What's the ideal operating temp for capacitors?
  • TELVM
    • Oct 2012
    • 547
    • Spain
    We know heat is bad for them, but there is a such thing as excessive cooling for capacitors?
    For instance, could a constant 21C internal case temperature be 'too cold' for the polys/lytics inside a computer?
    What's the ideal operating temp for them?
    (Just for laughs ): The Ice Cap & The Submarine Vents
  • Heihachi_73
    • 713
    Re: What's the ideal operating temp for capacitors?
    I had a feeling it would be Rodalco or someone like that.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      There is a tradeoff of course, actually cooling by peltier is better than fan because fans will encourage evaporation. However if things get too cold where liquid electrolyte freezes, that's a problem. Also cooler temperatures will reduce ion mobility, increasing ESR (that's why some capacitors work better when heated.)
      I think there is a happy point but in terms of overall performance, but for lifetime you can't do better than keeping it cool, just don't freeze them.
      • tmiha71
        • Apr 2010
        • 130
        Hard to say, but recommendation is to use capacitors with lower value of Z-25℃ / Z+20℃ (quotient of impedance at -25 degC and impedance at 20 degC ). That will result in lower deviation...
        In datasheets usually defined at 120Hz, but (probably) can be applied to higher frequencies - capacitors with higher quotient will have higher impedance than capacitors with lower quotient, probably valid for increase in temperature too...
        Some datasheets give information about impedance versus temperature - if there is that info it should be consulted first...
        Some datasheets give information about capacitance versus temperature, if we presume higher capacitance leads to lower impedance (always true), it's safe to presume higher capacitance also leads to lower ESR...
        To emphasize - deviation is bad, leads to shorter lifespan of electrolytic capacitor...
        You should search through this forum, think there was posts about this issue, and some info about other types of caps.
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 332
          • D12
          Didn't want to open new topic cause it's temperature related. I have VCR power supply with one cap that is 85C graded, can I replace that one with 105C one would that make any problem ? I know PSU that needs to have low esr caps/extra low I already check that
          • CapLeaker
            Leaking Member
            • 8135
            no there is no problems switching out an 85c rated cap for a 105c rated one, as long as they have same capacitance. The voltage gotta be the same or higher.
            • dragon3x
              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
              by dragon3x
              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
              power on.
              Here are some examples :
              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
              switching supply area).
              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
              than 6.3 V.)
              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
              I replaced capacitors with aluminum-polymer.
              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
              03-21-2025, 02:46 PM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
              by sam_sam_sam
              After all of...
              07-13-2024, 08:14 PM
            • Ady2017
              Are there any datasheets available for Elna RJG capacitors?
              by Ady2017
              I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
              05-25-2025, 02:19 PM
            • ctroxtell
              Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
              by ctroxtell
              I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
              01-03-2025, 08:57 PM
