Sony 55X8500E no power
  • wumeow
    • Dec 2022
    • 15
    Hi folks,
    I have a Sony 55X8500E that has no power at all, not even standby light.
    Tried to jump pin5 and pin9 on the power board with a 1K resistor and got the following measurements.
    CN6801
    Pin 1 : 0V
    Pin 2 : 77.39V
    Pin 3 : 77.39V
    Pin 4 : 77.39V
    CN6802
    Pin 1 : 0V
    Pin 2 : 0V
    Pin 3 : 1.52V
    Pin 4 : 1.49V
    Pin 5 : 1.49V
    Pin 6 : 1.45V
    Pin 7 : 1.49V
    CN6401
    Pin 1 : 0V
    Pin 2 : 0V
    Pin 3 : 0V
    Pin 4 : 0V
    Pin 5 : 3.5V
    Pin 6 : 0V
    Pin 7 : 0V
    Pin 8 : 2.8V
    Pin 9 : 3.4V
    Pin 10 : 0V
    Pin 11 : 0V
    Pin 12 : 0V
    Pin 13 : 12.7V
    Pin 14 : 12.7V
    Pin 15 : 12.7V
    Pin 16 : 12.7V
    Pin 17 : 12.7V
    Pin 18 : 12.7V
    Pin 19 : 0V
    Pin 20 : 0V
    Pin 21 : 0V
    Pin 22 : 0V
    Pin 23 : 0V
    Pin 24 : 0V
    Pin 25 : 0.08V
    Pin 26 : 0V
    Pin 27 : 0.08V
    Pin 28 : 0.08V
    C800A
    391V
    Any help would be appreciated.
    Thank you.
    • 12178
    • U.S.
    Re: Sony 55X8500E no power
    maybe check Q123, see if one leg is shorted to either of the other 2.
      • 12178
      • U.S.
      you have voltage on pin 8, I think that means a backlight issue.
        • 12178
        • U.S.
        can you post some good straight on pictures of each board and one of the whole back, as to see how everything is connected.
        • wumeow
          • Dec 2022
          • 15
          Thanks for your reply.
          I checked no short on Q123.
          • wumeow
            • Dec 2022
            • 15
            Just tried to ground the pin 8 but nothing happened.
            • wumeow
              • Dec 2022
              • 15
              Here you go.
              • wumeow
                • Dec 2022
                • 15
                Here is the service manual I found online
                  • 12178
                  • U.S.
                  some of those solder joints look a little suspect, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                  • wumeow
                    • Dec 2022
                    • 15
                    Had a detailed look, can't find any bad solder joints.
                    Would you mind to point out the component number which looks suspicious?
                    On the other hand, tested all 6 black light strips light up without any problem? Is it possible the 2.8V I get from BL_ERR is indicating something else?
                    Much appreciated.
                      • 12178
                      • U.S.
                      after confirming solder joints are ok, do this test:
                      Check STBY 3.3V
                      C518
                      near CN400
                      on B* board which is also known as the mainboard.
                        • 12178
                        • U.S.
                        look closely at the joints, see how some look cracked, a good joint does not look cracked or sparse or a big round glob.
                        • wumeow
                          • Dec 2022
                          • 15
                          Check STBY 3.3V
                          C518
                          near CN400
                          Will double check all the solder joints. Thanks
                          C518 is showing 3.5v.
                            • 12178
                            • U.S.
                            ok, looks like that points to a problem with the B board/mainboard.
                              • 12178
                              • U.S.
                              the solder might be ok, hard to tell from the picture, it looked like maybe some of the diode D75x might be a little cracked but not sure.
                              • wumeow
                                • Dec 2022
                                • 15
                                With 1K resistor jumping the 3.3V standby and power on pin. Power board is still not producing 24V on CN6401 pin25, 27 and 28.
                                Does it mean both main and power board are faulty?
                                • wumeow
                                  • Dec 2022
                                  • 15
                                  Resolder those Schottky diodes but nothing changed
                                  • wumeow
                                    • Dec 2022
                                    • 15
                                    Just found a short on ZD905 near IC901. Not sure is this related to the VCC 12V missing.
                                    • lotas
                                      • Jan 2016
                                      • 4592
                                      • Russia
                                      The zener diode is in parallel with low-resistance resistors, so it seems to you that it is short.
                                        • 12178
                                        • U.S.
                                        in some cases you need to jump power-on, bl-on, and maybe all the pwm pins to stndby to get the backlights on.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
