My first recap -FAIL! Please offer advice.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: My first recap -FAIL! Please offer advice.
    Originally posted by Agent24
    Well it's several years old and it's been OK so far,
    I would love to see pictures of the insides of this multimeter. I'm studying multimeters and like to learn more.
    --- begin sig file ---
    --- end sig file ---
    • bigbeark
      • Jan 2010
      • 661
      Originally posted by Davisdog
      bigbeark,
      I did test it outside of the case, sitting on cardboard. Same deal. I'm using a 30 watt pencil style iron, from Radio Shack. One of the legs of the problem cap had broken off inside the hole. I had a heck of a time getting it out. When I was done, the hole looked pretty nasty. I have already tried reflowing it, along with all the rest, but there was no change. I didn't mess with the other poly's at all.
      I hate to say it, but I'm thinking you tore the via trying to get that "leg" out.
      In my experience 30W is completely inadequate for motherboard work. 50W should be considered the minimum. I have one of those Radio Shack Irons and was able to remove a few caps but it wasn't really working very well. I spent the bucks and got a Hakko 936 solder station. They have come down in price from when I got mine, but that's what you need for this work. You need the 1/8 inch chisel-tip on that iron too.
      When you are unsoldering those VRM caps, there are some big copper-rich traces inside the board that just suck up the heat and stop you from nelting the solder enough. Result: the leg sticks in the board and if you try to remove it you damage the board.
      The only way a gutless iron is going to work is if you preheat the entire board in the oven first and frankly just get a good iron and save yourself the bother.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5038
        • New Zealand
        Sure, here they are.
        -David VanHorn
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          One of the nicest 830's I've seen.
          An insulator between the battery and board.
          Board is one piece!
          I've outlined the board in your pic, showing where that stupid 'jack board' would normally be. It would only be held by solder!
          Did you trim and resolder the leads for the transistor socket? The bad 830s would have those leads left as long as a quarter inch!
          You may continue to use that, *carefully* of course
          -Paul
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • Agent24
            I see dead caps
            • Oct 2007
            • 5038
            • New Zealand
            No I didn't do any modifications to it, the photos show how it came from the shop.
            Sounds like the cheaper versions are pretty bad though!
            Only bad thing with mine was that the test leads broke in months, can't remember details but I got much better ones from DSE which have been perfect ever since.
            -David VanHorn
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              I hear you on the test leads. Months you say? Usually one month, tops. It would indeed seem like yours is a better one.
              Unless used for resistance or where there's no chance of high energy faults, those really bad ones with the jack board should be destroyed on sight. Accident prevention, ya know
              That's exactly what I did to the one mentioned above. It may have been possible to fix, but the guy only paid 4 bucks for it. Not worth it.
              -Paul
              EOL it...
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #27
                I have a cheap, no-name, run-of-the-mill, 830D. I've had it for over 10 years now. Still works great. Other than the leads breaking after 1 month like you mentioned, I've never had any other problems with it. Used it quite a few times to measure 110 and 240 VAC as well as 320 VDC in PSUs. No explosions.
                And I can't tell you how many electronics I've been able to save with it.
                So if the OP needs a multimeter just to test this motherboard only, then by all means a cheap [<$10] 830 will be fine (just make sure it works before you buy it ).
                Like Agent24 said, a cheap multimeter is still better than no multimeter at all.
                • Davisdog
                  • Feb 2011
                  • 10
                  #28
                  Howdy all,
                  Thanks for the advice and direction. Unfortunately it seems that my heavy hand and inexperience led to me destroying this mobo. That's not 100% yet, as I don't have a DMM to check it with, but I'm fairly certain.
                  As I couldn't do without a functioning desktop anymore, I purchased a new mobo (and a larger PSU.) Now, if I could only get the OS to load.......
                  Davisdog.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5038
                    • New Zealand
                    #29
                    Yeah if you change motherboard you will usually get into some problems because the hardware is so different and the drivers are all wrong.
                    Try safe mode, if you're lucky that might work, then, uninstall all irrelevant drivers and try normal mode again.
                    Other than that, might need to do a repair install of windows (but a full reinstall would be the best)
                    -David VanHorn
                    • seanc
                      • Nov 2008
                      • 1319
                      #30
                      What OS are you running?
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Probably windows Vistrash/Visturd
                        • Davisdog
                          • Feb 2011
                          • 10
                          #32
                          I've got Vista Home Premium, but it's an OEM version that came with the PC. I can't get it to load at all, but when I go into the recovery options, the system does see my HD with all the files, but will only let me access drivers that are already on the system or on a disk.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            #33
                            post a pic of the cap you had trouble getting out.
                            a torn via may or may not be critical.
                            • Davisdog
                              • Feb 2011
                              • 10
                              #34
                              I'll try to get a decent picture of that cap a little latter today. Might be a bit of a chore though - I'm having camera issues that rival my computer issues.
                              • seanc
                                • Nov 2008
                                • 1319
                                #35
                                nVidia chipset on the old board.
                                What's the new board?
                                • Davisdog
                                  • Feb 2011
                                  • 10
                                  #36
                                  I bought a asus M2N68-AM PLUS. Using the old processor (AMD Athlon 64 X2 5000+) and the two 1 gig sticks of DDR2 from the old system. The new PSU and mobo let me install three HD's I had laying around, so backups shouldn't be an issue anymore. After I figured out that there was a long leg from one of the components contacting the case, the rest of the install went pretty smooth. I did have to buy a new OS though. I got Windows 7 Home Premium. So far so good.
                                  No chance to mess with the camera yet. I'm not home until tomorrow and I'll be sleeping all day, so maybe the next day.
                                  • Sus256
                                    HISENSE 65E7KQ PRO - no boot
                                    by Sus256
                                    Hi all!
                                    HISENSE 65E7KQ PRO
                                    RSAG7.820.13512 - chassis
                                    MT9618BAATAB - cpu
                                    RSAG7.820.12059 - power
                                    HD650Y3U77 - panel
                                    KLM8G1GETF - emmc
                                    The TV does not turn on, the standby indicator is on. All voltages are present.
                                    Emms is dead. Not readable, not detected.
                                    Replaced emmc.
                                    But with another dump there is no launch
                                    Terminal log
                                    UART
                                    AC_ON
                                    RPMB key is not yet programmed
                                    HASH1_VERSION=0x00000000 64bit
                                    E-B
                                    FDE enabled
                                    layout pattern onebin by SAR7,0...
                                    06-01-2025, 02:11 AM
                                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                    09-12-2024, 02:00 PM
                                    GeForce RTX2080 Super Aero video gaming card issues help need
                                    by sam_sam_sam
                                    This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                    Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                    05-07-2023, 08:12 AM
                                  • Hondaman
                                    Windows 11 buying advice needed
                                    by Hondaman
                                    My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                                    She does not want to switch to Linux. And she does not want to use a laptop because...
                                    04-14-2025, 11:35 PM
                                    HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                    09-06-2024, 06:20 AM
