a papst). I will see if I replicate the voltage fluctuations.
          Anyway it is good to know you have never seen a bad Taicon. Otherwise it is a good board for recapping. Only 9 caps would have to be changed.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            For the record I have found that Taicon (Taiwan Capacitor Ltd.) was established by Nichicon Japan in 1969 as a joint venture. Remains part of the "Nichicon Family". I guess that is a good sign as they would hopefully be using Japanese electrolyte formula.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i looked through a 5 gallon pickle bucket of dead caps as i poured them into the dumpster today.
              no tiacons in there i could see.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Thanks kc8adu I appreciate you checking.
                Guess they will be allocating a personal landfill for you soon lol .
                • davedog
                  • Oct 2006
                  Re: TAICON Capacitors?
                  Was googling "TAICON CAPACITORS" and came across this thread. Nice site by the way. I just replaced 17 BAD (blown) Taicon 1000uF 6.3 Capacitors on a ASRock P4i65GV Motherboard. Putting a fresh load of WinXP on this system, and so far so good.
                  -dave
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    those taicon and asrock go really well together.
                    • davedog
                      • Oct 2006
                      sorry, i didn't explain well, the TAICON caps were the BAD ones, the ones I pulled of the ASRock board. Is this unusual? Are these usually a good brand of CAPS?
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        they seem to fail on asrock boards mostly
                        • linuxguru
                          • Apr 2005
                          • 1564
                          Which series are those failed Taicons? If they're HN/HM, I would not be too surprised - AFAIK, Taicon manufactured the failed Nichicon HN/HM on the Dell and Intel boards. However, if they're HD/HE/P? I'd be more worried - the Taicon HD 1200/16 is widely available locally, as a useful universal 10mm cap.
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            that was never confirmed here, only speculated. do you have another source for that info?
                            • linuxguru
                              • Apr 2005
                              • 1564
                              Yup, you're right. A quick Google does not reveal any official confirmation/link that Taicon manufactured the bad batches of Nichicon HN/HM that failed on Dell, Intel and Apple motherboards. The only evidence is speculative/circumstantial - 1) a reference to 'Nichicon series' capacitors on Taicon's website; 2) Most of those boards were manufactured by OEMs (Flextronics, Wistron, Quanta, ...) with a significant Taiwanese manufacturing base, so it's likely that they'd have preferred to source the passives locally, perhaps from Taicon rather than Nichicon.
                              It's entirely possible that the application of the HN/HM is marginal - it is thin and long, and located right next to the CPU heatsink in most mobo applications. The combination of location, lack of air-flow and high ripple current must have tipped them over the edge.
                              • davedog
                                • Oct 2006
                                TAICON
                                1000uF 6.3v
                                0436(M)
                                105C(HD)
                                that is all the info on these bad caps
                                • linuxguru
                                  • Apr 2005
                                  • 1564
                                  > TAICON
                                  > 1000uF 6.3v
                                  > 0436(M)
                                  > 105C(HD)
                                  Damn, those are HDs - scratch another from the good caps list. Does it have a sort of bright green sleeve?
                                  • davedog
                                    • Oct 2006
                                    > TAICON
                                    > 1000uF 6.3v
                                    > 0436(M)
                                    > 105C(HD)
                                    Yes, they were green, not sure I'd describe them as "bright green" but green for sure.
                                    • rambaldi
                                      • Nov 2006
                                      I have 15 bad taicons 6.3V 1000uf (green color) in P4AL Asrock MOBO. Just trying to replace them with panasonic caps.
                                      • scotta
                                        • Jan 2007
                                        I had an ASRock K7S41GX motherboard fail a few weeks ago. 12 of the 15 TAICON 1000uF 6.3V caps had bulged and split. The board had been running 24/7 since October 2004. Same green colored caps as previously mentioned. Here's the info on the caps:
                                        TAICON
                                        1000uF 6.3v
                                        0414(M)
                                        105C(HD)
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • black6host
                                          Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                          by black6host
                                          Good day!
                                          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                          I'm going to replace the caps and I'll be the first...
                                          02-06-2024, 08:22 PM
