Sharp LC-26SB14U White Screen
  • CleanSC
    EnthusiastFixer
    • May 2010
    • 91
    Fellas!
    I have here in front of me a friend's Sharp LC-26SB14U that does nothing but power up to a white screen.
    I cracked it open and the PSU doesn't have any obvious bloaters.
    Changing the input does nothing, channel does nothing. Raising the volume does raise the no signal noise a little bit.
    I am guessing the PSU is not powering the logic board, or the logic board is just dead. There seems to be power reaching everywhere else on the tv.
    Anyone have any suggestions or typical fixes for this?
    I attached some pics so you get an idea of what's going on inside.
    Just wondering if anyone has had any experiences with these tv's. It died 3 days after the warranty period expired.
    Successfully Saved Various TV's and Monitors from the Landfill:
    Acer AL2423W (Fixed in 2010, Still in use today), Panasonic TH-37PD25 (Twice), Panasonic TC-P55GT30 ($100 CL Score), JVC 27" LCD Television
    Repair Equipment: Fluke 88V, Hakko 936
    Skills: Measure/solder at component level. Light IC replacements (Chip Quik)
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sharp LC-26SB14U White Screen
    Post a picture of the logic board. I'm pretty sure it is hidden underneath that aluminum shield. Try to get in as close as possible with the highest resolution.
    --- begin sig file ---
    --- end sig file ---
    • 70JUDGE
      • Jul 2010
      • 81
      Have you tried to reseat the cable that goes to the screen?Does your screen turn black afterwards,or have sound?I saw the exact model on Ebay that powers on to a white screen,then turns black.I hope this helps.Thank You very much!
      Tyler
      • Wizard
        • Mar 2008
        • 2296
        T-CON or mainboard. Unplugged LVDS cable always is black LCD even backlight is lit.
        White LCD is all pixels are on letting light through, and that requires power and command from mainboard. Or defective mainboard or bad T-CON.
        Cheers, Wizard
        • Agent24
          I see dead caps
          • Oct 2007
          • 4981
          • New Zealand
          While troubleshooting an AOC 17" I found that disconnecting power to the logic board and powering up would result in a white screen.
          The overall fault was just bad capacitors in the PSU.
          -David VanHorn
          • CleanSC
            EnthusiastFixer
            • May 2010
            • 91
            Below are the requested pics. I hope they are good enough.
            Judge, yes, I have tried to reseat all the cables, and still the same result. No black screen, always white. No sound, except for the faint hiss of the amplifier being on, but with no signal input.
            Let me know what you all think.
            Thanks, fellas!
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              You said that you suspected no power to the logic board, did you check this?
              -David VanHorn
              • CleanSC
                EnthusiastFixer
                • May 2010
                • 91
                No, because I have no idea how.
                The connectors to the logic board have 23 pins each and I have no idea which one does what. They are not labeled on either board and I don't have any electrical diagrams.
                Is there a way to find this information?
                Thanks, Agent!
                • CleanSC
                  EnthusiastFixer
                  • May 2010
                  • 91
                  Here's some shots of the PSU. I'd love to know what the pinouts are of connector CP401 so I could check if the logic board is getting proper power.
                  Any clues on this?
                  I can take any close ups of any particular areas on request.
                  Thanks, fellas!
                  • CleanSC
                    EnthusiastFixer
                    • May 2010
                    • 91
                    SCORE I found the service manual online. This will obviously help tremendously.
                    If anyone can help lead me in the proper diagnostic direction using these schematics, I'd be very appreciative.
                    I have checked the power outputs of CP401 on the bench and most seem to be in order. The rest, I'm not sure if the PSU needs to be connected to the other boards and the TV turned on to get the proper voltages. I haven't done this yet.
                    I have uploaded the service manual to my own server for your convenience.
                    Thanks in advance!
                    Right click, Save As... (Doesn't read right in browsers)
                    • mbates14
                      • May 2005
                      • 169
                      rip it all apart and check the SMD fuse on the T-CON panel driver board. I once had an older olevia do the "white screen of death" and replacing this fuse fixed it. Maggies were known for a mosfet failing on the mainboard causing white screen of death, because no power would reach the panels t-con
                      But i had an AUOptronics panel in an HP monitor have the same white screen of death, same blown fuse, but it re-blew, and i found the DC-DC converter that was built into the panel driver/t-con was shorted.
                      my 2 cents
                      • CleanSC
                        EnthusiastFixer
                        • May 2010
                        • 91
                        Good idea... Would you happen to know which component this would be from my pics? Or generally what area this should be in?
