Help find BIOS MSI MS-14B1 match with my board
  • wyde666
    • Feb 2020
    • 17
    • Indonesia
    hi guys, I have laptop MSI MS-14B1 with multiple short to ground, after replace few IC that short, I've manage to no short on board, tried to turn on board only power led light up and fan spin no display on screen, tried to flash bios and KB IC with file from this forum but still no luck, in MSI webpage there 4 version for this model and i confuse which model that i have, so can you guys please help me bios + EC file that match with board I have.
    MS-14B11 V.1.0
    I have the original backup BIOS + EC, maybe this helping.
    thank you.
    Last edited by SMDFlea; 11-16-2023, 09:36 AM. Reason: added extrnal images to badcaps
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: Help find BIOS MSI MS-14B1 match with my board
    MS-14B11 V.1.0
    thank you.
    POST SERIAL NUMBER/SERVICE TAG:-
    All donations to badcaps are welcome,see the donate button at the bottom of the page,or click on this link to donate via PayPal. Every donation made will go towards server fees and maintenance costs.
    • wyde666
      • Feb 2020
      • 17
      • Indonesia
      for Serial Number or Service Tag i cannot figure it out because label is not readable anymore (see attachment)
      and i only find number on motherboard but not sure is the serial number or not (see attachment)
      after see spec from MSI website my model is either PS42 8M or PS42 Modern 8MO because i have 40W adapter and this board dont have nvidia graphics chip.
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        for serial number or service tag i cannot figure it out because label is not readable anymore (see attachment)
        after see spec from msi website my model is either ps42 8m or ps42 modern 8mo because i have 40w adapter and this board dont have nvidia graphics chip.
        here is your new bios 128kb ec+8mb main bios
        model was ps42 8m
        • wyde666
          • Feb 2020
          • 17
          • Indonesia
          model was ps42 8m
          thank you sir, will try it and post here for updates.
            • 21914
            model was ps42 8m
            DMI 260000 - 26FFFF
            • aminsab
              • May 2023
              • 50
              • France
              Hello, i need help laptop msi turn on but no dislay
              i tried this bios file but the same probleme.
              SKU: PS42 RB-035fr-ss7855U16gxxdx10mh
              S/N: K1808N0076513
              thank you
              • hoaca388
                Badcaps
                • Jan 2022
                • 12330
                S/N: K1808N0076513
                thank you
                PS42 Modern (8th Gen Intel® Core™ processor)
                Model_PS42 8RB
                • aminsab
                  • May 2023
                  • 50
                  • France
                  Model_PS42 8RB
                  thank you still the same probleme keyboard light-on fan spinning no display on screen (nor via hdmi)
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12330
                    Then you have no problem with bios, check hardware, this is new bios from MSI.
                    • aminsab
                      • May 2023
                      • 50
                      • France
                      ok i will check about that, Thank you so much hoaca388
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • DynaxSC
                        Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                        by DynaxSC
                        I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                        I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                        Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                        Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                        05-04-2025, 12:08 PM
                      • aico60
                        Acer Nitro 5 AN515-46 DMI not working
                        by aico60
                        I am working on an Acer Nitro 5 AN515-46, board HH51R LA-M002P Rev: 1A with an AMD CPU and Insyde Bios rev 5.
                        Short issue description: BIOS does not recognize any of the DMI data.
                        History of the laptop:
                        The seller of the laptop said that it shut down during a BIOS update.
                        I bought in in a condition where it turned on but did not post.
                        While waiting for my RT809F to arrive, I tried to perform a Crisis recovery, which messed up the EC firmware, so... the laptop stopped even turning on. Power and Charging LEDs didn't work either...
                        05-06-2025, 08:44 AM
                      • edward card
                        BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
                        by edward card
                        I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
                        Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
                        Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
                        Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
                        10-06-2025, 05:41 AM
                      • danielgerman681
                        ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                        by danielgerman681
                        Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                        08-27-2025, 01:17 PM
