Is UCC KY suitable replacement for UCC KZG in MB?
  • jack black
    • Dec 2010
    • 37
    I'm new here and still learning. My son's PC was acting up so I popped the hood and spotted a bad cap near the CPU (P4 3.4 GHz MSI MB).
    Proud of my diagnostic skills I ordered replacement caps from an online seller advertising "Chemi-Con is the first class capacitor made in Japan.
    KY Series Minimize ESR 6.3V 3300UF Capacitor Grade A monitor, Motherboard or power supplies high-frequency low-impedance electrolytic capacitors". Sounded like the perfect thing for me. I even checked some websites claiming Chemi-Con is good.
    When I got the caps in the mail they looked awfully similar to the one that popped. Sure enough the defective one is UCC KZG and the ones I got are UCC KY. Now, I did dig deeper and looks like KY have higher ESR. I'm not sure if they will work in place of KZG. Should I try?
    Is there something else to protect the caps from the heat of nearby CPU heatsink? The case has plenty of ventilation otherwise.
    Many thanks!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Is UCC KY suitable replacement for UCC KZG in MB?
    Chemicon *does* make good stuff, but KZG is not recommended nor is KZJ.
    KY is NOT a suitable replacement for KZG. You need Rubycon MBZ, Nichicon HM, or Samxon GC. The seller you bought from on here I believe also sells Samxon products.
    • Toasty
      • Jul 2007
      • 4171
      KY = ESR 0.035Ω - 1900mA ripple
      KZG = ESR 0.012Ω - 2800mA ripple
      KZG are known for heat fails. KY is not a proper replacement.
      Best bet for that area of the motherboard with that CPU (onboard heater ) is to use polymer caps. You can halve the capacitance and still be fine.
      If not, these in order from top to bottom with the best specs at the top. All will work in that area:
      Nichicon HZ
      Samxon GA^^
      Nichicon HN
      Rubycon MCZ ^^
      Samxon GC^^
      UCC KZJ**
      Nichicon HM
      Rubycon MBZ^^
      Samxon GD^^
      Panasonic FJ**
      Panasonic FL**
      Sanyo WG**
      ^^ = available from here at badcaps.net
      ** = not available from suppliers in USA
      Stay clear of eBay caps until you ask and get advice here first about a seller.
      Some pics of your board and that area are also appreciated.
      Toast
      veritas odium parit
      • jack black
        • Dec 2010
        • 37
        Many thanks for the replies!
        I'm very tempted to install the KY as the boy is anxious to play his games. Will that fry the MB or CPU?
        I'll look for polymer ones in the meantime. Why polymers are not used routinely? Price? I can actually see a few caps in the MB that look like polymers.
        What polymer specs I should shoot for to replace 3300 uF 6.3V?
        • Toasty
          • Jul 2007
          • 4171
          You are replacing just one? You can't do just one. You need to replace all the same type caps around the CPU. I asked for pics to guide you and pose questions. Please provide.
          Toast
          veritas odium parit
          • bigbeark
            • Jan 2010
            • 661
            I doubt it's going to fry anything, but I'll defer to the experts. You are a lot more likely to fry something with the defective cap(s) in place.
            I assume those 6.3 3300UF are 10mm can size. A lot of the better-rated series may be 12.5mm at 3300uf. A quick check of this site shows you can get Ruby MBZ in the 10mm can size. I would suggest these.
            I had to use Panasonic NHG on my Abit board because I could not find 6.3v 3300uf in 10mm size. (The KY is a much better cap than the NHG). My Abit board works perfectly. but I will be replacing the NHGs when the better caps I ordered arrive.
            • Toasty
              • Jul 2007
              • 4171
              Polymer - Again this depends on which caps we are discussing. Right next to the CPU, you will have height issues. If they are the CPU VRM caps, then I think you can go with 4v poly's there. Perhaps even 2.5v, as the Vcore for the P4 3.2GHz is 1.6v. That gives a 55% buffer to over-voltage, which is well within tolerances.
              You can halve the capacitance, so 1500-1800uF is good.
              Nichicon series' LE, LG, & R5 (FPCAP !!) are all available in 1500uF from mouser.com, and one in 1800uF. I hate to divert you from badcaps, but the polymers here only go up to 820uF and I wouldn't recommend that great a drop in overall capacitance.
              Toast
              veritas odium parit
              • jack black
                • Dec 2010
                • 37
                Toast
                I'm replacing 2. One bulging and one visually OK near by. The other caps near CPU appear to be polymer ones. There are a few more UCC caps in the MB, but smaller and away from CPU.
                • Toasty
                  • Jul 2007
                  • 4171
                  Pictures PLEASE. I said it nice now, again.
                  veritas odium parit
                  • jack black
                    • Dec 2010
                    • 37
                    OK here are the pictures.
                    First the bulging cap (out of focus though) and second a surprize: burned power connection.
                    I put the new caps in and no POST (just like before).
                    Possibilities:
                    1. KY are not good for this job.
                    2. Soldering screw up.
                    3. MB toast.
                    4. CPU toast.
                    5. PS toast.
                    6. All of the above
                    Not sure which but I'm starting to look for replacement mobo, unless someone has better ideas.
                    • Toasty
                      • Jul 2007
                      • 4171
                      No boot because no CPU power from burned connection.
                      In first pic, the 2 caps across at the upper right look "puffy". All KZG caps on the board should be replaced. Even those "far away" from the CPU.
                      The 12v CPU connector and matching PSU connector need to be replaced. Some kind soul here might even send you one off a junk mobo and PSU, if ya ask nice like.
