can anyone id?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    can anyone id?
    just brought in a board from an emachines p4 box with you guessed it.bad caps.
    these are black with a logo resembling a lower case a with a tail on the left as well as the right.
    no pics yet but will post tomorrow.
  • linuxguru
    • Apr 2005
    • 1564
    Re: can anyone id?
    Photo please? I haven't seen anything like it in my pulls yet. Perhaps intended to be a Hitachi knockoff?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: can anyone id?
      pic
      btw its an imperial-gv board.
      with a gateway part number too.
      • Rainbow
        • Aug 2005
        • 1375
        Re: can anyone id?
        https://www.badcaps.net/forum/showthread.php?t=975
        Looks like I'm going to trash them all and buy Jamicons instead
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: can anyone id?
          hehe Partsnic now on the black list.
          NEXT.......
          • Chris1992
            • Apr 2005
            • 561
            Re: can anyone id?
            bulging at the plug too -- real crap. I have some Daewoo caps in a Trigem Lomita board. Watching carefully....
            The great capacitor showdown!
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: can anyone id?
              thought i had seen that xwindows logo vent before...
              • Jidis
                Need T-Con Advice (Vizio P602ui-B3)
                by Jidis
                I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                09-22-2025, 05:10 PM
              • Thetechdude
                MSI Ventus RTX 4080 16G Broadview schematic needed
                by Thetechdude
                Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                Thanks.
                07-15-2025, 11:15 AM
              • jm1234
                Reolink RLC-410-5MP - buck convertor
                by jm1234
                it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
                Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
                07-14-2025, 04:30 AM
              • mon2
                A2141 Not powering on - case study
                by mon2
                This is a case study on a 'sudden death' A2141 unit brought in for service.
                USB-C meter is @ 5v with ~0A current draw.
                a) Disconnected battery. No power to the machine. Applied the Qianli Tail tester with the USB-C connector. Each USB-C power connector was green with the diode mode of testing. CD321x are not defective as originally thought.
                b) PPBUS_g3h is not shorted but is a low voltage due to the low INPUT voltage of 5v being boosted. On a random power up attempt, PPBUS_g3h was at the expected 12v63 range AND input voltage was observed to be @ 20v for...
                07-10-2025, 10:58 AM
              • djpaesgana
                Hi i need help with a Dell latitude 14 5420 GDF40 LA-K491P Rev 2.0 (A01) 2020-11-16
                by djpaesgana
                Hi i need help with a Dell latitude 14 5420 GDF40 LA-K491P Rev 2.0 (A01) 2020-11-16 , it charges on usb type C i checked the charger with a pd decoy and a electronic charge its ok when, i tested the usb c jack with a tail tester it reads ok (photo incluided), then with a usb charge tester it looks like its trying to negotiate the PD but ressets i openned the laptop and with a thermal camera i noticed 3 ICS getting hot the TPS65994 (UT3) the ISL95860HRTZ (PU601) and the IC SLGC55544CVTR (UI1) this one checking it on the micoscope looks damaged visually (picture incuided) and looking on the Boardview...
                05-14-2025, 08:12 PM
