I just got another broken ASUS board, there's 5 bulging caps on it. They're UCC KZG 6.3V 3.300uF D10mm. I see that the caps is in VRM, but i need to make sure if it's right. I also need advice what caps can be use to replace them other than 3.300uF. Those 5 caps are the only 6.3V 3.300uF D10mm caps on the board.
Btw, i've seen more UCC caps bulging and never seen a bulging Nichicon. Is it UCC is more inferior than Nichicon?
I've got a DMM but it's just a normal Digital Multi Meter and not a Low ESR meter. Can you tell me how to check it with a DMM if they are paralleled?
(this board has a twin and that twin also has the same bulging problem with it's VRM but doesn't show any problems yet),
and that Samxon caps will arrive after one week.
What other reason for bulging cap beside hours used and heat? Bad PSU or elctricity?
