Unknown brand, "SC" logo
  • EngrChris
    • Aug 2010
    • 3
    I can't seem to identity these caps, I've never seen this logo before. I'm a long time viewer of the forum. Thank you.
  • yyonline
    • Jul 2009
    • 692
    Re: Unknown brand, "SC" logo
    According to:
    http://capacitor.web.fc2.com/c.html#cs
    they are "Chun Shing" capacitors.
    The company's website doesn't seem to work very well:
    http://www.12kj.com/docc/product.htm
    I see them from time to time, mostly in cheap power supplies. The ones you have pictured appear to be input filter caps. Primary input filter caps rarely fail, but the ones here can likely be replaced with any reliable brand of general purpose capacitor.
    • EngrChris
      • Aug 2010
      • 3
      Thank you.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        They are alright. I've only seen them fail in crap power supplies when put next to those minimum load resistors that run very very hot. My old Spire power supply also has them (apart from the cheap caps the build is quite nice) and it still runs fine.
        A working TV? How boring!
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Where other than crap PSUs have you seen them?
          I've only seen them in crap PSUs.
          And they failed.
          Mann-Made Global Warming.
          - Dr Seuss
          • Agent24
            I see dead caps
            • Oct 2007
            • 5085
            • New Zealand
            I've seen that logo a couple of times too, in cheap stuff.
            If you were doing a recap job in a PSU with those you might as well replace them too and save yourself potential future headaches.
            -David VanHorn
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Saw ones with that brand bulging and leaking in 2 CoolMax PSUs.
              Appears to be common in CoolMax PSUs.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Teban1306
                [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                by Teban1306
                Hello everyone!
                I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                System Information:
                • Model: Lenovo ThinkPad T14 Gen 1
                • Machine Type: 20S1S4E600 (Intel i7 variant)
                • Current BIOS: N2XET42W (1.33) - Latest version
                • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                What I'm trying to achieve:
                Replace the default "LENOVO" boot logo with a custom image during POST.
                🔧 What I've tried:
                09-14-2025, 11:49 AM
              • peterwang
                CLEVO PCB:6-71-V2500-D02
                by peterwang
                Hi! I encountered a Clevo brand laptop that needed its boot LOGO modified. I found the LOGO address, but after the modification, the machine stopped displaying it. I'm puzzled. It worked normally before the 11th generation of CPUs, but it stopped working from the 12th generation onwards! The LOGO addresses are:
                166BACEC-6793-4F38-213F-DE0BEF4FEF95
                166BACEC-6793-4F38-213F-DE0BEF4FEF97
                166BACEC-6793-4F38-213F-DE0BEF4FEF99
                I have provided the BIOS and LOGO files that require LOGO modification, and I hope someone can help me.
                post moved...next time look for a thread...
                07-05-2025, 03:57 AM
              • Verlengsnoer
                Bios splash/logo change
                by Verlengsnoer
                at firs, i hope this is the right place to post my question.
                Im looking for a tool to change the bios logo.
                everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                i know that HP has a build in option to change the splash logo.
                but i want to change the manufacturer logo to an own logo.
                I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                10-28-2022, 09:52 AM
              • Stanley1843
                BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                by Stanley1843
                has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                06-22-2024, 11:06 AM
              • Genghis_Khan
                ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                by Genghis_Khan
                I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                Issue summary:
                Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                11-11-2025, 11:51 AM
