Need help BFG/GR650WGSPSU
  • Philly Cheese Steak
    • Mar 2011
    • 114
    Hello all!
    First off I'm a total noob, so please assume I don't know the terms of stuff you post. As I probably will not..... Anyway I bought this unit of of Flee bay for a friends computer I'm building, so if its not worth fixing just say so. I'd like to fix it and use it in a mild build for mostly internet cruising.
    That said I kinda know how to use a meter, I got a blue point(fluke wanna be) but the battery was in it so long the terminals are corroded. And I may have to splice in a new connection from radio snack. I opened this unit up, first thing I noticed was it was full of dust bunnies. Then flipped it over and found burnt traces underneath it, the peace that had the burns is removed already but I know that simply slapping a new one in is not all that I need to do with it.
    A. I don't even know this parts name
    B. How do I go about testing it
    C. Again Don't assume I know anything, but I'm very teachable!!!
    THANK YOU IN ADVANCE!!!
    X99 5930K
    X99-gaming 9
    EVGA 1080 Vanilla
    Gskill 16GBRip JAWS@2400
    SSD'S
    Corsair AX1200
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Need help BFG/GR650WGSPSU
    The part that has failed is called a bridge rectifier, It may have been damaged from many thing or just failed.
    You will need a multimeter
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
      • Mar 2011
      • 114
      Thank you Joshnz!
      I got one, but have to repair it as it sat with the battery in it so long the connectors are corroded. So I'll have to go by Radio snack to get a battery adapter. I got a blue point multimeter from about ten years ago, its a Fluke wanna be.
      Keep the info coming.......... I'll get the multi up and running by tomorrow.
      X99 5930K
      X99-gaming 9
      EVGA 1080 Vanilla
      SSD'S
      Corsair AX1200
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        It's a older Topower built BFG, it will do 500W barely in spec at room temp, so unless you are running a real high end computer it should do fine.
          • Mar 2011
          • 114
          COOL!
          Thank you 370!
          Multimeter in hand, next?
          X99 5930K
          X99-gaming 9
          EVGA 1080 Vanilla
          SSD'S
          Corsair AX1200
            • Mar 2011
            • 114
            So I'm assuming here that cause its marked with "1006" that it is 10A 600V and that KBU is the manufacturer? As on its face it has "KBU 1006", I was searching Flee bay for a replacement it seems all the number correspond to the Amps and the voltage?
            Examples
            A. GBU 406=4A 600V
            B. KBP 206=2A 600V
            C. KBJ 2510=25A 1000V
            Also hard to find a 10A 600V on Flee bay, if anyone would suggest? I will check this site, again Thank you for any and all help.
            X99 5930K
            X99-gaming 9
            EVGA 1080 Vanilla
            SSD'S
            Corsair AX1200
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              Hi I have marked points of interest.
              The fuse marked in yellow will be blown can be verified with you meter set to 200 Ω should read less than 1Ω
              The varister marked in cyan should read less than 20Ω.
              On the 200Ω range put red probe where red circle is and black probe on the black circle hold it there for a while let me know the results.
              On the white rectangles measure between
              1 (red probe) 2(black probe)
              2 (red probe) 1(black probe)
              2 (red probe) 3(black probe)
              3 (red probe) 2(black probe)
              1 (red probe) 3(black probe)
              3 (red probe) 1(black probe)
              4 (red probe) 5(black probe)
              5 (red probe) 4(black probe)
              6 (red probe) 5(black probe)
              5 (red probe) 6(black probe)
              6 (red probe) 4(black probe)
              4 (red probe) 6(black probe)
              let me know for each or those combinations.
              My pc
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                10A 600V is correct.
                KBU is just part of the part number to help identify it.
                My pc
                  • Mar 2011
                  • 114
                  Josh,
                  Yes the fuse reads 0, the Varister reads 3.2 Ohms.
                  It started off @12.(something) then incremented down to 0
                  It starts off @ 0.527
                  3.80 slowly decreasing
                  2.90 slowly decreases
                  0.521
                  2.65
                  2.65
                  0.522
                  2.28 increasing
                  0.525
                  0.560 increasing
                  2.65
                  2.65
                  Thank you!
                  X99 5930K
                  X99-gaming 9
                  EVGA 1080 Vanilla
                  SSD'S
                  Corsair AX1200
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    may need to remove the transistors to get better results.
                    My pc
                      • Mar 2011
                      • 114
                      UGH!
                      Those are the one's I was testing right? I just realized I read them back wards, the contact points, I'll redo it in the morning!
                      Again Thank you Joshnz!