                      The poly's around CPU look to be OSCONs and they're fine. The Panasonics in the foreground are FJ, perhaps? Usually also okay.
                      Toast
                      veritas odium parit
                      • jack black
                        • Dec 2010
                        • 37
                        Good point. Will try another PS tomorrow.
                        • Toasty
                          • Jul 2007
                          • 4171
                          Re: MSI 7143 ver. 2.0 aka: 915P Neo-L
                          So others can find this -
                          Motherboard: MSI 7143 ver. 2.0
                          PCB Version: 2B
                          aka: 915P Neo-L
                          http://www.msi.com/index.php?func=pr...=1&prod_no=216
                          veritas odium parit
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            You need to clean-up/fix the pins on the mobo side too.
                            If you are lucky the plastic will slide up and off making the job easier.
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              HEY!
                              You're getting better at this!
                              - Dr Seuss
                              • jack black
                                • Dec 2010
                                • 37
                                Update:
                                removed the burned plastic from mobo connection, plugged up another PS and the PC works (except for sound card silent now).
                                Tested the old PS with different PC and it doesn't work. I took it apart and no bulging caps inside. Maybe it's the bad contact at the plug?
                                It's possible the UCC KZG caps were not the problem here and the UCC KY caps seem to work OK for a time being at least.
                                Thanks everyone for the expert help and handholding during my first MB repair!
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  It's possible the KZG weren't bad but they are well proven to be a problem cap with high failure rates. Unfortunately they don't always bloat when they go bad.
                                  [Very similar to OST in failure rate and mode.]
                                  - The KY have higher ESR so there will be more noise in the circuit [less Ripple removed] which can lead to the system being erratic and unstable.
                                  - The KY have a lower Ripple rating [which is -sort of- like the watt rating on a resistor]. Caps pass Ripple to ground and that creates heat inside the cap. If the circuit's Ripple is more than the cap is rated for the cap's operation will overheat the cap internally. That will shorten the life of the cap. Sometimes dramatically. Down grading the Ripple from KZG to KY is a huge downgrade and wouldn't expect KY to last very long unless the KZG were over-spec'ed. [I wouldn't count on the KZG being over-spec'ed. KZG are the correct -grade- of cap to use there. They are just unreliable]
                                  10x20mm KZG has 2550 mA Ripple and .013 ohm ESR.
                                  10x20mm KY has 1400 mA Ripple and .046 ohm ESR.
                                  - A HUGE downgrade. [45% less Ripple and over 3x more ESR.]
                                  I would not expect KY to last very long or for the system to be stable.
                                  And now you why it's best to compare new and old cap's specs -before- choosing replacements.
                                  Is okay.
                                  Just about everyone makes that mistake when they are a cap newbie.
                                  - AND IT'S RUNNING AGAIN! - Congrats!
                                  - Dr Seuss
                                  • jack black
                                    • Dec 2010
                                    • 37
                                    The KY is a temporary fix. I will go ahead and test the cap temp with IR thermometer tonight.
                                    I bet the bulging KZG has higher ESR than new KY. But I have no ESR meter and no way to check.
                                    In the meantime I'm looking for polymer caps. The largest I could find in UCC catalog is this: http://parts.digikey.com/1/parts/138...a152mjc0g.html
                                    • yyonline
                                      • Jul 2009
                                      • 692
                                      That's a surface mount capacitor. You want a through-hole capacitor. Assuming 10mm diameter you can use this:
                                      http://search.digikey.com/scripts/Dk...me=565-3229-ND
                                      • MixMasta
                                        • Feb 2006
                                        • 142
                                        Oh yeah you are going to install a SMD cap eh? Good luck with that. Look, since you apparently have already had a problem with finding the right caps, why don't you just buy them from this website or the thecapking website and stop wasting your time and overpaying?
                                        • r2digital
                                          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                          by r2digital
                                          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                          04-18-2024, 03:50 PM
                                        • ezenia
                                          Suitable replacement IC? .PCB - X_BFJSFANRE_RLED_V4
                                          by ezenia
                                          I am not sure where exactly to put this thread, so hopefully this is the best place.
                                          I have a USB fan that has suddenly been unable to increase its speed. It's just stuck on the first speed. This fan has 3 speed settings. Each time you press the power button, the speed of the fan should increase.
                                          The way the button works with each press is: Speed 1 > Speed 2 > Speed 3 > OFF
                                          Speed 2 and 3 don't currently work any more.
                                          I suspect the issue might be with what looks to be some kind of driver IC. It is a 16-pin...
                                          06-20-2023, 05:22 AM
                                        • Benass
                                          Looking for Suitable Relay Replacement.
                                          by Benass
                                          Hello. I have Industrial Washing Machine PCB.
                                          Customer Requested Relays Replacement.
                                          I can't find WJ115F1 relays to buy. Looking for some help to identify possible alternative solutions.
                                          Or any tips, on how to approach this situation....
                                          04-21-2023, 01:51 PM
                                        • fytonv
                                          7 channel NAD receiver,Need help identifying a suitable cap replacement
                                          by fytonv
                                          My 7 channel NAD receiver has audio quality and volume issues on 2 of the channels. Sometimes they work and sometimes they don't. Sometimes they're at about half the dB level of the left channels, and then they cut out entirely. Powering off and on the receiver fixes it for a bit.
                                          Without much experience to really know for certain, they only apparent issue I can see is with these electrolytic capacitors on the power supply. Bulging = bad, correct? I'm looking for replacements but I'm unsure what leeway I have with the temp ratings. Are there any other specifications I need to worry...
                                          09-08-2022, 09:52 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
