Picked up a sony with no power symptom, thought it might be a bad power supply. Caps look good so I checked the power supply by itself by jumping the ps-on signal. All voltages are there. Is this a main board problem or can the t-con board cause this.
Sony KDL-32L5000 No Power
Re: Sony KDL-32L5000 No Power
You can start with this:
https://www.badcaps.net/forum/showthread.php?t=39740Never stop learning
Originally posted by Spitz View PostPicked up a sony with no power symptom, thought it might be a bad power supply. Caps look good so I checked the power supply by itself by jumping the ps-on signal. All voltages are there. Is this a main board problem or can the t-con board cause this.
Would love to know if anyone ever found a resolve for this symptom, I also have all voltages 24v,3.3v and unregulated 12v and 15v and led's are on,still not getting any backlights. Power button does nothing. After set sits unplugged for sometime all 3 front panel led's stay on. One click from psu during plug in clicks once when unplugged.Sony training manual flow charts in circles? Another stumper I don't want to replace all three boards on. Also unplugging H2 has no effect. Help!
The OP never upload the pictures as requested in post 2.Never stop learning
Originally posted by patrax View PostWould love to know if anyone ever found a resolve for this symptom, I also have all voltages 24v,3.3v and unregulated 12v and 15v and led's are on,still not getting any backlights. Power button does nothing. After set sits unplugged for sometime all 3 front panel led's stay on. One click from psu during plug in clicks once when unplugged.Sony training manual flow charts in circles? Another stumper I don't want to replace all three boards on. Also unplugging H2 has no effect. Help!
I also have this same tv that has no front lights. with everything plugged in I hear the relay click on then off when given power, with all of the boards disconnected however the relay does not click.
With all of the boards disconnected the voltages from the power supply to the main board are 3.37 on STBY. & 3.39 UNREG 15V.
With the main board connected ( and everything plugged into that ) I get .8 volts on UNREG 15V BUT NOTHING ON 3.3V and that voltage drops to zero.
I HAVE TWO POWER SUPPLY'S AND TWO MAIN BOARDS and the results are the same.
I have already done the individual board elimination test.
Did I get a bad main board twice?
See post 2.
OP did not do as requested, I hope you are not going to be doing the same thing.Never stop learning
Well, lets see now , I do not have the TV, the boards in front of me to look at so I have no idea which boards or boards version/revision being used in YOUR TV, you can have same model TV number but the boards, the LCD panel, etc. can be made by more than one OEM.
If you bother to do some research you will see how many versions of the boards are used in the KDL-32L5000.
http://www.shopjimmy.com/catalogsear...ny+KDL-32L5000
Sorry, I will just skip this thread and good luck with your repair.Last edited by budm; 03-16-2016, 04:56 PM.Never stop learning
Thanks for updating the thread with pictures etc could you also if possible re connect all the wires and then test the voltages on the two white connectors on the power board if you can right down the marking on the pcb ie 5vstby- measures 5.00 volts etc do this for each pin on the connectors so we can see what each pin does what the voltages should be and are now measuring many thanks
are you using your original boards again now for fault finding?
Please can you post a well focus picture as in post #18 since I cannot make out what the legends are alongside the connector so can't tell you if all the readings are good.
You don't list 15V so I suspect that's what's missing so check your diodes, any smd fuse close-by any bulged capacitors or any burnt resistors.Last edited by dick_barton; 03-25-2016, 04:13 PM.Willing to help but I'm no expert.
There's literally just a handful of discrete components to provide the 15V which is missing and I suspect R6416 may have gone O/C. The 12V is up and running so the DC-DC inverer circuit is working. There's not much left to check out. D6401, C6403 and finally but highly unlikely to lose the supply, R6413/5Willing to help but I'm no expert.
