Identifying Nichicon PL
  • sebr
    • Oct 2010
    • 79
    I recently ordered caps and now as they have arrived, Im wondering why dont match the specs in the datasheet. Maybe fake caps?
    They are labeled as:
    nichicon
    3300 uF 10V
    PL(M)
    105°C
    H 0912
    Can size 10 x 26 mm
  • yyonline
    • Jul 2009
    • 692
    Re: Identifying Nichicon PL
    Nichicon PL is an obsolete series.
    Where did you buy them from? There are many counterfeit capacitors on ebay, and I'm sure elsewhere too. Post some photos of the top, bottom, and sides and we can compare them to what genuine Nichicon look like.
    Next, what specification is different than expected? I can't find a datasheet for PL, since it's an old series. Were you able to find a datasheet? If so, can you post a link?
    • bigbeark
      • Jan 2010
      • 661
      I found datasheets identifying PL as superseded by PM series.
      PM datasheet shows 3300UF at 12.5mm diameter. These are not a low impedance or low ESR capacitor. The ripple rating is 1700 for 6.3v (not high enough). Even if these are genuine, I don't think they would be the best choice for motherboard use.
      Nichicon HM or HN (after 2005) or Rubycon MCZ would be much better choices.
      Nichicon P series caps would be more suitable for power supply use.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Most brands will do custom order sizes if you order enough so a legit cap not showing up in the data sheet isn't that unusual and isn't like -proof- of a fake.
        Does make it suspect, it's just not proof without something else.
        PL and PM are low ESR if you read the correct table in the data sheet.
        PL data sheet attached.
        3300uF 10v came in 12.5x35.5 or 16x20 mm.
        You probably have the 12.5x35.5 there and slipped a little with the ruler.
        Mann-Made Global Warming.
        - Dr Seuss
        • sebr
          • Oct 2010
          • 79
          Here are the pics.
          I bought the caps from ebay.
          @PCBONEZ: Thanks for the datasheet. PM is the successor of PL. But anyways, I measured correct. Of course it can be a custom made cap, but the bottom and top pics make ....doubts...
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Those are fake.
            The vent stamp shape on them is a Teapo Trademark.
            Nichicon doesn't use it because they'd get sued.
            The font also looks wrong.
            I don't think Nichicon ever uses an italic 'u' in uF.
            - Dr Seuss
            • Toasty
              • Jul 2007
              • 4171
              Fake
              1) The picture (not the drawing) in the datasheet indicates that the bung is wrong. Bung protrudes to raise cap off of board.
              2) Datasheet says marking is "white printing on dark brown sleeve".
              As has been said before, ask here before buying from eBay. Or, completely bypass that venue and go direct to RS or Farnell or similar in your country.
              ?? Who was the ebay seller ??
              veritas odium parit
              • sebr
                • Oct 2010
                • 79
                Vent stamp and the "missing" bung were also suspicious to me.
                Well, they were not announced or sold as Nichicon caps, just as "motherboard caps". So i didnt expect too much.
                Usually i only use Rubycon or Panasonic FM series caps from RS, but no 10mm type was available.
                Anyways they are now in my parents computer which isn't in use very often (probably once a week) so it wont hurt much.
                ebay seller was "satistronics"
                • LuSiD
                  Research addict
                  • Mar 2011
                  • 16
                  • Greece
                  So the other day i bought the caps you can see in the picture. A lot of 10. For 3$! How stupid could i be to believe these where original Nichicons? The answer is "very stupid". Well, they were my first caps and i didn't know. So, beware of fakes for low prices on eBay... What is really funny is that some had the vent stamp from Teapo as above (and i used those to recap a graphics card) and the vents of the other ones where like the ones in my other pictures...
                  A very helpful post indeed! Are there any ways to identify fake Rubycons too?
                  By the way, the eBay seller is "cn-resource". I will contact him to see what does he actually think of the caps he is selling...
                  P.S. Do you think i have to recap my graphics card with more reliable caps? I think the answer is YES!?!
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Originally posted by Toasty
                    2) Datasheet says marking is "white printing on dark brown sleeve".?
                    I can confirm this. I have Nichicon PL pulled off a server board and they are indeed white on dark brown. Great caps btw. I've seen sold here caps labeled as Sanyo with a similar print - same gold text on green sleeve, same slightly fuzzy printing. Wouldn't be surprised if it's the same factory which made them.
                    A working TV? How boring!
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2640
                      hmmmm...
                      • b700029
                        Banned
                        • Sep 2010
                        • 640
                        It seems like you got a mix of resleeved Teapo and some other no-name brand.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          @ Scenic: Are you telling me that those gold on green (third pic) Sanyo caps are genuine? If they really are... looks like i've found a steady source of caps.
                          • yyonline
                            • Jul 2009
                            • 692
                            I'll wait for Scenic to chime in to confirm, but the long capacitor in the last photo appears genuine. The shorter ones that are the darker green are obvious fakes. I see lots of Sanyo, and I'd be happy to give you my opinion on your caps if you post photos. I'm sure others would as well.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Okay, i'll buy some this week.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                I've gotten mixed legit and fake Sanyo from the same dealer in the same order before. [The legit and fake were different uF.]
                                Seeing one good one in an order doesn't tell you squat about what will show up at your door.
                                - Dr Seuss
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2640
                                  the longer 6,3V cap in the 3rd pic is genuine, the short one is obviously a fake, but uses (what looks like) the exact same (wrong) colors as the fake nichicons in the earlier posts.
                                  (wrong tone of both green and gold, plus the obvious things like the X vent and the fact that they labelled a Sanyo WX as 125°C )
                                  • helungyim
                                    • Jun 2011
                                    • 3
                                    The shorter one. 10V 1000UF absolutely are fake Sanyo caps.
                                    check the vent. printing etc
                                    Originally posted by Scenic
                                    hmmmm...
                                    • dwatashi
                                      • Aug 2011
                                      • 1
                                      Well, I think that I have fake caps too.
                                      Mine have 10x23mm, 10v, 4700uF, nichicon.
                                      I have yhe same problem, I can´t get 10mm 10v caps locally, then i get some via eBay.
                                      • scabiko
                                        • May 2013
                                        • 1
                                        • Argentina
                                        Originally posted by sebr
                                        Here are the pics.
                                        Hi, I am new to the forum and I am a new victm of fake Nichicons HE(m). They look exactly as the ones on your pictures. In your experience, do they work or will fry my equipment? I want to use them in a regulated power supplly of 12v, to power an audio device. Please advise! Regards.
                                          HP Pro Pro 3300 SFF Pro 3300 G850 Specification for Upgrade or Repair
                                          This specification for the HP Pro Pro 3300 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Pro 3300 SFF boardview and Pro Pro 3300 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:44 PM
                                          DELL Latitude 3300 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3300 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3300 boardview and 3300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3300...
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 12:30 PM
                                          09-06-2024, 11:50 AM
