Is UCC KY suitable replacement for UCC KZG in MB?
    Re: Is UCC KY suitable replacement for UCC KZG in MB?
    Originally posted by MixMasta View Post
    Oh yeah you are going to install a SMD cap eh? Good luck with that. Look, since you apparently have already had a problem with finding the right caps, why don't you just buy them from this website or the thecapking website and stop wasting your time and overpaying?
    Pardon me if I insulted you by my ignorance. May I call you an asshole?
    BTW, did you actually check the capacity of poly caps available from here?
      buying your parts here serves to help maintain these forums.and as far as an smd cap i have bent the leads down and removed the base to use in a through hole app.
      no need for anyone to be a jerk about this.
        take an overhead pic of the vrm/cpu socket.
        bet there are open spots for polys.fill all the empty spots with sanyo sepc 560@4 availible in the store.this should make up for your ky.
        do this and its a non issue.
        i have seen nichicon hd in a msi board and thought that someone fouled up when loading the machines.till i pulled the hsf and saw all the poly spots filled.remember these are built the cheapest way possible.or with whatever is in stock and will do the job.
          Good luck with your recap jack black!
