Original Xbox Replacement Caps
  • NeMesiS34
    • Sep 2015
    • 37
    I've been modding Original Xbox consoles for over ten years.
    As these things age I find myself becoming more of a refurbisher.
    The most common problem is the clock capacitor which tends to leak.
    This is illustrated in the first 2 attached pictures below.
    The faulty capacitor is a SuperStor 1F 2.5v SuperCap (console v1.0 to 1.5)
    It wasnt until the final Original Xbox version 1.6 that the cap was replaced,
    with a Nichicon 1F 2.5v Gold SuperCap, as seen in the 3rd picture.
    I came across and have been looking for replacement caps at "mouser.com"
    I've noticed that smaller caps like 22uf 25v have a life span of around 2000hrs
    Medium sized have life span of around 5 to 7k hrs and 10k for the largest (psu) caps.
    I'd like these console to last another decade, I'm considering replacing most,
    if not all caps on the motherboards and power supply units.
    The 4th picture is a Xbox version 1.0 motherboard (with cpu fan)
    13x 25v 22uf Nippon SMG
    6x 25v 100uf Nichicon VR
    3x 16v 1500uf Nichicon PW
    2*x 10v 3300uf Nichicon PW
    1x 10v 680uf Nichicon PW
    5x 6.3v 1500uf Nippon KZE (6th picture)
    1x 1F 2.5v SuperStor
    The 5th picture is a Xbox version 1.1 motherboard (without cpu fan)
    1*x 10v 3300uf Nichicon PW
    5x 6.3v 1500uf Unidentified Solid Cap (7th picture)
    My Questions:
    I have little experience and limited knowledge in regards to caps.
    1) Would i need to replace solid caps with other solid caps or can I use wet caps?
    2a) Would it be better to use caps with a higher ripple current and lower leakage current?
    2b) Would it be better to use Nichicon HD series over PW series?
    3a) Any advantage in using higher voltage caps whilst maintaining capacitance?
    3b) For example 22uf 50v over 22uf 25v or 1500uf 10v over 1500uf 6.3v, etc...
    4) What would be a better clock cap alternative to the SuperStor 1F 2.5v?
    Thanks in advance, Nemo
    • 31029
    Re: Original Xbox Replacement Caps
    you dont need the supercap, under 1.6 just leave it out.
    on a 1.6 you need something so stuff a 100uf electrolytic there or the console wont start.
    there is no cpu fan btw, that's the g-force3 gpu your refering to.
    the cpu vrm caps - the 1500uf 6.3v must be *very* low esr or use poly's
    for the rest, just use panasonic FR
    finally, your unidentified caps are not solid, they are just electrolytics.
    the symbol on them is Nichicon - they are HD series.
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      I'm not sure if the Aerogel clock capacitor is actually defective. These capacitors are 1F, 2.5V, and IIRC, the clock capacitor is ran right at its maximum voltage (2.5V is the voltage the clock circuit runs at, if memory serves), which is why both the Aerogel capacitor and even sometimes the Nichicon UC capacitor (which bulges now and then because of that) has a limited life. Though, since the Aerogel capacitor almost always leaks from the bottom, it may be sealed very poorly. For what it's worth, I would just desolder the clock capacitor (from versions 1.0-1.5) and forget about it. It isn't very useful anyway - if you remove AC power, it only keeps the time for what, a few hours? Those ADDA hyprobearing fans that come with version 1.0 of the console tend to seize prematurely as well.
      There are also a bunch of small SMD electrolytics as you can see - one is 47uF 16V, six are 10uF 16V. Nichicon 85C (WX series very likely), Chemi-con 85C (MV series - can be identified by the shield), and Suncon (Sanyo) 85C (CBS series, from what I can tell) SMD electrolytics are all used interchangeably there. The 3300uF 6.3V Nichicon HMs were also known to go bad in versions 1.2-1.6 (2002-2005 datecodes) of the console, in the VRM input and output. I believe there is also one more 680uF 16V HM (again 2002-2004 datecodes) used in version 1.2-1.5 (it's used interchangeably with a Panasonic FJ of the same value). Never seen it actually go bad, but it wouldn't hurt to replace all the electrolytics, as you said.
