Macbook Pro A1706 820-00239-09 schematich and brd
  • krichtot
    • Oct 2021
    • 20
    • belgium
    here the schematich if anyone needs had to buy it so i share
  • Willeh
    • Jul 2025
    thank you, krichot, my next project repair is this mb. i owe you a beer! o7
    • Chivo77
      • Aug 2024
      • 15
      • Argentina
      thank you!
      • Danielreinaa
        HELP need password bios Macbook A1706
        by Danielreinaa
        Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
        Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
        Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
        gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
        Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
        09-07-2024, 03:47 PM
      • capon5153
        Macbook A1706 works perfectly but no data on USB C
        by capon5153
        hello,
        so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
        i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
        06-22-2025, 09:42 AM
      • B2L_Repairs
        Macbook A1706 touchpad and keyboard not working. Please help
        by B2L_Repairs
        Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
        10-09-2023, 04:56 AM
      • obelix24
        A1706 - Macbook pro - one USB-C port only 20V 0A
        by obelix24
        I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
        I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
        There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
        There were some broken pads under CD3215 but i've recreated them.
        What should be...
        05-22-2024, 08:04 AM
      • johnbeton
        Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
        by johnbeton
        I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
        Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
        This is what I measure so far:
        Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
        PPBUS_G3H = 0,79v
        PPBUS_HS_CPU = 0,79v
        PPBUS_HS_OTH5V = 0,79v
        PPBUS_HS_OTH3V3...
        05-21-2024, 02:06 PM
