Philips 60PFL8708S/12 Android Upgrade Kit Issue (Pictures Inside)
  • CroBUTKO91
    • Jul 2022
    • 22
    • Croatia
    Re: Philips 60PFL8708S/12 Android Upgrade Kit Issue (Pictures Inside)
    its not problem im not in a hurry thank you for you help again just to ask you my serial number from 60PFL8708/12 will not work? and how is going with ambilight did you manage to get it working
    • CroBUTKO91
      • Jul 2022
      • 22
      • Croatia
      q
      • PhilipSerbia
        • Apr 2023
        • Serbia
        Hi there.. I have 2013 42PFL7008K/12 upgraded to 42PFL7008S/R1 because of well known problems with 2013-er series. Few days ago the TV stuck on power up with persistant logo and flashing diode (3hz soft blinking). No remote response. I tried to flash with new firmware, but no real success. Only android circle running for hours, but nothing else.. Can somebody (DutchDIY) upload NVM 42pfl7008s_r1_51_nvm, because it maybe help. Thanks..
        • William1967
          • Nov 2017
          • 203
          • Netherlands
          Did you try the .upg file or the .pkg file to flash?
          • rakonja
            • Sep 2023
            • 6
            • Croatia
            Hello everyone! I am the owner of a Philips 42PFL7008k/12 TV! It served me well all the years. Sometimes it used to get "stuck", after which I used to disconnect it from the voltage, hold the power button on the device for about 30 seconds, and after turning it on again, it worked like new!Only once it threw something like no software!Now it happened that it won't turn on anymore, the red LED blinks twice!Do you have any suggestions? They are probably not cost effective to repair, but I am sorry to get rid of it, it has served me well and looks like new!The only downside is the slow software! Now I see these upgrade kits! What are the experiences with it......
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4305
              • Italy - Milan
              #26
              NO good to enlarge to the infinite other one's thread, better to open his own thread, your problem is the same as all in this series, if you had read the rest you already know, bad processor solderings..
              • E--Man
                Samsung LED UHD TV - Bad Main Board or Bad T-Con Board? Pictures inside
                by E--Man
                Hi All,
                Thanks for reading. Based on the interesting fact that the vertical lines issue don't seem to effect the menus whatsoever but rather everything around the menu regardless of video is shown, I'm trying to set mine whether the issue is the main board or the t-con board.
                Again what's baffling is that the menu is not effected whatsoever. However, any other video displayed regardless of inputs or when no inputs exist exhibits the vertical lines and seem to effect black areas only.
                The lines are green in color when the tv is in "Game Mode" and...
                05-12-2024, 10:52 AM
              • ameenameen
                How to force on PSU philips DPS-119CP (photos inside) TV PSU
                by ameenameen
                So problem is i have a faulty motherboard and i want to install a universal one , i could not find a power on pin , do i need to short 3,3v standby to ground ? and which pins are for power on the backlight and dim
                01-16-2024, 04:02 AM
              • Flaku_34
                Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                by Flaku_34
                Introduction:
                Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                04-18-2024, 12:47 PM
              • Grut
                JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
                by Grut
                My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
                Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
                When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
                Can anybody help me please finding the 17MB171 USB firmware to try to upload...
                11-15-2024, 03:12 AM
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
