I'm looking to know what the blue component that says UEI 44n on it, is.. it looks to be a capacitor but when I measure it in circuit it measures 16pF one way and 28pF the other way. Was expecting 44nF. I've looked at capacitor marking and the marking is not conforming to standards. The circuit is from 1600w 240V to 110V AC to AC voltage converter that uses a triac and a diac to make the conversion.
What is this component, looks like a cap
by saghi88Hello everyone,
I am looking for the part number of this component so I can order it. I cannot identify it based on the marking code; I think it is an LDO IC. Can anyone determine the manufacturer's part number from the marking code?
I have uploaded images showing the dimensions and the marking code of the IC. I believe the package is a DFN-8 with dimensions of 3 mm × 3 mm × 0.9 mm.
Thank you in advance for your support3 Photos -
by tomy78need this IC information. marking FMN 930
by dutchgauchoDear BadCaps colleagues,
I'm working on a HP Omen 16-WF0894ND. Won't turn on. Battery is charging and 3 and 5V rails are present.
However, I located PU1801 that's only outputting 0.37v as soon as the power button is pressed. Weird voltage imo, although there's no short after the coil. Chip aint getting hot either. Since no diagram is available, I can't really determine what this rail is for, but I assume it might be a PCH PWR rail. Please help me to identify:
Chip marking eHFFH
Board model: LA-M783P
Please also see pictures attached. -
I'm trying to identify a small SOT-package IC marked "XA2LD" located near the 5V_FS rail on a logic board. The silkscreen shows it as U26/U25, and it's adjacent to components labeled R415, C232, L28, etc.
Here’s what I know so far:- The IC marking is XA2LD (possibly custom or abbreviated).
- It’s likely involved in power switching or regulation (possibly a load switch or LDO).
- The package appears to be SOT-23-5 or similar.
by tommy97Hi,
i'm looking for a component from the picture with marking "JWCXJ 2HB1N" it is just after Ethernet IC.... - Loading...
