Capacitor
  • djrock
    • Feb 2007
    • 38
    Capacitor
    Hello, I am replacing capacitors in a old food mixer. Is it ok to replace a 0.15uf cap with a 0.22uf cap?
    Thankyou
    djrock
  • starfury1
    • May 2006
    • 1256
    Re: Capacitor
    thing with that is its probably a mains operated device Meaning you must use approved caps for this
    Not knowing exactly what the caps being use for (no idea whats in a food mixer)
    it would probably be ok but it must be the same type or an equivalent replacement type
    Post a photo of the guts and its location and I am sure someone will be able to tell you
    Whats that you say ?,
    you want to how to post photos here
    check this thread of Willawake's (forum mod) on how to do it.
    https://www.badcaps.net/forum/showthread.php?t=1868
    Start Legal Rant
    Mains Voltages are potentially Deadly so all disclaimers apply here "You Do At Your Own Risk
    (be advised that depending on were you are it may be illegal for you to do this work)
    End Legal Rant
    Just covering mine and the forums rear end here.
    Welcome
    Cheers
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • djrock
      • Feb 2007
      • 38
      Re: Capacitor
      Hello, I don't have a photo of the guts of it but i have the spec and a similar photo of them.
      This is the spec taken from the bad caps.
      0.15uf 250v 3.8Mhz
      0.047uf 40/085/56 PME 271M547
      Both I think appeared to be made by Rifa and are like the ones in this Link.
      The ones I got to replace them are like these http://www.maplin.co.uk/images/300/bx84f_bx70m.jpg.
      I told the guy the voltage, the cap value, what it was needed for and thats the caps he gave me.
      djrock
      • starfury1
        • May 2006
        • 1256
        Re: Capacitor
        I wouldn't be the best person to answer this one so you really might want to wait
        for a better reply on this.
        One question you should ask yourself is "WHY" did they fail Why do you need to replace them
        There could be another failure just waiting to bite you
        if you look at you "link" photo you will see lots stamps on these caps the clear ones
        These are Agency safety approval stamps for capacitors used with Electrical Mains supply
        So you need to replace with this type of capacitor that is type approved.
        The maplin link, these look like they are a high voltage polyester, more commonly know as greencaps (or orange drops I think from memory)
        (going by the photos)
        These would as far as I am aware be "Unsuitable" for this application.
        The caps you need to get are know as either X or Y caps depending on there location inside that device.
        OUTLINE OF CAPACITOR CLASS RATINGS
        Capacitor are classified by the IEC into two
        categories (these designations are used by most
        European countries).
        Class Y: Capacitors used in applications where
        damage to the capacitor may involve danger of
        electrical shock.
        Class X: Capacitors used in applications where
        damage to the capacitor will not lead to the danger
        of electrical shock.
        From this PDF HERE
        I personally would "NOT" use those caps you got
        unless they are specifically for X or Y Class use and I very much doubt they are.
        Going by your links
        EDIT:
        I notice you told the guy what they were for so you need to check they are type approved
        (caps can come in different packages)
        These are issues of SAFETY to "human life & property" so you MUST used the correct type of caps
        To be brutally honest
        these type of repairs are best left to Properly Qualified Trained Technicians.
        who can check for other possible fault conditions and are equipped to do so.
        I can understand why people what to repair things them selfs but sometimes it really best to leave it to the professionals
        HTH
        Cheers
        • starfury1
          • May 2006
          • 1256
          Re: Capacitor
          just on PME 271
          Multi-layer metallized paper. Encapsulated
          and impregnated in self-extinguishing material
          meeting the requirements of UL 94V-0.
          Here is a PDF Link
          it appears to be Class X2 from the pdf
          not sure on the 0.15UF 250V thought
          HTH
          Cheers
          • djrock
            • Feb 2007
            • 38
            Re: Capacitor
            Hello, The mixer (Kenwood Chef A901P) does still work but it's stuck on maximum speed and I have read that the traic can do this.
            I think due to the triac failing has caused the capacitors to fail.
            The caps I have been given have no safety markings, which as you said can't be a good thing. Would these cap be ok Link?
            They are class x2 and approved but will it matter that they are 275vac not 250vac?
            From what I can see the mixer does not appear to be very complicated electrical wise (2 caps, 2 resistors and a triac)
            so I can see one reason why people still want them because they don't heavily rely on electrical components.
            Thankyou
            djrock
            • kikkoman
              • Jul 2007
              • 691
              Re: Capacitor
              looks good.
              a (slightly) higher voltage rating is no problem here. WIMA is an established brand, too.
              "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
              • djrock
                • Feb 2007
                • 38
                Re: Capacitor
                Originally posted by kikkoman
                looks good.
                What about the rating? I can't get a 0.15uf so is it ok to fit a 0.22uf or a 0.1uf? Will the capacitance tolerance matter since I think the originals were 10% but the Wima's are 20%?
