Seeking advice - Marcon or Hitano
  • craftech
    • Mar 2006
    • 45
    I am new here and it is a pleasure to be a part of your forum.
    I have two blown caps near the CPU of my Soyo SY-6BA + 100.
    It is a video editing computer so it runs many long hours. It won't post. PSU is good, CPU good. No beeps. Everything spins up, etc.
    I have two different capacitors I can install, but I cannot find out anything about one of them.
    The one with posted specs is the Hitano 8mm 1000 uf /10 v cap number 9735A. I have searched the forum and read mixed reviews on these. I have a bunch of them.
    The other one is a Marcon 13mm 1000 uf/10v cap number CE-MD. I can't find anything out about them except that they are now a part of United Chemi-Con. I actually used two of these to repair a Soyo SY-6BA + IV a few years ago and the board has been running fine ever since. I don't know if they are low-ESR or not.
    The 6BA+IV wasn't as critical a computer as the video editing computer so I wanted to ask before I went ahead and used the Marcons. With reasonable care they will fit. I do need to be up and running soon.
    Recommendations?
    John
  • craftech
    • Mar 2006
    • 45
    Re: Seeking advice - Marcon or Hitano
    Further specs -
    The Hitano number (9735A) doesn't show up on the Hitano website and I am not really sure which Hitano I have. The dimensions are 8mm diameter x 11 mm long and they are black. Heat rating is 105 degrees C and is says VENT on it. They are a little wierd because the leads are both the same length and are really short (around 4mm long). They will have to be soldered from the PCB side of the board. The Neg lead IS marked though.
    The Marcon CE-MD is Blue and is 13mm Diameter x 23mm long. Heat rating is 85 degrees C and it has a rating of 1 SB. Normal long leads on them.
    Thanks,
    John
    • craftech
      • Mar 2006
      • 45
      Sorry, the Hitano is 8mm x 14.5 mm long (not 11mm long).
      • craftech
        • Mar 2006
        • 45
        OK,
        The Hitano caps are SNAP IN Terminal Type, but they must be a discontinued model because none of the three listed here match in voltage or size.
        http://www.hitano.com.tw/electrolytic.html
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          i have no experience with either of them.
          we can only recommend to use known reliable types, especially with mission critical systems. anything else, you are on your own.
          Where to buy capacitors / Recommended types
          isnt video encoding somewhat cpu intensive. you could pick up a budget current system which would be more than quite faster. otherwise watch the for sale section of this site.
          welcome anyway. anyone with a soldering iron in their hand is most welcome indeed.
          • PeteS in CA
            • Aug 2005
            • 3583
            • USA, Unsure of Planet
            On the Hitano, "9735A" is probably the date code - 35th week of 1997. Snap-in caps aren't low impedance parts per se, but usually are fairly low impedance, and have fairly high ripple current ratings.
            Marcon became part of UCC in the early 90s or so, so that Marcon cap is probably 10 or more years old. Also, since it is rated for 85C it probably is a general purpose or low-leakage current part rather than a low ESR, high ripple current part (which are normally rated for 105C).
            PeteS in CA
            • craftech
              • Mar 2006
              • 45
              Thanks to both of you for the knowledge and advice. Despite the fact that the Marcon caps have worked in the nearly identical 6BA+IV board for three years and the Hitano caps "may" work I think the safest bet for my 6BA+100 editing computer would be to order some of the low-ESR recommended caps like the Panasonic FC/FM or the like.
              Regards,
              John
              • RJARRRPCGP
                • Jul 2004
                • 6304
                1997! There's no way that the motherboard can be that old!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • craftech
                  • Mar 2006
                  • 45
                  Sorry for the confusion, but the caps I was referring to are caps I have had in my electronics parts inventory for a long time. They could easily be that old.
                  John
                  • craftech
                    • Mar 2006
                    • 45
                    Just wanted to let you know that the Panasonic FM caps came today. Replaced the two blown Wendell caps and I am back up and editing Act II right now.
                    Thanks guys for the advice.
                    Regards,
                    John
                    • Borse2008
                      Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                      by Borse2008
                      Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                      I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                      • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                      • There’s
                      07-15-2025, 04:55 AM
                    • Cooperr
                      Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                      by Cooperr
                      I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                      The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                      10-21-2025, 01:11 PM
                    • Ven
                      Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                      by Ven
                      I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                      The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                      I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                      If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                      07-08-2024, 09:32 AM
                    • willis6732
                      XBR-75X940D : Alive but no Backlight, Seeking Advice...
                      by willis6732
                      Hello, Tv Has no Backlight (or Sound that i know of)
                      Tv Turns on flashing Orange/Green, and then turns to white with remote and can be turned on and off.
                      Was also able to update firmware with no change.
                      The TV had a Burnt LED Driver IC on the Main Power board, Both main power boards have been replaced.
                      I would like to test the backlights on this TV without opening it up. I am confused by all the ribbon cables coming off the LED Driver board
                      I have a LED Tester...
                      Ribbon cables E,F Look totally different than A,B,C,D,G,H,I,J...
                      11-01-2024, 02:03 PM
                    • Phad
                      Seeking help and advice to remove bios admin password – HP ProBook 4520s
                      by Phad
                      Dear All,
                      Hope that this post is at the right place of the forum.
                      I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                      The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                      As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                      After...
                      11-10-2021, 12:05 AM