                        And checking is simply seeing if there is continuity thru it like any other fuse, correct?
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4981
                          • New Zealand
                          I personally have no idea where any fuses may be but if there are any fuses they should be in the schematic in the service manual you downloaded.
                          From there, you should be able to find them on the PCB.
                          Yes, you would want to check for continuity. Good fuse should read almost 0 ohm, blown fuse will be infinite.
                          -David VanHorn
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Just a caveat with using the continutiy (beep) feature on multimeters. This varies greatly between different multimeters. On mine, continuity is 25 ohms +/- 10 ohms. When measuring a picofuse it beeped good, but in reality at 19 ohms it was a bad fuse.
                            On some really cheap multimeters, I read their manuals and continuity is anything less than 1.5k ohms.
                            So I suggest just using 200 ohms if you have a manual multimeter and looking for 0.3 ohms.
                            • CleanSC
                              EnthusiastFixer
                              • May 2010
                              • 91
                              I have confirmed (I think, hah) the logic board is getting all the voltages it should need to work. The 30v and 5v lines are all reading their respective values.
                              As far as I can tell, the logic board has no fuses on it. I'm pretty sure I have confirmed this using the diagrams.
                              So, in my very inexperienced opinion, the logic board is fried.
                              Being that this may very well be the case, where do you all usually source these boards? Just googling the part numbers?
                              Thanks, fellas!
                              • Dgtech
                                E. Technician
                                • Apr 2009
                                • 1462
                                • Steeler
                                For some, there are sites that sell boards like that and yes google will find you those sites. For me, I use ebay to try and keep the price low however..... there are lots of people that sell faulty stuff on there too. Knock on wood, I have only gotten about two defective things out of about 90 things bought on ebay. Sometimes people sell good cards out of units that have had physically damaged screens. These should have no problems.
                                Good luck with your search.
                                • Dgtech
                                  E. Technician
                                  • Apr 2009
                                  • 1462
                                  • Steeler
                                  I just seen one on ebay for $69.00. This was taken out of a 24 inch unit. That has the same board number. I dont know if there is any difference in firmware/eprom (if any) programming for the different sizes. I'd need some of the more skilled techs to confirm that.
                                  • mbates14
                                    • May 2005
                                    • 169
                                    the board I am referring to is the board that your LVDS cable is going up to on the LCD panel itself. This board usually causes the white screen of death. in most cases. not all...
                                    You cant see the board, because its up under the metal frame that seperates all your boards from the panel. Youll see a square "buldge" thats at the top center of your metal frame plate. thats the board you need to get to.
                                    • CleanSC
                                      EnthusiastFixer
                                      • May 2010
                                      • 91
                                      Okay I have located this board... It runs along the top of the panel and is about one inch wide by 21 inches long. I scoured the whole board and only found one component, FP1, which looks like it could be a fuse. It's an SMD white square with a K on it. Not sure if that's it, but it measured .1 ohms so it's not broken. Couldn't find anything else on that board that looked anywhere remotely fuse-like.
                                      Thanks for the direction!
                                      Any other ideas before I trash this thing? Now accepting offers!
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        K = 1.5A according to
                                        http://forums.xbox-scene.com/index.php?showtopic=658938
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • odi
                                          Sharp E50E41NKFMBXNNX white screen
                                          by odi
                                          I'm trying to fix this TV that I got from a friend. It displays a white screen only. What is weird though is that when I first turned it on it appeared to work for a few minutes but then got the white screen and I haven't got the picture back even for a second after that initial time. If I plug in an HDMI device, the audio is played through the TV speakers, and the power button turns the TV on and off.
                                          I've tested the caps on the power supply with an ESR meter while in circuit they seemed within spec.
                                          Tried wiggling the LVDS while on and no change to the white screen. Have removed...
                                          01-31-2022, 03:29 PM
                                        • Megan0
                                          Sharp LC-70UD1U Half screen Normal half screen is white
                                          by Megan0
                                          My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
                                          Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
                                          Result:
                                          I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
                                          Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
                                          Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
                                          Only in the first test, where I did not
                                          01-19-2022, 11:20 AM
                                        • thesharpfella
                                          Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                          by thesharpfella
                                          Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                          07-23-2024, 10:37 AM
