old Bravia double fail?
    • 12097
    • U.S.
    Re: old Bravia double fail?
    and you followed the firmware upgrade procedure, exactly like it says on the sony site?
      • 12097
      • U.S.
      ok lets try this, unplug cable from powerboard to mainboard, plug power cord in, see if theres anything on the display or the backlights come on.
        • 12097
        • U.S.
        can you post a picture of the whole back, as to see how everything is connected?
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8694
          Yeah saw a YT video of someone doing the upgrade, and it does not behave the same way.
          I also disconnected the MB from the inverter board and the backlight did not turn on.
          The photos in the SM is pretty much the same as the TV...
            • 12097
            • U.S.
            check the fuse on the inverter board.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8694
              Fuse is good, or at least Vdrop across it is 0V.
              Agree this is suspicious that both the inverter board or CCFL tubes and the MB are both bad?
              This sort of leads back to PSU problems, but standby is working (else the remote wouldn't powerup) and the PSU is giving solid 12V and 24V...
                • 12097
                • U.S.
                #27
                what kind of meter do you have, close to 0 ohms is short, no continuity is short.
                  • 12097
                  • U.S.
                  #28
                  go ahead and ohm test those mini transformers on the inverter board, they should all be very close to each other, similar testing there: https://www.youtube.com/watch?v=b36w2GNrH6Y
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8694
                    I'm getting 24V across the input of the board and 0V across the fuse (24V on both sides of the fuse) so there's no short here.
                    I'm wondering if I should cut bait at this point with both the inverter/CCFL not lighting *and* the mainboard not lighting the optical SPDIF port/not picking up firmware from USB? Unless there's still a chance there's only one thing that's causing both problems other than the PSU as it seems like it's working... Perhaps there's some magic sequence that needs to go through the enable to light the CCFL tubes, but the wire/pin is simply labeled "Enable" (and the other wires on the connector are ground, inverter board failure, and pwm dimmer - a total of 4 wires that go from the mainboard to the inverter board.)
                    Is it worth to fix the inverter board and then have to also fix the mainboard? I was hoping the mainboard at least show signs of life, I could jury rig a backlight. Or perhaps just fix the inverter board to fleabay the board as "working" as I definitely can't sell the mainboard. About the only thing that I could resale is the PSU, but ... I want another working TV.
                      • 12097
                      • U.S.
                      #30
                      did you test those mini transformers? easy test, I think the thing to do is test the powerboard as stand alone, usually involves using a couple, few, resistors as jumpers and see if the backlights come up and stay on, like UNHOOK the cable from powerboard to mainboard at mainboard and stick the resistor legs in that end of cable if they will fit.
                        • 12097
                        • U.S.
                        #31
                        maybe some of the supertechs can chime in with easier methods, all I can do is try my best, it IS an interesting puzzle for sure.
                          • 12097
                          • U.S.
                          #32
                          LOL, This is wrong, my bad.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8694
                            O-K! not sure how I screwed up before, as I thought I did the same experiment to segregate the two.
                            BACKLIGHT WORKS!!! I was able to light it by poking the enable pin. And of course what I see on the screen is disheartening, indicating problem is indeed in the mainboard (or one does have to suspect tcon but right now I think it's the former): a whole bunch random colored vertical lines across the whole display.
                            Now whether to go buy a mainboard or not... or perhaps it yet can be restored...
                              • 12097
                              • U.S.
                              #34
                              ok, try having one ribbon cable at a time hooked up from tcon to panel, see if theres any display or white screen whatever it shows, do both sides, best to make all unhook and hookups with tv unplugged from power to avoid any errant surges etc.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8694
                                Not sure what you mean by tcon to panel connection, thought that was usually soldered?
                                Anyway with the LVDS cable disconnected - screen is fairly uniformly gray instead of the randomly colored vertical lines uniformly across the screen (no underlying corrupted image visible like "Bravia" that I thought it would normally display upon boot, just lines.)
                                Still have to focus on the mainboard as it is not supplying the proper enable signal to the backlight - once again is it a double fail of a mainboard and tcon at the same time?
                                  • 12097
                                  • U.S.
                                  #36
                                  its the flat ribbon cables that go from tcon to panel driver boards, usually a little flat clip that you snap up with a fingernail, then power up tv with only one side connected, then do the other side, make sure the cable ends are not touching anything like the metal chassis to avoid shorting anything out, they flip up easy, should never force anything.
                                    • 12097
                                    • U.S.
                                    #37
                                    can poke around the mainboard and tcon, see if you have any voltages, should probably find at least one spot with 12 volts near where the lvds connector of mainboard and the lvds connector of tcon are, so tcon fuse is ok? see if you have around 12 volts on each side of fuse, metal chassis for ground, can also look mainboard over, sometimes theres many little fuses on them, one or more could be bad if they are there.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8694
                                      I can see the +5V around the board, and some other voltages but did not xref with SM yet... so unfortunately no obvious problems.
                                      Incidentally it's funny the inverter board is made by Samsung and has some crappy solder job on it. But if it works, it works...
                                        • 12097
                                        • U.S.
                                        #39
                                        did you see if you have around 12 volts on each side of fuse on tcon board?
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8694
                                          Can it be assumed the tcon fuse is intact because the behavior of the panel is different of LVDS cable (which has power on it?) is plugged in or not?
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 03:40 AM
