Little Caps can be BAD
  • bigbeark
    • Jan 2010
    • 661
    Here's a Pic of my Asus TR-DLS motherboard with onboard SCSI that is misbehaving. The little caps I believe are 10uf 25v and a grouped near the SCSI chip. I measured their ESR. It was 8(!!), I'll be recapping as the board works great other than this issue.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Little Caps can be BAD
    Thats certainly possible, just not very common. On the SX280, theres a 22uF @ 25v by the CMOS battery that fails all the time. Strange one to fail, and many times fails without showing any physical signs. It will usually just go open, and make the board exhibit all kinds of odd behavior.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      do you know what circuit this cap is part of?
      offtopic question for topcat: do you know if, on a dell 270 sff p4, the 1 rubycon cap sort of in the middle of the mobo leaking crud can cause the onboard lan to not work?
      thanks.
      • bigbeark
        • Jan 2010
        • 661
        Since these caps are right beside the 68-pin onboard SCSI connector, I am assuming they are in this circuit.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          I would think the problem would be more serious than the onboard ethernet being unusable.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • bigbeark
            • Jan 2010
            • 661
            Re: Little Caps can be BAD - UPDATE
            So I replaced those little stinkers. When I got them off the board they all measured around 4
            ESR value. Replaced them with Nichicon PY 10uf 25v. There were 6 scattered among the SCSI chips. A real swine to remove and clean out the holes. Made extensive use of the "add fresh solder" to remove the caps and also to melt the solder in the hole for the pin-method. All went according to plan. I noted that the previous owner had set the onboard scsi jumper to disabled. Changed that and attempted to boot from the harddrive. Realized that the HDD had Adaptec drivers loaded and the on-board is LSI, so that didn't work. Did a fresh install of Ubuntu, crossed my fingers, and voila! Success, boots and runs fine.
            The board still needs a recap though. It's responsive, plays video etc, but I got it to freeze by loading a CD into the tray while a youtube video was playing. Locked up the video, lost the mouse. Had to restart. A little later lost the mouse again. After that I got a lock when I tried to change the Desktop background. This is over the course of three evenings.
            I figure server boards should just automatically be recapped, the caps are just "tired".
            I'll start with the 6 Nichicon HD(M) 1220uf 16V from 2002.
            • smason
              • 1652
              Server boards? Server and Asus shouldn't be used in the same sentence.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                are nichicon hd supposed to not have colorful sleeving? or if mine dont does that mean they are fakes?
                • severach
                  • Aug 2007
                  • 1055
                  Most boards won't post when C259 on the GX270 SFF board goes bad. Apparently the heat from the nearby MOSFET is "to die for."
                  Measure the cap voltage then check the voltage against the required voltages on the network chip datasheet. Looks to me that the RC82540EM takes a lot of 1.5v and a little of 2.5v and 3.3v. Without the 2.5v and 3.3v it can't communicate, and without the 1.5v it can't function.
                  sig files are for morons
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    i think the HD is ok... it is HM and HN that are stinkers.
                    sigpic
                    (Insert witty quote here)
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      It is c259! Well it still seems to be working. And the lan still works too. Just need to keep an eye on it!
                      • Rulycat
                        • Apr 2010
                        • 724
                        • United Kingdom
                        I've never seen problems with caps on cool-running devices such as the super cheap network cards where they use the ridiculously cheap generic brands, not sure why they last so long.
                        • Pyr0Beast
                          • Feb 2009
                          • 406
                          They don't. Just that caps on mobo have to take the burden then.
                          They are also quite tolerant, unlike other systems.
                            by momaka
                            03-12-2025, 03:42 PM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • captain150
                            by captain150
                            03-16-2025, 07:34 PM
                          • Foetuss
                            Gigabyte GA-6OXT :: caps question
                            by Foetuss
                            Good evening
                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                            But I was also suprised about the bigger boys, which are 330µF 25V.
                            Could it be they used 25V caps because they were cheaper / available at that time?...
                            02-11-2025, 12:22 PM