                Thankyou
                djrock
                • gdement
                  • Jan 2007
                  • 690
                  Re: Capacitor
                  Thankyou
                  djrock
                  I don't know anything about this type of thing. But if the original cap was 10% tolerance, that makes me think the spec must have been important. Otherwise I'd expect them to use a more common 20% part.
                  • starfury1
                    • May 2006
                    • 1256
                    Re: Capacitor
                    thanks for the info...as I said, mostly you probably could use 0.22uf
                    but not totally sure of how its put together
                    so strictly speaking I don't know on the 0.15 uf
                    I did find a post here on that model
                    this seems to be a common type failure
                    EDIT did find mention 41 years????...well that would explain failure
                    2 resistors
                    larger one on left of Triac (near) 0.47uf (47nf) is said to be 56 Ohms
                    The other on the right is said to be 220 Ohm
                    heres the original post and yeah seem like you need to check all the components
                    for failure would be a good idea..mention of replacing brush too
                    http://www.howtomendit.com/answers.php?id=68470
                    another thread says caps are for suppression ..makes sense
                    http://www.mendmy.com/answers.php?id=111979
                    this post that there are no answer to might throw a bit of confusion in to the mix apparently different controllers
                    http://www.mendmy.com/answers.php?id=110223
                    seems to be a bit on googling around but unfortunately no photos could I find
                    anyway Hope this helps
                    cheers
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      Re: Capacitor
                      Those caps are probably for reducing the dT/dV or in plain words to slow down the transient produced by the off or on switching (assuming the capacitor & resistor is in parallel with the triac).
                      A relay would arc and a triac would go short if voltage rises too fast. This kind of circuit is commonly called a snubber or RC snubber.
                      The fast rule is 1Ohm/V and 0,1uF/A. It is recommended to use some UL or similar approved metal paper capacitor either from X1, X2 or Y1, Y2 class.
                      The safety class is determined if there is an fuse before the capacitor and if it does connect to ground / safety ground or only from neutral to hot.
                      For an snubber i would say an X1 or x2 should be sufficient, as long as there is an fuse anywhere.
                      Generally, the value of the capacitor is not critical, but if the capacitor is increased to far, there is the possibility that the motor coil and the capacitor will act like an oscillating circuit, which is not particular good.
                      But if you can`t manage to get some 0.15uF capacitors or 150nF ones i would try the 0.22uF ones.
                      • djrock
                        • Feb 2007
                        • 38
                        Re: Capacitor
                        Hello, Starfury1 The mixer could be about 25 years old. I have read most of the posts you have linked to. That's when I discovered it was a common fault that could be fix very easily.
                        I will be replacing the two resistors as well. The 220ohm is way out of spec and the 56ohm is fine but I am going to replace it anyway.
                        I was thinking about changing the brushes as well.
                        There's nothing to worry about the different controllers. Since you can get a new controller on a pcb. I think it could be for a newer motor.
                        I will try and take a picture and post it sometime tomorrow, which might help to identify what the caps are being used for and if the tolerance value is important.
                        Thankyou
                        djrock
                        • starfury1
                          • May 2006
                          • 1256
                          Re: Capacitor
                          No worries
                          Age was probably its demise, so that possibly rules out a secondary fault which was more my concern.
                          (although suppose its still possible the triac is gone)
                          Since its using a triac, which is probably chopping up the mains sine for speed control
                          EDIT seems one maybe for timing trigger point but not sure
                          My guess is that the caps are purely there to shut up EMI/RF crap
                          true thought, values are chosen for specific reasons and thats why you shouldn't stray from them unless you know what the effect of this will be
                          I dont fix these things
                          and triac theory is way rusty with me
                          (apart from the fact its more or less a bilateral switch that you can set the voltage trip point on at various levels in the waveform)
                          I dont know the circuit either, it seems to be crudely simple and that perhaps account for its reliability.
                          Looking at a PDF on Triac Control
                          that cap maybe being use to set the "trigger point"
                          (this could possibly explain the use of closer tolerance capacitors)
                          If so, then by using a larger cap you will change the trigger point
                          (Also note the use of a DIAC with the TRIAC)
                          http://www.play-hookey.com/semicondu...iac_triac.html
                          http://www.hobbyprojects.com/thyrist..._and_diac.html
                          No mention of a Diac being used in that controller?
                          (have to look into this ...like I said I have forgotten....these you do tend to find used with triacs.
                          They are open circuit till their trigger voltage is hit then go short circuit
                          using the term "'open short" loosely here.
                          (high resistance, low resistance would be better)
                          there are some pdf's and other interesting stuff of this link
                          http://www.educypedia.be/electronics...ronicsdiac.htm
                          if you can just draw a diagram of what connects to what for reference.
                          sometimes with photos its hard to see what connect to what if its skyhooked
                          but either would be of help to me as I don't know.
