Bad Capacitors or PSU Problem?
  • saxman285
    • Mar 2006
    • 20
    #41
    Re: Bad Capacitors or PSU Problem?
    but to have my old PSUs caps bad, AND the one i just bought?
    .... i just have horrible luck? Earlier in the thread, people said my PSU caps looked fine...
    and whats an ESR meter, and where do i get one?
    • linuxguru
      • Apr 2005
      • 1564
      #42
      OST can also go bad without visible bulging - it's worth recapping the entire bunch of OSTs with any of the recommended good caps. Pay attention to the caps near the Northbridge and DIMM sockets as well.
      • stardreamer77
        • Nov 2005
        #43
        hi saxman285,
        i had a P4P800 deluxe, and i also got this problem b4, after check everythings...my solution is : change the "power switch" that one connect to the mb and casing! then , the problem gone!!!
        and now , i got an other problem !! the pc always keep "restart" !!( continue restart!! even cant see the post screen.... ) also after 3 day of checking (it is killing me!!) .. the problem is the "reset switch wire" is broken!!...
        so try unplug all the switch or led wire, then test it 1 by 1...
        this is my experience, but i'm not sure my solution work in your case...
        and sorry for my poor english....
        hope this help.....
        • starfury1
          • May 2006
          • 1256
          #44
          guess this really is a sticky one, again not the expert here but here's my 2 cents worth
          Since you have now ruled out the psu buy buying a new one.
          If your old one was an enermax and it looks like my other one, mines been going for like 5 years (the computers been on for a couple of hrs (min) nearly every day since its been in)
          near the bottom of this page
          The caps look fine but as pointed out thats not a certainty that they are
          (and there a fair chance they are not)
          we are now back to MB or MB related card connector issue.
          (maybe even a dry solder joint on the MB but others here are best to advise how likely that is)
          Others have posted that the caps(some of them) can fall into the suspect list and you say its been in service for a while.
          Recap might be the short answer.
          If you are intending to keep this system for awhile a recap won't hurt anyway
          (just got to hope it isn't a major MB problem if the recap don't work)
          think it was willawake that said these can be a bit of a pain to recap so if you haven't done it , it might be best to get it done by TC or another forum member close to you if they care to offer you their services (err hope thats OK TC)
          (you don't have a location on your tag)
          I do have few questions thought
          1) Does it ever happen when its cold (like 5 min after start) or is it always a couple of hours or so before it stops.
          2 Does the system spend a lot of time powered up (like 4 Hrs plus each day)
          3) how long has the system been running
          you say that the problem has been getting progressively worse, guessing over the last few months
          (if it is a failing cap it will only get worse)
          lastly to explain ESR
          think of that as "how well a capacitor pretends to be a piece of wire"
          (this is a TOTAL LIE but hopefully gets the idea across)
          So basically low esr caps you can think of as being like a jumper cables general purpose ones like speaker wire
          So we want the capacitors to be "invisible" to the circuit and circuit operation, only act as a big storage bucket of power for the circuit so it can operate at its best.
          The problem comes when the capacitor states to fail and starts acting as part of the circuit causing the circuit to malfunction
          (becomes more like a resistor then a big bucket)
          Again some what bending the truth.
          ESR meters are not cheap things to buy you could buy a good MB for the price of some of them
          willawake has a post of a production build version of this meter bobs esr meter kit
          willawakes post
          A bit on ESR and how bob come to make his meter here
          there are other meters avail and some better some worse but all not that cheap.
          There is a discussion thread somewhere here on building one too
          (I have seen pre built's that probably use similar circuit going for over $200 US)
          just a little info for u HTH
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
          • saxman285
            • Mar 2006
            • 20
            #45
            I'm in California
            1) Yes, it happens WHILE starting sometimes. So definitely regardless of cold or hot.
            2) Yes, it spends a good amount of time powered up, but any decent computer should be able to handle that...
            3) Computer born at the end of 2003 (if thats what you were asking)
            Yes, its getting progressively worse. Now it is almost guaranteed that when i want to use it. It will shut off at least once when im trying to boot or immediately afterward, and then possibly again later while in use.
            • Brian C
              • Dec 2006
              • 156
              #46
              Here are some suggestion from me :
              1. If u have oscilloscope, please check the Vcore, Vdimm, 12V, 5V, 3.3V suuply waveform. Too large ripple voltage, especially under heavy load ( when loading windows, ruuning application), may trigger the protection circuit (shutdown).
