Dell Inspiron 17R 7720 "Your Battery is Temporarily Disabled", Battery LED Flashing
  • Ali101
    • Jul 2017
    • 152
    • Taiwan
    Hello BADCAPS Experts,
    My Inspiron 17R 7720 SE laptop can't power on with battery but only AC adapter can turn it on, if i try to charge battery with power off laptop than it flashing 4 orange flashes, then white flash, then repeat, if i open laptop connected with AC adapter with battery it showing a start-up message "Your battery is temporarily disabled. Please turn off the unit and try again when the unit is back to operational temperature" & keep flashing 4 orange flashes, then white flash, then repeat.
    When I run the F2 Setup, under battery health I get the same message above "Your battery is temporarily disabled. Please turn off the unit and try again when the unit is back to operational temperature"
    The computer operates normally with the AC adapter, shows the battery at 100% charged, but shuts off immediately when the AC adapter is disconnected.
    Now i google my issue & found it may be issue with my battery or AC adapter so i bought one by one new AC adapter & battery but no success, still same error as above and it only can power on with AC adapter, hence I wast money to bought new AC adapter & battery, now after all this i been suggest on Dell website that issue is with laptop mother board, and need to replace/repair motherboard Charging IC or some other part,
    Now i am wondering how i check whether issue is in motherboard Charging IC or some other part, i am ready to work on my laptop motherboard, any suggestion will be highly appreciated, since i am newbie and need expert help to check mother board on component level,
    Thanks.
  • Ali101
    • Jul 2017
    • 152
    • Taiwan
    Re: Dell Inspiron 17R 7720 "Your Battery is Temporarily Disabled", Battery LED Flashi
    **Bump**
    Hope some one will help me,
    Thanks.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3553
      • slovakia
      "try again when the unit is back to operational temperature"
      i think its a battery temp sensor
      • Ali101
        • Jul 2017
        • 152
        • Taiwan
        Dear ktmmotocross,
        Many thanks for your reply, appreciated,
        any idea where is battery temp sensor located & how to check whether its got bad?
        • Ali101
          • Jul 2017
          • 152
          • Taiwan
          Enclosed Motherboard Schematics which found from below link
          http://www.s-manuals.com/notebook/dell_inspiron_7720
          May be it help,
          • Ali101
            • Jul 2017
            • 152
            • Taiwan
            Bump.. need some one help, pls help me sort-out my issue, any help will be highly appreciated
            • atsio
              • Oct 2013
              • 819
              • Greece
              Have you tried to reset bios by removing rtc battery?
              • Ali101
                • Jul 2017
                • 152
                • Taiwan
                yes i did, included upgrade & downgrade bios as well, nothing working, so i am 99.9% sure this issue is from hardware but not software,
                any suggestion will be appreciated,
                Thanks.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  check psid circuit at page 47
                  • Ali101
                    • Jul 2017
                    • 152
                    • Taiwan
                    @mcplslg123 thanks for help but on page 47 which thing i need to check with which component, sorry noobi question,
                    BTW how about Page 55 [Charger (BQ24765RUVR)] since i have doubt on charging IC BQ24707ARGRR (PU8) but i don't know how to check whether this IC is good or bad,
                    any help will be appreciated,
                    Thanks.
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      measure voltages on pins of BQ24765RUVR.
                      • kiraro
                        • Jan 2016
                        • 177
                        • North NY
                        Change "EC45""EC46""EC47",change also "EC58""EC59""EC60",Generaly change caps related to "+VCHGR",one or many of thoses caps is the main cause of disabling battery temporary, that's why you see the msg ,thoses caps are the main causes of this msg and also for another problem ,when you see battery charging but the % still the same ,thoses caps also the main causes,change it and it will work ,I have the same pb with dell 3521 same msg changing those caps solve my prob ,also lenovo g580 who still charging but percentage not increase change thoses caps solve my prob also,I hope that help you friends.give us a feedback friend.thank you .
                        • Ali101
                          • Jul 2017
                          • 152
                          • Taiwan
                          Thanks for head-up kiraro, appreciated your help, lets try with your suggestion & see if it working or not,
                          EC47 & EC59 looks same (0.1U/25V_6)
                          EC58 & EC 46 looks same (1000P/50V_4)
                          EC60 & EC 45 looks same (2200P/50V_4)
                          any idea where to find & buy these caps? any web link or online store? eBay/aliexpress or any else where?,
                          Thanks.
                          • Ali101
                            • Jul 2017
                            • 152
                            • Taiwan
                            Enclosed Motherboard image with EC45""EC46""EC47", "EC58""EC59""EC60" marked with yellow color, just for reference in case it need, hope it will help to advise where i can buy them with what size,
                            Thanks.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Thanks.
                              Replace these caps only if it shows short, else it doesnt make sense. You can get them in plenty from any laptop scrap mb.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                most likely you have problem in battery output line. Check those lines carefully for any shorted caps or mosfet.(two similar looking pins at the extremes of battery connector-one side is gnd and the other side is output +12v)
                                • Ali101
                                  • Jul 2017
                                  • 152
                                  • Taiwan
                                  sorry for noobi question but how check this, can you advise which section & pin is battery output line?
                                  Thanks.
                                  • dspok
                                    • Jan 2014
                                    • 553
                                    • Nepal
                                    Did you change pr3, pr3 and pr6, you can put 33ohm or 22ohm resistor. Just try.
                                      • 30919
                                      it could be a fault in the battery pack, it does contain a microcontroller and several temp sensors taped to the cells.
                                      • dycc
                                        Vision
                                        • Nov 2011
                                        • 624
                                        • Côte d'Ivoire
                                        Cn4 :pin5 (psid) voltage ???????????? Should be 3.3v normally
                                        jbat1: Smbdat0 , smbclk0 voltages ?????????????? Should be 3.3v normally
                                        jbat1: Pbat_pres# should be low
                                        CHECK WITH AND WITHOUT BATTERY CONNECTED (ADAPTER CONNECTED)
                                        • HTR-Informatique
                                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                          by HTR-Informatique
                                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                          I also changed the screen because the PC fell and the screen was broken.
                                          I changed the battery with a new and original battery.
                                          I also had corrosion/oxidation on the...
                                          02-09-2025, 06:51 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                                          The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                                          configurable for operating as either a Hybrid Power Boost (HPB)
                                          charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                                          4-cell batteries. Both configurations allow the battery to work with
                                          the adapter together to supply the system load when it exceeds
                                          the adapter capability, referred to as system Turbo mode. HPB
                                          charger configuration reverse-boosts battery energy to the system
                                          bus to help the adapter provide the system power in Turbo mode.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • huzo
                                          HP ELITE X2 1013 G3 weird battery issue
                                          by huzo
                                          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                          01-31-2025, 12:09 AM
                                        • trepachka
                                          iPad Air A1475 Boot loops after replacing battery
                                          by trepachka
                                          This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                                          The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                                          I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                                          11-08-2024, 03:17 PM
