I can't seem to identity these caps, I've never seen this logo before. I'm a long time viewer of the forum. Thank you.
Unknown brand, "SC" logo
Re: Unknown brand, "SC" logo
According to:
http://capacitor.web.fc2.com/c.html#cs
they are "Chun Shing" capacitors.
The company's website doesn't seem to work very well:
http://www.12kj.com/docc/product.htm
I see them from time to time, mostly in cheap power supplies. The ones you have pictured appear to be input filter caps. Primary input filter caps rarely fail, but the ones here can likely be replaced with any reliable brand of general purpose capacitor. -
They are alright. I've only seen them fail in crap power supplies when put next to those minimum load resistors that run very very hot. My old Spire power supply also has them (apart from the cheap caps the build is quite nice) and it still runs fine.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Where other than crap PSUs have you seen them?
I've only seen them in crap PSUs.
And they failed.
.Last edited by PCBONEZ; 06-07-2011, 12:41 AM.Mann-Made Global Warming.
- Dr Seuss
I've seen that logo a couple of times too, in cheap stuff.
If you were doing a recap job in a PSU with those you might as well replace them too and save yourself potential future headaches."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Saw ones with that brand bulging and leaking in 2 CoolMax PSUs.
Appears to be common in CoolMax PSUs.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
by Teban1306[REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
Hello everyone!
I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
System Information:- Model: Lenovo ThinkPad T14 Gen 1
- Machine Type: 20S1S4E600 (Intel i7 variant)
- Current BIOS: N2XET42W (1.33) - Latest version
- BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
Replace the default "LENOVO" boot logo with a custom image during POST.
🔧 What I've tried:- [
Channel: BIOS Requests ONLY!
by peterwangHi! I encountered a Clevo brand laptop that needed its boot LOGO modified. I found the LOGO address, but after the modification, the machine stopped displaying it. I'm puzzled. It worked normally before the 11th generation of CPUs, but it stopped working from the 12th generation onwards! The LOGO addresses are:
166BACEC-6793-4F38-213F-DE0BEF4FEF95
166BACEC-6793-4F38-213F-DE0BEF4FEF97
166BACEC-6793-4F38-213F-DE0BEF4FEF99
I have provided the BIOS and LOGO files that require LOGO modification, and I hope someone can help me.
post moved...next time look for a thread...-
by VerlengsnoerHi all,
at firs, i hope this is the right place to post my question.
Im looking for a tool to change the bios logo.
everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
i know that HP has a build in option to change the splash logo.
but i want to change the manufacturer logo to an own logo.
I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
...10-28-2022, 09:52 AM -
by Stanley1843Hello,
has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.06-22-2024, 11:06 AM -
by flat-eartherI have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
I have opened the camera and I think there is enough room to add something inside to accomplish this:
The camera is powered by a 3.7V nominal single cell lithium ion battery.
So I need to connect another battery in... - Loading...
