Rubycon ZL?
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Rubycon ZL?
    Have a Gateway motherboard here, has alot of Rubycon ZLs on it, these good? Only two caps I had to replace on this were bloated out Nichicon HMs with the date code 0251 (replaced those with Rubycon MBZ)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Rubycon ZL?
    Yes, rubycon ZL is fine. they'll never give you any trouble.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Hemingray
      KABOOM!
      • Jul 2010
      • 143
      Re: Rubycon ZL?
      Awesome! They didn't look bad so I left em, board works just fine. Just replaced the two bloated out HMs
      • c_hegge
        • Sep 2009
        • 5219
        Re: Rubycon ZL?
        All rubycon caps are reliable. They are one of only 3 manufacturers I can think of who have never made a bad series before (the other two are Sanyo and Panny)
        • severach
          • Aug 2007
          • 1055
          Re: Rubycon ZL?
          Not only that, ZL is extremely rugged. Rubycon MBZ and MCZ are good but will bulge in moderate heat. ZL can take a lot of heat so are a common choice for server products.
          sig files are for morons
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Rubycon ZL?
            Actually ZL get used in less strenuous applications because they can't handle anywhere near as much Ripple as MBZ or MCZ.
            And 'moderate' is an understatement. 'Excessive' would be more appropriate.
            Sanyo and Panny do seem to do better in hot boxes.
            MBZ also seems to do better than MCZ in poorly cooled machines like the small Dells.
            Sanyo isn't Sanyo anymore though. Now they are Suncon.
            Mann-Made Global Warming.
            - Dr Seuss
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Re: Rubycon ZL?
              It doesn't matter anymore....Rubycon doesn't make either of these series any longer...
              Team : 49813
              Join in!!
              Team Stats
              • c_hegge
                • Sep 2009
                • 5219
                Re: Rubycon ZL?
                Well, if ruby MBZ does better than the other slightly lower ESR series like MCZ, it REALLY doesn't inspire much confidence in Nichicon HZ.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: Rubycon ZL?
                  I don't buy HZ because I don't trust them. Not fact, just gut feeling.
                  Any place you -really- need ESR that low can be a polymer anyway.
                  Seems when they push the electrolyte to the high end it gets less reliable.
                  How far it gets depends on the brand.
                  Chemicons crap out at KZG and I think that's what their deal is too.
                  Got too creative/exotic on the electrolyte.
                  - Dr Seuss
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    Re: Rubycon ZL?
                    Since the discontinuation of MB and MC, I've replaced them with HN, HM, and HZ. So far, I've had no issues....but its too soon to tell. In a few years, I'm sure the toaster boxes will start cooking them, those bastards will roast ANY lytic (dell GX620usff, GX745usff, SX280, etc) including panasonic (the holy grail of lytics IMO).
                    After the HN and HM debacle of 04, I was leary to say the least.....but panasonic wouldn't even talk to me when I tried to acquire larger quantities....Nichicon would....so that's the way the cookie had to crumble... I have faith in them, I've had no issues....and Nichicon has always been a good brand otherwise. Been using them for about a year now.
                    FWIW, I've gotten some GX745USFF's that were refurbed by Dell, and had Rubycon ZLH's in place of MCZ's the 2200uF 6.3v positions....and a few cooked. Datecode on them was 08 & 09.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: Rubycon ZL?
                      Rubcon says on their site to use ZLH in place of MCZ and that is flat out bogus.
                      ZLH just doesn't handle near the amount of Ripple MCZ (or MBZ) did.
                      Took a while but I'm good with HN and HM now.
                      HZ are pretty much over-kill outside of the VRM Vcore and maybe in RAM.
                      Between that, not really trusting them and given where their cost falls I'd rather use HN, HM or poly in Vcore and RAM depending on what was there to start with.
                      Going poly often ends up being cheaper now days anyway. Just makes more sense to me.
                      - Dr Seuss
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Re: Rubycon ZL?
                        IMO, HZ are overkill anywhere. I've never seen a motherboard come with them, VRM or elsewhere. In fact, I don't often see boards with MCZ or equivilant. It's usually MBZ or equivilant.
                        I'm perfectly OK with using HM and HN anywhere, I just with topcat would have them in a few more sizes.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Re: Rubycon ZL?
                          Just observations and speculation here:
                          I've seen a lot of MCZ or equivalent but mostly after MBZ went away.
                          I think the switch was partly an availability issue when their heart [or contracts] were set on using Rubycon.
                          Supermicro tends to use a mix of Sanyo WG and Polys on everything including their non-server boards.
                          [At least into sockets 771/775. Haven't seen much newer stuff because I don't need it.]
                          Intel server boards in the same range are pretty similar in so far as the grade of the caps they use but their consumer boards Intel's boards are more like the other brands.
                          But on their non-server boards Supermicro does use a lot -more- 8mm & 10mm caps outside the VRM than most other brand boards [sometimes 30-40] so that might be part of it.
                          Another part of it.
                          The consumer type boards with HN/MCZ-equivalent on the bulk of the board [I think] use them to keep the ESR down without adding to the cap count.
                          That's also about $$ and eating up board space.
                          On server boards adding another 10-20 caps isn't going to add much to the cost plus they have lots of 'real estate' to play with.
                          - Dr Seuss
                          • DrewPhillips
                            Capacitor Diarrhea - Nichicon PL Series
                            by DrewPhillips
                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                            03-02-2025, 10:18 PM
                          • nick3092
                            Mid/late 80's Nichicon Yellow Caps
                            by nick3092
                            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                            08-28-2022, 03:56 PM
                          • withalligators
                            Looking for best replacements for Capxons, but can't find data sheets
                            by withalligators
                            Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                            1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                            1 x Capxon 1000uf35v...
                            03-25-2022, 02:30 PM
                          • chth96
                            Is there datasheet for nichicon LXJ series?
                            by chth96
                            I want to calculate capacitor ESR referring to below guide.
                            https://forum.digikey.com/t/calculat...-from-tan/2633
                            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                            11-20-2022, 08:11 AM
                          • chth96
                            Is there any datasheet for nichicon RT(M) series?
                            by chth96
                            A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                            https://www.badcaps.net/forum/troubl...e-been-blew-up
                            and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                            But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                            I have spare console...
                            11-28-2023, 03:36 AM