        • 31029
        these "supercaps" are a joke, i had the datasheet for them.
        they are rated for something like 500 charge/discharge cycles.
        after that - it's anybody's guess what they do - other than piss themselves on the board above some fets.
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          I attached the datasheet for both Nichicon UC and Aerogel Powerstor B series.
          Worst of all, both capacitors are only rated for 1,000 hours @ 70*C, both load life and shelf life.
          • NeMesiS34
            • Sep 2015
            • 37
            Thanks for all the replies,
            100uf 25v cap?
            Noted...
            Originally posted by Wester547
            For what it's worth, I would just desolder the clock capacitor (from versions 1.0-1.5) and forget about it. It isn't very useful anyway.
            I agree with the both of you to remove the clock cap
            Yea so I've noticed, they can be surprising loud.
            I've been trying to find a replacement, I found similiar heat sink fans.
            But there only 40x40mm where 40x50mm is needed to be mounted properly.
            Maybe i'll just slide in a standard 40x40x10mm fan and secure somehow.
            Cheers, I forgot to mention them...
            The 3300uF 6.3V Nichicon HMs were also known to go bad in versions 1.2-1.6 (2002-2005 datecodes) of the console, in the VRM input and output. I believe there is also one more 680uF 16V HM (again 2002-2004 datecodes) used in version 1.2-1.5 (it's used interchangeably with a Panasonic FJ of the samevalue). Never seen it actually go bad, but it wouldn't hurt to replace all the electrolytics, as you said.
            Thats right, versions 1.2-1.5 have those HM series caps.
            Questions:
            Do you guys prefer Panasonic over Nichicon?
            Picture 6 (1.0mobo) you can see the two black caps to the right (3300uf 10v),
            Picture 7 (1.1mobo) there is only one but the cap is still allocated on the board,
            Could this be filled in? Would there be any benefit?
            Cheers, Nemo
              • 31029
              pana vs nichi is like atari vs comodore - we could start a war over it!
              why dont you get a passive gpu sink from a dead xbox higher than 1.0 ?
              • NeMesiS34
                • Sep 2015
                • 37
                LoL... no worries
                I have 5x 1.0 consoles atm
                and 2x dead 1.6 consoles
                I would still be shy by 3 heatsinks
                • NeMesiS34
                  • Sep 2015
                  • 37
                  Versions 1.0 to 1.1
                  Mobo Caps:
                  13x 25v 22uf Nichicon VR
                  5x 6.3v 1500uf Nichicon HD (Solid/Wet)
                  1x 1F 2.5v SuperStor!
                  SMD Caps:
                  1x 16v 47uf
                  6x 16v 10uf
                  (Delta) PSU Caps:
                  1x 50v 10uf Ltec (Gold)
                  1x 25v 47uf Ltec (Blue/Green)
                  2x 25v 100uf Nippon KY
                  2x 200v 330uf Taicon?
                  3x 10v 2200uf Nippon KY
                  1x 16v 1000uf Nippon KY
                  RAM:
                  Samsung
                  K4D263238M-QC50
                  Versions 1.2 to 1.5
                  Mobo Caps:
                  7x 25v 100uf Nichicon VR
                  3x 6.3v 3300uf Nichicon HM
                  2x 10v 3300uf Nichicon PW
                  1x 16v 680uf Nichicon PW
                  3x 6.3v 1500uf Nichicon HD (Solid)
                  SMD Caps:
                  1x 16v 47uf
                  5x 16v 10uf
                  (Delta) PSU Caps:
                  1x 400v 150uf Rubycon USR
                  3x 50v 0.22uf Taicon?
                  2x 25v 100uf Taicon?
                  1x 25v 47uf Taicon?
