Here's a Pic of my Asus TR-DLS motherboard with onboard SCSI that is misbehaving. The little caps I believe are 10uf 25v and a grouped near the SCSI chip. I measured their ESR. It was 8(!!), I'll be recapping as the board works great other than this issue.
Little Caps can be BAD
Re: Little Caps can be BAD
Thats certainly possible, just not very common. On the SX280, theres a 22uF @ 25v by the CMOS battery that fails all the time. Strange one to fail, and many times fails without showing any physical signs. It will usually just go open, and make the board exhibit all kinds of odd behavior.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
offtopic question for topcat: do you know if, on a dell 270 sff p4, the 1 rubycon cap sort of in the middle of the mobo leaking crud can cause the onboard lan to not work?
thanks.Comment
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: Little Caps can be BAD - UPDATE
So I replaced those little stinkers. When I got them off the board they all measured around 4
ESR value. Replaced them with Nichicon PY 10uf 25v. There were 6 scattered among the SCSI chips. A real swine to remove and clean out the holes. Made extensive use of the "add fresh solder" to remove the caps and also to melt the solder in the hole for the pin-method. All went according to plan. I noted that the previous owner had set the onboard scsi jumper to disabled. Changed that and attempted to boot from the harddrive. Realized that the HDD had Adaptec drivers loaded and the on-board is LSI, so that didn't work. Did a fresh install of Ubuntu, crossed my fingers, and voila! Success, boots and runs fine.
The board still needs a recap though. It's responsive, plays video etc, but I got it to freeze by loading a CD into the tray while a youtube video was playing. Locked up the video, lost the mouse. Had to restart. A little later lost the mouse again. After that I got a lock when I tried to change the Desktop background. This is over the course of three evenings.
I figure server boards should just automatically be recapped, the caps are just "tired".
I'll start with the 6 Nichicon HD(M) 1220uf 16V from 2002.Comment
36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....Comment
Measure the cap voltage then check the voltage against the required voltages on the network chip datasheet. Looks to me that the RC82540EM takes a lot of 1.5v and a little of 2.5v and 3.3v. Without the 2.5v and 3.3v it can't communicate, and without the 1.5v it can't function.Comment
i think the HD is ok... it is HM and HN that are stinkers.sigpic
(Insert witty quote here)Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
