Usb Noise
    Usb Noise
    Hi guys,
    Need your inputs about on how to measure noise in USB and how to remove it.Thanks in advance.
    Re: Usb Noise
    you would measure it with a scope
    remove it with a higher grade filter cap with less ripple and lower ESR
      Re: Usb Noise
      or USB cables that have a ferrite filter might help
        Re: Usb Noise
        thanks for the help
          Re: Usb Noise
          For USB 2.0, you would need a high frequency scope with a USB tolerance indicator.
            Re: Usb Noise
            Series L, shunt C. Be careful the L you pick (and the C too) if you're going to put them in series with the D+/D- lines as you can add too much impedance and affect the USB signals. Try putting the filters on the power and ground first.
            Are you trying to prevent USB signals from radiating out, or prevent external RFI from getting in?
              Re: Usb Noise
              Hi sixer, the answer is both.
                Re: Usb Noise
                Are you worried about noise in the power or in the signal?
                Using a cable with a ferrite would fix both.
                Mann-Made Global Warming.
                - Dr Seuss
                  Re: Usb Noise
                  xformer: I think some more information about your situation will help us help you here. Is this a product you are designing or a COTS product you have purchased? Are you having trouble passing FCC Part 15 or do you have some sort of interference/RFI problem that you are trying to mitigate? If so, what is the source of the offending radiation and/or what are the devices that this USB product is offending? What is the product in question (or at least the chipset)? Be verbose
