ILO LCT27HA36 TV, no picture but sound
  • Roadkill203
    replied
    Re: ILO LCT27HA36 TV, no picture but sound
    I'd suggest replacing every electrolytic cap on the power supply board. Those Decon caps look like candidates for the badcaps list, and I'm not sure what else is in there.
    One other point. Because of the way you took that first picture, those two bad caps stood out perfectly. Heck, I can even see the dust on the coils!! The last picture showed the manufacture's name. The rest were unneeded.
    PlainBill
    Bill, call me Mr. Overkill! I just wanted to make sure that I covered the whole power supply.
    The power supply has 11 no-name caps and 1 Samxon (22uf/450V)! What is the sense of that?
  • PlainBill
    replied
    PlainBill
  • retiredcaps
    replied
    Originally posted by Roadkill203
    Thank you, I'll measure the resistance in that fuse in the morning. I only wish that there was a website called BadRotors.Org so that I could repay the favor (I'm a mechanic by trade)!
    Let us know if you need help measuring the fuse. Measuring resistance should always done with power off and unplugged. The big difference is you have the tools to replace a capacitor or fuse while I don't have the tools to do rotors.
    I like watching ericthecarguy youtube videos. I have had my rotors replaced and machined over the life my car at least a couple of times.
    BTW, no one has mentioned it yet, but most here recommend recapping all your capacitors since a couple were bad. After some more diagnostics, we can discuss that later when you make a parts list.
  • Roadkill203
    replied
    Originally posted by retiredcaps
    Actually, it is not a dumb question. I am too tired today to go back and count, but I think I have been asked this question in one variation or another at least 5 times this last week.
    I circled it in red on your picture. There may be more, but you have the best view to find them all. A open fuse may also be the reason you don't see the backlight come on (in addition to bad caps).
  • retiredcaps
    replied
    Dumb question #3 - Which board?
  • Roadkill203
    replied
    Well, don't wreck the TV on my account.
    From a quick look I spot one green picofuse on your board. It wouldn't hurt to quickly measure all your fuses to ensure they are all good (0.3 ohms or less).
  • retiredcaps
    replied
    I'm having a little difficulty going any deeper. The metal panel under the mainboard and RF board has all of the screws out but is not budging! There must be hidden screws somewhere but I'm having a humdinger of a time finding them!
  • Roadkill203
    replied
    We would probably like pictures of ALL your boards. The two bad caps may not be all that is bad.
    edit: Some designs have their inverter and power combined on one board. Some are separate. Just depends on the manufacturer.
    Okay, I attached photos of the mainboard and the RF board. The mainboard is new, it was replaced last year under warrantee. The HDMI-IN in the mainboard stopped working, so they replaced the whole board. I'm not seeing any more bad caps on these two boards.
  • retiredcaps
    replied
    Okay, I found bad caps in the power supply (is that what you mean by inverter <<<NOOB!). The part number on the power supply is MLT168A.
    Should I stop here or keep on digging?
  • Roadkill203
    replied
    That means the screen itself is fine, it's the CCFLs or inverter which went out. If white had a pinkish color for some time before the failure it's the lamps, if they just plain went out, it's the inverter. My money goes on bad caps in the inverter.
    No, the picture just suddenly went out, like the TV was shut off, but the green light was still on and the soiund was perfect.
    I've attached some pictures of the power supply. The last two have the bad caps. Should I stop here or keep on digging? Thanks all!
  • Th3_uN1Qu3
    replied
    I then shined a flashlight on the screen, I saw fleeting parts of the broadcast picture when I did this.
  • Roadkill203
    replied
    Thank you for your replies!
    On some computers LCDs like my NEC 1700V (I don't know about TVs), there are electrolytic caps on the inverter board. They are separate from the logic card where the sound chip is likely to sit.
    I understand exactly what you are saying about ther perfect sound and everything. So it all depends on the layout of the TV.
    Even if it is not capacitor related (which is why I said "could"), people will want to see pictures of the insides.
    I'm gonna take the back cover off and see what I can see. Apart from bad caps, is there anything else specific that I should look for? Thanks!
    Originally posted by Wizard
    Diagnose your TV properly!
    Absolutely! I respect everyone here; please forgive my 'noobness'!
    Is the backlight lit? (press on the LCD gently) or look at back of LCD with back off (careful with live power).
    Can you see anything on the LCD while on? with flashlight carefully on the LCD (take care, LCD surface covering is plastic that scratches easily).
    Cheers, Wizard
    I pressed on the LCD screen gently like you said, there was nothing, no response.
  • Wizard
    replied
    Cheers, Wizard
  • retiredcaps
    replied
    Could the picture go out, the green light stay on, and the sound be perfect with bad caps?
  • Roadkill203
    replied
    Thanks for the reply, I shall take it apart and look at the caps, but I'm telling you this thing has perfect sound! Oh, and the green light stays on, the only problem is no video. When the TV went dark it actually looked like a lightbulb burning out, which got me thinking that there was a bulb that went bad.
    Could the picture go out, the green light stay on, and the sound be perfect with bad caps? Like I said earlier I've never really tinkered with LCDs before - I fixed a Dell 1800FP LCD monitor (replaed the ICE2AS01 and re-flowed the solder joints in the diodes, all in the power supply), but the instructions were all over the web; it was an easy fix!
  • retiredcaps
    replied
    If you need any more info just let me know. Thanks!
    Well, it could be capacitor related. There are already a few people who have solved it by replacing the bad caps as per
    http://www.fixya.com/support/t156293..._just_stays_in
    Folks here will advise AGAINST Radio Shack capacitors and prompt you to use Rubycon, Panasonic, or United Chemicon low ESR caps.
    If you take apart your TV, post clear focused pictures and we possibly can help you out. Post your pics using after reading this.
    https://www.badcaps.net/forum/showthread.php?t=1868
  • Roadkill203
    started a topic ILO LCT27HA36 TV, no picture but sound
    Okay, I was watching this Wal Mart special when the screen just went blank but it still had sound. The TV is about five years old. I unplugged the video cables from both ends and then plugged them back in, no change. I then unplugged the TV, held the power button for five minutes, let the power button go, then plugged it back in to the wall. Same thing, sound but no video.
    It's an LCD TV; I don't have much experiance toying with these things but I remember something about some kind of lamp burning out in LCD TVs and I'm wondering if that's what happened here...
    I can't find much info about this TV on thw web other than it's from China and it's a POS! Hell I can't even find any parts for it! If anyone can point me in the right direction in diagnosing it then I will be much appreciative!
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • jchang
    Samsung UN70NU6900F no picture and no sound
    by jchang
    Hi all
    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
    Symptom:
    No picture no sound.
    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
    No sound at all.
    What I tried:
    1. I tried unplugging the left or right ribbon...
    01-09-2023, 06:28 PM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
