For those who swear by Teapo
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I've had people tell me that they think Teapo caps are high-end because they don't bulge as most of the others do. Well, here's some evidence to the contrary. This is a VP6 that was "refurbished" by Abit via the class action lawsuit.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Rainbow
    • Aug 2005
    • 1375
    Re: For those who swear by Teapo
    I've seen bulged Teapo too - but only one. They're not good but still better than GSC.
    • Newbie2
      • Sep 2005
      • 885
      My dad swears by Teapo. I always tell him that Teapo is crap but he says Teapo isn't crap.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i wonder how many on that board are open or very high esr?
        i see way more teapo open than bulged.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Teapo is el cheapo!
          Ludicrous gibs!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I hate Teapo, and their rebadged brands like Gluxon and Yaego they all suck ! I replace Teapo on site.
            • phunny
              • Feb 2016
              • 5
              They seem to have gained a little size
                • 31214
                i was more distracted by the excessive application of silicone-grease
                • delaware74b
                  • Apr 2009
                  • 628
                  Holy thread revival, Batman!!!
                  Stupidity should be a crime, especially for drivers. I have NO patience for them.
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    I swear at teapo...
                    Me too...
                    "pokemon go... to hell!"
                    EOL it...
                    All style and no substance.
                    guilty,guilty,guilty,guilty!
                    guilty of being cheap-made!
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      Also known as the School Lunchroom Spatula Spread Method of Applied Tim.
                      • Stefan Payne
                        • 1267
                        They may last.
                        Or they may not last.
                        Depending on the circuit, heat and what series you use...
                        Those green ones are usually SC or maybe SM. Not the best ones Teapo has in stock...
                        Especially since the specsheet says something about 3000h Lifetime at best...
                        So they are rather cheapish...
                        And they will fail sooner...
                        If you want better Teapo, you have to get a better series from them...
                        Buttom line:
                        Just don't flame a manufacturer, because they have so much different shit.
                        And always take a look at their product diagrams.
                        And the SC series is the worst series they have...
                          by momaka
                          03-12-2025, 03:42 PM
                          by momaka
                          03-15-2023, 10:17 PM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
