SAMSUNG UE55MU6405 - no standby
  • Jmenuu Zavalichi
    • Jun 2024
    • 28
    • españa
    #41
    i mean the firmware....if you have it
    • lotas
      • Jan 2016
      • 4651
      • Russia
      #42
      The firmware is different, when updating the software via network or usb, the data in the 25Q40 also changes and the old version (dump) will no longer help (it will not match the eMMC software version and the TV will not turn on, you need to read the data (dump) from the 25Q40 and post it here, I'll fix it for you (if it's damaged).
      • Jmenuu Zavalichi
        • Jun 2024
        • 28
        • españa
        #43
        Are you talking about the original mainboard? Very good...tomorrow when the programmer arrives I will try to copy the 25q40 software and send it to you.
        • Jmenuu Zavalichi
          • Jun 2024
          • 28
          • españa
          #44
          from the original mainboard and if is dosnt work y will copy the file from ic1603(original mainboard) to ic1603(new board)
          • lotas
            • Jan 2016
            • 4651
            • Russia
            #45
            Yes, copy IC1603 from the original board and replace this dump in the new board and check if the image changes.
            Or just unsolder it and replace this chip on a new board (this is without a programmer).
            • lotas
              • Jan 2016
              • 4651
              • Russia
              #46
              Yes.
              • kris_007
                • May 2017
                • Niemcy
                #47
                This is dump from us55mu6452 can you fix it ?
                • lotas
                  • Jan 2016
                  • 4651
                  • Russia
                  #48
                  Yes, I can, try it.
                  • kris_007
                    • May 2017
                    • Niemcy
                    #49
                    Thank you very much. It's work !
                    • Jmenuu Zavalichi
                      • Jun 2024
                      • 28
                      • españa
                      #50
                      Hello friend...I'm trying to copy the chip...it detects it as epprom and tells me to put it in manually...any of them that I put in tells me that the chip is empty...it could be a problem of the program?
                      • Jmenuu Zavalichi
                        • Jun 2024
                        • 28
                        • españa
                        #51
                        el chip is this...can you help me?
                        • Jmenuu Zavalichi
                          • Jun 2024
                          • 28
                          • españa
                          #52
                          I haven't been trying for days...with the tweezers (which are useless) with the ch341 programmer that burned...I bought a SOIC8 cable that didn't work for me...in the end I had to modify it...so that It matches the pins of the chip...it seems to connect...so it's fine...but I don't know what's wrong...the program I have or the Windows 11 that I have installed on the PC ...but I installed the drivers and it says the programmer is connected
                          • lotas
                            • Jan 2016
                            • 4651
                            • Russia
                            #53
                            I don’t understand what you’re doing, why are you touching the SPI flash IC1603 (25Q80) chip, are you having problems with the image on TV?
                            • Jmenuu Zavalichi
                              • Jun 2024
                              • 28
                              • españa
                              #54
                              If you look at what we have talked about before, you told me to do that
                              • Jmenuu Zavalichi
                                • Jun 2024
                                • 28
                                • españa
                                #55
                                I don't know what the programmer could be, it connects perfectly but any chip that reads tells me that it is empty
                                • Jmenuu Zavalichi
                                  • Jun 2024
                                  • 28
                                  • españa
                                  #56
                                  Hello friend, have you found out something?...what could I do...I asked for a clip to hook the IC properly yesterday I did a little research and lowered the speed of the ezp2019+ programmer and it read but I think it's not complete tx I'll tell you
                                  • Jmenuu Zavalichi
                                    • Jun 2024
                                    • 28
                                    • españa
                                    #57
                                    Hello friend...I finally managed to extract the bin file of the 25Q40 ic from the original motherboard that does not have standby (as you told me to send it to you to see if you can fix it) could you? I'll send it to you here...I'll try tomorrow to copy the file from the 25Q80 to the motherboard that I bought, let's see if it works for me (I remind you that I sent you some photos with the image of the TV that doesn't look complete, it's only 75% complete and distorted colors) thank you and I'm waiting for answers, let's see if could you modify the bin file
                                    • lotas
                                      • Jan 2016
                                      • 4651
                                      • Russia
                                      #58
                                      Click image for larger version  Name:	dataurl134603.png Views:	0 Size:	365 Bytes ID:	3298199
                                      What kind of dump is this, where did you read it from, it does not correspond to 25Q40, did you mess something up, is it numbered IC1604?
                                      This dump looks more like a 25Q80, but you read it as a 24Q80 (IC1603).​
                                      • Jmenuu Zavalichi
                                        • Jun 2024
                                        • 28
                                        • españa
                                        #59
                                        hy there...theat was the dumb i think...from the iriginal main (512kb)...try this....its the same i think
                                        • Jmenuu Zavalichi
                                          • Jun 2024
                                          • 28
                                          • españa
                                          #60
                                          i have 2 this one and the last one
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                            09-07-2024, 05:50 AM
                                          • JSin21
                                            Compatibility of main boards between different variations of samsung MU6100
                                            by JSin21
                                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                            11-27-2023, 04:54 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Yanleb
                                            Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                            by Yanleb
                                            Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                            If they are not compatible why did Samsung give them the same part number to begin with?
                                            08-04-2025, 11:35 PM