              2. It's hard to tell whether a non-bloating cap is a healty cap. You may need to recap the critical circuit like Dimm Voltage regulator, multiphase Vcore for cpu.
              3. Please try new or other power supply (borrow from friend...). Some cheap power supply can easily out of regulation when some rails are lightly loaded due to bad cross-regulation.
              !!! Merry Christmas !!!
              • saxman285
                • Mar 2006
                • 20
                #47
                This power supply IS brand new, and its not a cheap one. Its a Hiper Type R 580w PSU, but the system still shuts down at random times, be it during use, or during start up.
                • davmax
                  • Dec 2005
                  • 899
                  #48
                  Keep focused on the Mobo. It seems that the power supply has been investigated enough. I have not picked up a photo of the mobo. This would help particularly if the shot details the caps around the VRM for the CPU and around the memory. As the problem is gradually getting worse and seems to be independent of temperature it does seem to suggest capacitor ageing. Causing a CPU supply ripple problem and crashing the CPU.
                  Gigabyte EP45-DS3L Ultra Reliable (Power saver)
                  Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
                  160Gb WD SATAII Server grade
                  Nvidia 8500GT 256Mb
                  160Gb WD eSATAII Server grade for backup.
                  Samsung 18x DVD writer
                  Pioneer 16x DVD writer + 6x Dual layer
                  33 way card reader
                  Windows XP Pro SP3
                  Thermaltake Matrix case with 430W Silent Power
                  17" Benq FP737s LCD monitor
                  HP Officejet Pro K5300 with refillable tanks
                  • saxman285
                    • Mar 2006
                    • 20
                    #49
                    There are pictures of the Mobo on page 2 of this thread.
                    • bgavin
                      • Jan 2007
                      • 1355
                      #50
                      Where does one probe if the board won't power up at all? I assume there is a +5v point somewhere as a starting point... ?
                      • Rainbow
                        • Aug 2005
                        • 1371
                        #51
                        Try shorting the PS_ON# signal (usually green wire) on the ATX connector to ground. If the PSU starts, then there is a problem in power-on circuit. If the PSU does not start, there is a short on the board.
                        • bgavin
                          • Jan 2007
                          • 1355
                          #52
                          To clarify: I understand you to mean shorting the ATX signal to ground while plugged into the board.
                          I can start the PSU stand-alone using my PSU test tool. It starts up fine, spins the fans, etc. It is a known-good PSU.
                          • Rainbow
                            • Aug 2005
                            • 1371
                            #53
                            Yes, while plugged into the board. Some boards will even start and run when powered up this way.
                            • Fizzycapola
                              • Oct 2006
                              • 423
                              #54
                              You should really cease or limit using this computer and power supply until problem can be resolved. Worsening problems eventually regulators will fuse inside causing ram, graphic card and CPU to be destroyed.
                              Any part that has been near a bad PC can give the same fault to new PC's.
                              It seems to me PC's increasingly are becoming the tool to keep the poor poorer, I for one would be quite wealthy without PC problems every few months and it doesn't seem to matter what parts I buy or how expensive.
                              Rubycon Rubycon Rubycon
                              • theone111
                                by theone111
                                3. Problem: TV shuts down
                                07-22-2024, 10:36 AM
                              • CasasElectronics
                                Acer 6920G with strange error - sometimes boots and sometimes not, and rare fan noise
                                by CasasElectronics
                                Hi, I've been troubleshooting this PC for a while but I cannot repair it for now.
                                The error on this PC was the known graphics card soldering problem (or that was what I was thinking), so I took a 3470 from a 5920G and installed it.
                                The video after that worked, so I thought the problem was solved. When I tried to install windows, I noticed a problem: the ACER logo (bios load) stopped after completing the loading bar (and that was in every power on, but sometimes not even charged the Acer logo screen, I only could see a blinking white bar).
                                So I thought it may be...
                                02-25-2025, 03:26 PM
                              • HTR-Informatique
                                by HTR-Informatique
                                02-09-2025, 06:51 AM
                              • Zeonalbasta
                                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                by Zeonalbasta
                                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                09-13-2024, 01:17 PM
                              • Ady2017
                                Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
                                by Ady2017
                                I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
                                06-06-2025, 08:05 AM