                  3x 10v 2200uf Ltec (Blue/Green)
                  1x 16v 1000uf Ltec (Blue/Green)
                  RAM:
                  Samsung
                  K4D263238D-QC50 (v1.2-1.3)
                  K4D263238F-QC50 (v1.4-1.5)
                  Version 1.6
                  Mobo Caps:
                  11x 25v 22uf Nichicon VR
                  3x 25v 100uf Nichicon VR
                  3x 6.3v 1500uf Rubycon ZL (Wet)
                  5x 6.3v 3300uf Rubycon MBZ
                  SMD Caps:
                  1x 16v 47uf
                  3x 16v 10uf
                  (Delta) PSU Caps:
                  3x 50v 1uf CapXon?
                  1x 50v 0.47uf CapXon?
                  1x 50v 10uf CapXon?
                  1x 50v 22uf CapXon?
                  1x 10v 2200uf CapXon?
                  1x 25v 470uf CapXon?
                  1x 10v 3300uf CapXon?
                  2x 200v 330uf CapXon?
                    • 31029
                    that list is no good, you made the classic mistake of not including diameter and where it's under something - height.
                    also, put the part number for the psu's because there are multiple models for different markets.
                    • NeMesiS34
                      • Sep 2015
                      • 37
                      I can fix that up once I've come back from the dentist later this afternoon.
                      True, these PSU are from the Australian market
                      The PSU I listed earlier are all "Delta"
                      Also come across a couple "FoxLink" PSU's in some v1.0's
                      I will also make a listing for it when I get a chance.
                      Attached are 2 pictures of a Delta PSU from a v1.4-1.5
                      Picture 2 shows "DPSN-96BP-1" is this the part number?
                      • Wester547
                        • Nov 2011
                        • 1268
                        • USA.
                        Those Nichicon HDs aren't hybrid polymers. They are wet electrolytics in laminated cases.
                        Not much of a "super" stor if it leaks from the bung upon every glance.
                        LTEC ST series.
                        LTEC LZG series? Might not hurt to replace it if it's a startup capacitor (I think it is).
                        Those are the capacitors for filtering the linear regulated +3.3VSB output (that's why these units only have two optocouplers).
                        Two Taicon VZs in the voltage doubler. Those may be safe to keep.
                        Two of those are in parallel for the +5V output, one for +3.3V.
                        That's the +12V filtering capacitor.
                        Those aren't solid capacitors.
                        Taicon VX?
                        Taicon PW and VX for filtering +3.3VSB.
                        1x 25v 47uf Taicon?
                        Taicon VX.
                        As before, two LZGs for +5V, one for +3.3V.
                        +12V filtering capacitor, LZG series. The LTECs and Taicons may or may not be safe to keep in both units, as these Delta units run quite a bit cooler than the Foxlink equivalents, especially on the secondary side (the Foxlink heatsinks get much hotter which can't be good for the stock Teapo SC and SEK capacitors, or for that matter the hard drive chassis sitting right above it).
                        (Delta) PSU Caps:
                        3x 50v 1uf CapXon?
                        1x 50v 10uf CapXon?
                        1x 50v 22uf CapXon?
                        CapXon GS and GL. And that's actually a Samsung power supply made in Tuscany as evidenced by the transformer part number. And yes, DPSN-96BP-1 is the part number. Also, those early Foxlink units were the worst when it came to cracked solder joints in the AC inlet (FTPS-0001, except revision D, and FTPS-0002 were the affected models - the socket and inlet were only held in place by two measly plastic clips so eventually the solder would break with repeated insertions and disconnections of the power cord).
                        • NeMesiS34
                          • Sep 2015
                          • 37
                          Thanks for the reply, very informative...
