SAMSUNG UE55MU6405 - no standby
  • totof
    • Feb 2017
    • 157
    • france
    Hi i have Samsung UE55MU6405
    The tv will not turn on, there is no standby light.
    Main board BN41-02568B (BN94-11958Q)
    Screen CY-KM055HGAV3H
    When i remove the psu cable to main board i get backlight
    1,8V and 3,3V on main board
    Attached my dump file from 25Q40
    Can someone send me the right file please?
  • lotas
    • Jan 2016
    • 4598
    • Russia
    Re: SAMSUNG UE55MU6405 - no standby
    Try.
    • totof
      • Feb 2017
      • 157
      • france
      lotas! I love you!
      It work very fine
      By the way dump for 25Q80 and eeprom 24512 for this tv reference.
      • lotas
        • Jan 2016
        • 4598
        • Russia
        Ok!
        • KYBOSH
          • Oct 2011
          • 581
          • Unknown
          How common are problems with these memory chips?
          • Joistyk11@gmail.com
            • Jan 2023
            • United Kingdom
            Hi I Have The Same TV With The Same Issue. can you please explain how to use this file? Thank you.
            • totof
              • Feb 2017
              • 157
              • france
              Hi.
              You need to use a flash programmer, like CH341A programmer. You will find the procedure to use it on bacaps or other sites on internet.
              • lagri
                • 3
                • Spain
                UE55mu6405u with the same problem, can you help me?
                Thanks in advance.
                • lotas
                  • Jan 2016
                  • 4598
                  • Russia
                  Thanks in advance.
                  Yes I can. Try.
                  • lagri
                    • 3
                    • Spain
                    You are the best ! works great ! thank you very much!
                    • lotas
                      • Jan 2016
                      • 4598
                      • Russia
                      OK. Thank you.
                      • yoritomo
                        • Sep 2012
                        • 147
                        • Belgium
                        Hello
                        Same problem with UE55MU6225WXXN , I could not find the dump for the eeprom IC1604 anywhere, please anyone can find it ?
                        Thanks you very much
                        • lotas
                          • Jan 2016
                          • 4598
                          • Russia
                          Originally posted by yoritomo
                          Hello
                          Post your non-working one here and I'll fix it.
                          • yoritomo
                            • Sep 2012
                            • 147
                            • Belgium
                            Thank you for the reply
                            This is mine, may I ask what are you modifying ?
                            • lotas
                              • Jan 2016
                              • 4598
                              • Russia
                              From the damaged dump I make it work. try.
                              • yoritomo
                                • Sep 2012
                                • 147
                                • Belgium
                                Thanks for the dump, but looks like something else is wrong, still be no reaction from the stand by LED, the processor keeps cold as well as RAM chips, no POWER_ON signal going to the power supply, I could find 1.8V on the power button, and 3.3V is coming to the IR module.
                                I don't know which is the vital power supply in stand by mode on this motherboard.
                                Pins 1,7 and 8 are powered with 3.4V at IC1604
                                Anyone as a clue ? As usual with Samsung no schematics for this board ....
                                • lotas
                                  • Jan 2016
                                  • 4598
                                  • Russia
                                  After writing the dump, you need to set and write the status register 0x88, 0x42, without them the firmware flies again.
                                  • yoritomo
                                    • Sep 2012
                                    • 147
                                    • Belgium
                                    Wow thank you so much, now it is working fine, I did not know it needs to be protected, is it sometime the case for Nand chips too ? Because I failed them always ...
                                    • lotas
                                      • Jan 2016
                                      • 4598
                                      • Russia
                                      Nand suffers from Bad Block, ECC and if firmware data falls into these (BB).
                                      • yoritomo
                                        • Sep 2012
                                        • 147
                                        • Belgium
                                        Yes I know, but even from official spare parts providers I could never grab any correct Samsung Nand chips without any bad blocks, I tried to use the three method to override bad block, but no success ... with the same software as you showed for RT809H
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                          09-07-2024, 05:50 AM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Yanleb
                                          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                          by Yanleb
                                          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                          If they are not compatible why did Samsung give them the same part number to begin with?
                                          08-04-2025, 11:35 PM
