Need help with compatibles...
  • bw1
    • Sep 2010
    • 172
    Sorry for always asking for help with compatible caps, but I have a hard time finding the info or data sheets for the originals, and sometimes even when I do, I'm not quite positive about what's compatible.
    1000uf/25v SAMXON GF(M) V9A is the original. Would SAMXON GT(M) Y3A work for a replacement? (currently closest match I've got)
    1000uf/10v SAMXON GF(M) V8A is the original. Would Ruby MCZ's work for a replacement? (currently closest match I've got)
    220uf/25v TAICON C0635(M) 105*C(PW)P is the original. Would SAMXON GT(M) X1A's work? (currently closest match I've got)
    I know, everyone points newb's to the "What capacitors should I buy?" post, but it doesn't have ANY Samxon info on it, nor does it say how close the ESR needs to be to the original.
    ANY information to help assist with future replacement compatibility would be greatly appreciated! I'm great with actually replacing the components, but a bit hesitant with picking out replacements.
    Thank you! (:
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Need help with compatibles...
    https://cdn.badcaps-static.com/pdfs/...f9651347cb.pdf
    PCBONEZ teaches at
    https://www.badcaps.net/forum/showpo...30&postcount=7
    --- begin sig file ---
    --- end sig file ---
    • bw1
      • Sep 2010
      • 172
      • macmino
        Buffer data does not match SPI chip!
        by macmino
        Hi all, after several attempt, I finally got a working CH341 Pro working USB device. Now I'm able to read dump the BIOS
        When I verify the image (800G6_EC_RCunlocked.BIN found on this forum) I receive "Buffer data does not match SPI chip!". I tried different programmer but the message is the same. Anyway, I removed the password but I see at the boot the HP Message:
        "HP Endpoint Security Controller Problem"
        When I hit OK, the boot continues and I'm able to use the computer. Did. the SPI chip not match error caused the error?
        09-08-2024, 09:52 AM
      • chth96
        Can I replace KME cap with Samxon GF cap?
        by chth96
        Hello.
        I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
        Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
        I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
        04-17-2024, 07:11 AM
      • TJ65
        Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
        by TJ65
        i made out of two broken Samsung Galaxy Tabpro S one that works partially.
        The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
        I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
        The problem is, that the micom Version doesn't match with the bios version, see picture.
        How can i update the Micom Version? The Samsung bios update wont work.
        With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
        01-09-2025, 01:35 PM
      • Devonavar
        Vizio M43-C1 - How closely do I need to match the mainboard number?
        by Devonavar
        I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
        I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
        Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
        So, I've ruled out the PSU for now.
        The reboot loop...
        08-14-2022, 08:46 PM
      • wyde666
        Help find BIOS MSI MS-14B1 match with my board
        by wyde666
        hi guys, I have laptop MSI MS-14B1 with multiple short to ground, after replace few IC that short, I've manage to no short on board, tried to turn on board only power led light up and fan spin no display on screen, tried to flash bios and KB IC with file from this forum but still no luck, in MSI webpage there 4 version for this model and i confuse which model that i have, so can you guys please help me bios + EC file that match with board I have.
        MS-14B11 V.1.0
        I have the original backup BIOS + EC, maybe this helping.
        thank you....
        11-16-2023, 09:18 AM