                          Samsung PSU, learn something everyday
                          Yea I wrote about that FoxLink on another Forum earlier this week: XBMC4Xbox
                          • NeMesiS34
                            • Sep 2015
                            • 37
                            Versions 1.0 to 1.1
                            Mobo Caps:
                            13x 25v 22uf NIppon SME (5x11mm)
                            6x 25v 100uf Nichicon VR (6x11mm)
                            3x 16v 1500uf Nichicon PW (12x20mm)
                            2x 10v 3300uf Nichicon PW (12.5x25mm)
                            1x 10v 680uf Nichicon PW (8x15mm)
                            5x 6.3v 1500uf Nippon KZE (10x20mm)
                            1x 1F 2.5v SuperStor (N/A)
                            SMD Caps:
                            1x 16v 47uf Nichicon WX (6.3x5.4mm)
                            6x 16v 10uf Nichicon WX (3x5.4mm)
                            240v PSU Caps: (Delta DPSN-96AP-1)
                            1x 50v 10uf LTEC ST (5x11mm)
                            1x 25v 47uf LTEC LZG (5x11mm)
                            2x 25v 100uf Nippon KY (6x11mm)
                            2x 200v 330uf Taicon VZ (18x35mm)
                            3x 10v 2200uf Nippon KY (10x30mm)
                            1x 16v 1000uf Nippon KY (10x20mm)
                            *Fuse 1x 250v 3.15A Bel (8.35x7.7mm)
                            240v PSU Caps: (FoxLink FTPS-0002 Rev. B)
                            1x 400v 180uf TEAPO? (25x30mm)
                            2x 25v 100uf TEAPO? (6x11mm)
                            1x 1000uf 16v TEAPO? (10x20mm)
                            *Fuse 1x 250v 2.5A ? (8.35x7.7mm)
                            Could not identify the following caps:
                            C23, C19, C17, C21, C15, & unknown C??
                            RAM:
                            Samsung
                            K4D263238M-QC50
                            Versions 1.2 to 1.5
                            Mobo Caps:
                            13x 25v 22uf Nichicon VR (5x11mm)
                            7x 25v 100uf Nichicon VR (6x11mm)
                            3x 6.3v 3300uf Nichicon HM (10x25mm)
                            1x 16v 680uf Nichicon HM (8x15mm)
                            3x 6.3v 1500uf Nichicon HD (10x20mm)
                            SMD Caps:
                            5x 16v 10uf Nichicon WX (3x5.4mm)
                            240v PSU Caps: (Delta DPSN-96BP-1)
                            1x 400v 150uf Rubycon USR (22x35mm)
                            3x 50v 0.22uf Taicon VX (4x7mm)
                            2x 25v 100uf Taicon PW & VX (6x11mm)
                            1x 25v 47uf Taicon VX (5x11mm)
                            3x 10v 2200uf Ltec LZG (10x30mm)
                            1x 16v 1000uf Ltec LZG (10x20mm)
                            *Fuse 1x 250v 3.15A ? (8.35x7.7mm)
                            RAM:
                            Samsung
                            Versions 1.6 to 1.6b
                            Mobo Caps:
                            11x 25v 22uf Nichicon VR (5x11mm)
                            3x 25v 100uf Nichicon VR (6x11mm)
                            3x 6.3v 1500uf Rubycon ZL (10x20mm)
                            5x 6.3v 3300uf Rubycon MBZ (10x23mm)
                            1x 1F 2.5v Nichicon UC (N/A)
                            SMD Caps:
                            3x 16v 10uf Nichicon WX (3x5.4mm)
                            240v PSU Caps: (Samsung 8794V-0 Rev. 1.0)
                            3x 50v 1uf CapXon GS (5x11mm)
                            1x 50v 0.47uf CapXon GS (5x11mm)
                            1x 50v 10uf CapXon GS (5x11mm)
                            1x 50v 22uf CapXon GS (5x11mm)
                            1x 10v 2200uf CapXon KM (10x20mm)
                            1x 25v 470uf CapXon GL (10x20mm)
                            1x 10v 3300uf CapXon GL (10x30mm)
                            2x 200v 330uf CapXon GS (18x35mm)
                            • NeMesiS34
                              • Sep 2015
                              • 37
                              I had troubles trying to identify the caps on the FoxLink PSU
                              As you could see in the picture the caps are covered in glue.
                              I also Included values and measurements for the PSU fuses.
                              • mariushm
                                • May 2011
                                • 3799
                                The last three pictures show fuses, T means they're "time delay" fuses, then you have the current and voltage.
                                The first picture shows some capacitors, most likely made by Teapo if I'm going by the color and the shape of the vent. If you want to be more accurate, you'll just have to use a sharp blade to cut the glue and desolder the capacitors to read the capacitance and voltage rating.