                      X99 5930K
                      X99-gaming 9
                      EVGA 1080 Vanilla
                      SSD'S
                      Corsair AX1200
                        • Mar 2011
                        • 114
                        OK,
                        Sorry busy at work my first chance to jump back at it, I had your list back wards Joshnz. And now the right readings need more ask.............
                        0.61
                        3.20
                        3.05
                        0.542
                        2.66
                        2.66
                        0.521
                        3.30
                        0.500
                        0.499
                        2.65
                        2.65
                        THANKS!
                        X99 5930K
                        X99-gaming 9
                        EVGA 1080 Vanilla
                        SSD'S
                        Corsair AX1200
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          http://search.digikey.com/scripts/Dk...e=GBU1006DI-ND
                          For 2 cents more you can upgrade by 5 amps.
                          http://search.digikey.com/scripts/Dk...GBU15J-BPMS-ND
                          Mann-Made Global Warming.
                          - Dr Seuss
                          • b700029
                            Banned
                            • Sep 2010
                            • 640
                            Wouldn't 10A be more than enough? At 120V input 10A would mean 1.2kW input power.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Considering it blew [and don't really know why] for 2 cents I'd upgrade anyway.
                              - Dr Seuss
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                PCBONEZ do those readins look to low to you?
                                Philly Cheese Steak
                                If it were me I would have gotten the part numbers for the transistors and got the datasheet for them those reading look to low to me.
                                also what type of meter are you using.
                                My pc
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Yes. - Assuming it's out of the circuit to measure as it should be.
                                  Should be open or at least very high in one direction. [Depends on meter.]
                                  ... And very low in the opposite direction.
                                  Part of the reason I linked to the parts was to show these aren't like expensive or anything.
                                  - Dr Seuss
                                    • Mar 2011
                                    • 114
                                    Philly Cheese Steak
                                    Hey Joshnz!
                                    I got a radio shack Digital Multimeter, as i recall it was around fifty bucks a few years back. Its the one that can fold closed and fit in your pocket, don't see a model number on it any where.
                                    I got a better meter if you think this one may be off, its the fluke wanna be from Snap on. Only reason i used this one was the connection had corroded on the battery. I assume I can solder the battery in place to use it....
                                    X99 5930K
                                    X99-gaming 9
                                    EVGA 1080 Vanilla
                                    SSD'S
                                    Corsair AX1200
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Does your meter auto-range?
                                      If it's changing ranges on it's own that might explain it.
                                      - Dr Seuss
                                        • Mar 2011
                                        • 114
                                        I'm guessing it does as when I'd try to take readings from certain points, it would start out at like say 0.260 then begin to climb and continue for a while. If you think the blue point would do better, I can post up the same readings with it.
                                        X99 5930K
                                        X99-gaming 9
                                        EVGA 1080 Vanilla
                                        SSD'S
                                        Corsair AX1200
                                        • jasonbay13
                                          Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
                                          by jasonbay13
                                          it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
                                          PU200
                                          pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
                                          pin 8 vreg3 = 0v
                                          pin 13 en = .2v
                                          pin 1,6 entrip1,2 = 0v
                                          b+ and b++ = 19.5v
                                          +5valw = 0v & 25+ohm to ground
                                          +3valwp = 0v & 25+ohm to ground
                                          i cleaned the board up just a little and can get more pics.​
                                          where should i be looking? thx...
                                          09-25-2025, 10:54 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • bogosort
                                          Corroded 820-01654-a (M1 air battery board)
                                          by bogosort
                                          I am trying to diagnose a Macbook air m1 battery board that looks like it has liquid damage.
                                          However, I cannot correctly get resistance readings because the board is always powered by the battery.
                                          The battery icon had an X icon and was not recognized by the laptop. After removing corroded capacitors, the laptop cannot even boot with the battery plugged into the logic board.
                                          (Photo attached)
                                          Do you guys have an idea of what I could do?...
                                          12-11-2023, 05:20 PM
                                        • yuuki47
                                          Corroded GA-B85-HD3
                                          by yuuki47
                                          Hi all...
                                          I have a Gigabyte GA-B85-HD3. It mostly works but it has a few problems. At random times through the day, I get constant notifications from Realtek's Audio Panel that the rear jack has been connected/disconnected. It spams me for a few minutes and then stops.
                                          Second weird issue is the integrated graphics have red artifacts. I've seen those in boards with bad caps, so I concluded that the caps must be bad... especially because the board has signs of corrosion everywhere.
                                          But upon closer inspection, this appears to be environmental corrosion...
                                          07-22-2023, 04:44 AM
                                        • mferna14
                                          Logic Board 820-01987-A missing PP3V3_S5
                                          by mferna14
                                          Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
                                          06-07-2025, 05:07 PM
