Corroded GA-B85-HD3
  • yuuki47
    • May 2021
    • 56
    • United Kingdom
    Corroded GA-B85-HD3
    Hi all...
    I have a Gigabyte GA-B85-HD3. It mostly works but it has a few problems. At random times through the day, I get constant notifications from Realtek's Audio Panel that the rear jack has been connected/disconnected. It spams me for a few minutes and then stops.
    Second weird issue is the integrated graphics have red artifacts. I've seen those in boards with bad caps, so I concluded that the caps must be bad... especially because the board has signs of corrosion everywhere.
    But upon closer inspection, this appears to be environmental corrosion rather one induced by leaking electrolytes. I leave right next to the sea, and with so much salt in the air, this is far from impossible.
    The caps also appear to be solid ones... though they could be hybrid. I have no idea what brand they are.
    Some picks:
    The rear connectors are corroded. Should I just neutralize it with vinegar? Won't I need to repaint it in order to prevent further corrosion?
    Thanks... any ideas are appreciated.
  • DynaxSC
    • Apr 2021
    • 477
    • Poland
    Re: Corroded GA-B85-HD3
    First of all clean the board from dust with isopropyl alcohol and compressed air - several times, from both sides, using a brush, and cleaning also all ports. Then I would apply an ultrasonic bath in distilled water, to get rid of the salt everywhere, to go sure 2 times, from both sides a 30 min. at least per run - remove from the board any coated heatsinks/covers, as they can loose color in the bath, and clean them separately. Finally clean the water with compressed air, and once again spray the whole board with isopropyl alcohol and clean again thoroughly with compressed air, 2 times would not be bad - especially LGA socket (distance min. 10 cm), RAM sockets, PCIe sockets, all ports and the thin gap under the chipset. Check if any port contacts are corroded, if yes treat them with contact spray, if this does not help the ports needs to be replaced (needs hotair gun, 150-200W solder iron and it's not easy).
    • yuuki47
      • May 2021
      • 56
      • United Kingdom
      Hi, thanks for the reply.
      The problem is... I don't have an ultrasonic cleaner. I'm just a humble hobbyist with a soldering iron and a SS-02 pump
      Since I wasn't getting replies, I tried cleaning the corrosion with some vinegar, then soapy water to rinse it all off, and then IPA. The board is much cleaner now but no dice.
      In fact, it has stopped posting (before I did the cleaning, which is why I rushed it) and all it does is power cycle itself. The fans will spin for two seconds, then they will spin down, and spin up again in this infinite loop.
      Which isn't surprising to be honest... it was doing all sorts of weird stuff before. I wish there was a way to see if it goes through any POST codes at all.
      Maybe the capacitors have gone...
      • slimmy182
        [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
        by slimmy182
        Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
        I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
        Looking on google I found this:...
        01-14-2023, 11:55 AM
      • jasonbay13
        Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
        by jasonbay13
        it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
        PU200
        pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
        pin 8 vreg3 = 0v
        pin 13 en = .2v
        pin 1,6 entrip1,2 = 0v
        b+ and b++ = 19.5v
        +5valw = 0v & 25+ohm to ground
        +3valwp = 0v & 25+ohm to ground
        i cleaned the board up just a little and can get more pics.​
        where should i be looking? thx...
        09-25-2025, 10:54 PM
      • mat2k
        HP Elitebook 840 G3 no VCORE
        by mat2k
        Hello, I'm troubleshooting an HP Elitebook 840 G3 with corrosion on the board, it powers up fine and lights up a few LEDs and the keyboard backlight but doesn't do anything else (screen fully off, no beepcodes).
        3v3, 5v, 1.2v ddr4, 1.8v, 1v rails are present, but I don't see Vcore or VCCGPU. The board had lots of corrosion near some USB-C controller chip, and some corrosion on NCP81208 (I believe this one is the culprit). I fixed a couple of traces near the chip, everything appears fine and not corroded now. The NCP81208 is getting VCC (5v) and EN (around 3v) yet it doesn't do anything,...
        09-21-2025, 05:43 PM
      • B2L_Repairs
        Huawei D15 no power found corrosion damage
        by B2L_Repairs
        I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
        02-06-2025, 01:05 PM
      • AJ847.63e
        Dell XPS 9510 LA-K411P Liquid damaged
        by AJ847.63e
        Hi All,
        Just wanted to get some advice on a XPS 9510 we have. Unit suddenly decided it no longer wants to turn on. Sometimes pressing the power button, it sits on keyboard lights no picture and boot loops a few times before shutting down. Other times it completely ignores the power button and does nothing. There is no light at the front of the laptop.
        We are getting 20V on all 3 ports so the USB C PD communications working fine. We are getting 12V,3V3 and 5v so it seems like an issue quite late in the power sequence.
        Removed the board and found dust corrosion...
        02-26-2024, 06:05 PM