                                The glue is there just to prevent components from vibrating and/or popping out of the pcb holes when these pcbs go through wave soldering. You can cut it out without damaging the power supply.
                                ps. pay attention to those gray and green wires, the insulation is almost cut. may want to put some tape around the cables for safety.
                                • Wester547
                                  • Nov 2011
                                  • 1268
                                  • USA.
                                  SMD Caps:
                                  Just to be clear on this, though I may not be 100% correct on this, the "WX" capacitors can be identified by these markings:
                                  [Letter][Number]
                                  [Capacitance]
                                  [Voltage]
                                  "WT" (105*C SMD electrolytics by Nichicon) have a "P" after the number (the datecode).
                                  Chemi-con MV SMD capacitors can be identified by a shield on the markings. And I think the Suncon (Sanyo) ones reverse the letter and numbers on the datecode and have a slightly different font.
                                  That would be Teapo LXK or LH. Sometimes they used Chemi-con SMH in this position.
                                  There is a 100uF 25V Teapo SEK (brown sleeve) on the primary side which acts a a startup capacitor. The green and gold sleeved Teapo SC (100uF 25V) on the secondary is before the standby regulator. There appears to be a ventless, brown Teapo SEK after it - not sure what the value is either since it's drenched in glue and removing the glue could compromise the sleeve (if you're not careful whilst removing the glue with a blade, as mariushm said), but I'd guess smaller than 100uF 25V. Perhaps 47uF 25V.
                                  Teapo SC, +12V filtering. From what I can see, there is a 13x20 2200uF 10V Teapo SC before the ferrite coil on the +5V rail and possibly an 8x20 1000uF 10V Teapo SC after the ferrite coil (forming a PI filter). The +3.3V rail appears to have one 1000uF 10V 8x15 Teapo SC before and after the ferrite coil in the PI filter. Their sleeves do appear to be partially covered in glue, so this is my best guess. The later Foxlinks (FTPS-0007) used two 2200uF 10V 10x25 Teapo SCs in parallel for +5V filtering and one for +3.3V. These are the stock capacitors, and obviously there were better choices when it came to brand.
                                  Those are all Teapo SEK, probably on the decoupling side of the secondary logic. You may need to desolder them to identify them at all if they aren't draped and awash in glue (which you'd have to remove, again).
                                  Watch out - these are known to go bad even if they don't show it. They are notorious for going leaky (partially shorted) during this time period.
                                  • NeMesiS34
                                    • Sep 2015
                                    • 37
                                    Thanks again, Very Knowledgeable
                                    Ill get around to having a good look at that FoxLink PSU,
                                    when I get a chance but not in any particular hurry atm.
                                    Took a few pictures of the SMDs
                                    Maybe you could help Identify, please...
                                    Pictures, from left to right:
                                    1) Version 1.0-1.1
                                    2) Version 1.4-1.5
                                    3) Version 1.6
                                    4) Version 1.2-1.3
                                    Found this fuse on Mouser.com
                                    Would this be a suitable replacement?
                                    "Bel Fuse MRT 3.15"
                                    (For all PSU's excluding FoxLink)
                                    • NeMesiS34
                                      • Sep 2015
                                      • 37
                                      Awesome, thanks.
                                      Yea, just noticed that thanks again
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        1) Version 1.0-1.1
                                        2) Version 1.4-1.5
                                        3) Version 1.6
                                        4) Version 1.2-1.3
                                        1) 47uF 16V - Nichicon WX, 10uF 16V - Chemi-con MV
                                        2) 47uF 16V - Nichicon WX, 10uF 16V - Nichicon WX
                                        3) 47uF 16V - Nichicon WX, 10uF 16V - Chemi-con MV
                                        4) 47uF 16V - Nichicon WX, 10uF 16V - Chemi-con MV
                                        I noticed a blue, ventless capacitor in the 1.0 - 1.1 image. That's either Panasonic M or Nichicon VX series, depending on whether there's a boxed M logo on the sleeve or if it says Nichicon.
