Usb Noise
  • xformer
    • Jun 2011
    • 16
    Usb Noise
    Hi guys,
    Need your inputs about on how to measure noise in USB and how to remove it.Thanks in advance.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Usb Noise
    you would measure it with a scope
    remove it with a higher grade filter cap with less ripple and lower ESR
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Re: Usb Noise
      or USB cables that have a ferrite filter might help
      • xformer
        • Jun 2011
        • 16
        Re: Usb Noise
        thanks for the help
        • japlytic
          • Oct 2005
          • 2086
          Re: Usb Noise
          For USB 2.0, you would need a high frequency scope with a USB tolerance indicator.
          • sixer
            • Nov 2011
            Re: Usb Noise
            Series L, shunt C. Be careful the L you pick (and the C too) if you're going to put them in series with the D+/D- lines as you can add too much impedance and affect the USB signals. Try putting the filters on the power and ground first.
            Are you trying to prevent USB signals from radiating out, or prevent external RFI from getting in?
            • xformer
              • Jun 2011
              • 16
              Re: Usb Noise
              Hi sixer, the answer is both.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: Usb Noise
                Are you worried about noise in the power or in the signal?
                Using a cable with a ferrite would fix both.
                Mann-Made Global Warming.
                - Dr Seuss
                • sixer
                  • Nov 2011
                  Re: Usb Noise
                  xformer: I think some more information about your situation will help us help you here. Is this a product you are designing or a COTS product you have purchased? Are you having trouble passing FCC Part 15 or do you have some sort of interference/RFI problem that you are trying to mitigate? If so, what is the source of the offending radiation and/or what are the devices that this USB product is offending? What is the product in question (or at least the chipset)? Be verbose
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • tony359
                    by tony359
                    11-28-2023, 05:18 AM
                  • MegaZAC
                    Onkyo TX-SR805 noise in one channel
                    by MegaZAC
                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                    There's some logic behind it. As soon as I select an input I get only left...
                    04-23-2025, 10:09 PM
                  • courtcircuit
                    Philips HTS8000 home cinema noise problem
                    by courtcircuit
                    Hello
                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                    Removed each of tyhe boards
                    02-08-2025, 08:22 AM
                  • longmt1990
                    Panasonic Cf-w5 bios password remove
                    by longmt1990
                    Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                    I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                    Please help me remove bios password.
                    Thank you so much
                    07-06-2025, 10:50 PM