                          I did a bit of googling but didn't find anyone had posted a photo or a diagram
                          At this point I'll leave it
                          The links should help understand better how the thing works.
                          but I know it doesn't really answer your questions
                          Cheers
                          I edited out this bit but will leave it for my reference
                          if the 1n5f (0.15uf) is purely for EMI I see no reason not to use a 2n2nf (0.22uf)
                          10% jobs my have been all they could get at the time, Dont know
                          • starfury1
                            • May 2006
                            • 1256
                            Re: Capacitor
                            This might explain it a bit better
                            http://www.allaboutcircuits.com/vol_3/chpt_7/6.html
                            Firefox decided to play silly buggers and went on a go slow for some reason.
                            cheers
                            • gonzo0815
                              • Feb 2006
                              • 1600
                              Re: Capacitor
                              I don´t think that the caps are there for setting the trigger point, but sure w/o circuit it is all guesswork.
                              Trigger point is either set with a resistor voltage divider or an diac or with both.
                              • starfury1
                                • May 2006
                                • 1256
                                Re: Capacitor
                                in one of the forum links its stated for EMI surpression for both of them caps that is
                                (but No mention of diac use)
                                from the ST doc PDF link
                                Triggering with synchronization on the TRIAC voltage
                                The triggering circuit with synchronization across the TRIAC (See Figure 1 and Figure 2)
                                turns on the component at an angle β after the current drops to zero, such that
                                β = ω · Tr.
                                Time Tr is defined by the time constant (P + Rt)C.
                                ω = 2 · π · f with f = mains frequency.
                                Figure 1. Typical Circuit: synchronization across the TRIAC
                                Also if you look at the last link (separate post above) it shows a pot and cap and says;
                                "A simple lamp dimmer circuit is shown here, complete with the phase-shifting resistor-capacitor network necessary for after-peak firing."
                                thats why I thought possibly for triggering
                                true, no idea really and circuit is not known
                                I Have forgotten most everything with triacs
                                esp with regard to how you trigger them.
                                its guess work based on links, as you said.
                                Thanks for the reply Gonzo, every bit helps
                                Cheers
                                • gonzo0815
                                  • Feb 2006
                                  • 1600
                                  Re: Capacitor
                                  Sure in this circuit the capacitor is a snubber, to protect the Triac against high voltage spikes from the load switching. From another point of view it sure does reduce EMI too, but i assume that it is not necessarily needed for this task.
                                  It does nothing else there and the circuit would work even without the capacitor.
                                  But the triac may fail earlier, due to high voltage spikes and too fas voltage rise.
                                  But i referred to the circuit in question, e.g. the original circuit from the particular mixer.
                                  I certainly know, how a simple triac circuit should look like, but how should we know that it is the same circuit in the mixer?
                                  There are plenty of circuits and far more then one way how an triac circuit could be designed.
                                  • severach
                                    • Aug 2007
                                    • 1055
                                    Re: Capacitor
                                    Any chance you could fix that with Harbor Freight Item # 43060 Router Speed Control?
                                    http://harborfreight.com/
                                    I tried fixing a variable speed control once and I must not have got all the bad parts or the right replacement parts. It worked but lost most of its sensitivity across the dial range. It eventually burned out again. I just shorted out the internal components and ran the motor from one of these. Far cheaper than the replacement parts and super easy to replace.
                                    sig files are for morons
                                    • djrock
                                      • Feb 2007
                                      • 38
                                      Re: Capacitor
                                      Hello, Sorry I forgot to mention I am fitting a new triac since testing it, it appears that has been taken out too. The guy I got the wrong caps off did say the traic could take out the caps. Thanks for the links I will have a good read of them.
                                      Here are some photos of the circuit. I thought also I would draw a circuit diagram.
                                      Thankyou
                                      djrock
                                      • severach
                                        • Aug 2007
                                        • 1055
                                        Re: Capacitor
                                        Your schematic is missing the blue wire from the motor to the 0.15uf cap. I was having trouble tracing power through the motor. The 3rd stripe on the 56r resistor looks brown to me which would make it a 560ohm resistor. The lower junction of resistor 56r and 0.47uf cap looks like it goes to more than nothing. I see a large contact down near the cooling blades that might be connected and has no obvious purpose and its height may be set by the spring loaded adjustment screws. The other contact is labeled "motor centre."
                                        That tells me there's a speed control somewhere. I see the black dial but I don't see how it connects.
                                        That motor has 6 contacts which seems like a lot to me. Seems like there might be something important besides a motor beyond that bundle of 4 wires.
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • jimmy2022
                                          Russell Hobbs food mixer
                                          by jimmy2022
                                          hello.
                                          the chip has completely blown and i am unable to see the number on the chip. any idea what chip this is?...
                                          04-20-2025, 06:48 AM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          How can I test non-polarized capacitor?
                                          by chth96
                                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                          06-02-2024, 07:31 PM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
