Philips 42" Plasma 42PF7320
  • mbates14
    • May 2005
    • 169
    #41
    Re: Philips 42" Plasma 42PF7320
    Hey guys, quick question, would anyone be willing to help me out with a bad board that no one is using?
    I had one of these i set the wrong option code in and now i cant get the picture to come back to set the right option code. so i just need a board to pull the eeprom from to be able to get mine goin again.
    • PlainBill
      • Feb 2009
      • 7034
      It's not an unusual problem. Scan through the posts since the beginning of the year. Someone had the same problem. There is a code you enter via the remote after entering a special number sequence.
      You owe me one. Here's the thread. https://www.badcaps.net/forum/showthread.php?t=9751
      PlainBill
      • mbates14
        • May 2005
        • 169
        #43
        yea that was me. LOL...... and i never did get a solution to it.
        • celiabrown
          Issue with Plasma Philips 37inch chassis FTL2.1
          by celiabrown
          Hello guys,
          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
          Can someone has any symptom like this ?
          Thanks​
          05-09-2024, 10:56 PM
        • spantor
          power board manual philips 55pus6482/12 715g-p01-000-0h2s
          by spantor
          Hello.
          Some components have exploded and I can't figure out the values. I have obtained the manual for this power supply for 65" but comparing components there are some differences and it is not reliable.
          Could someone leave me the power supply manual for this 55" model?
          I would be very grateful
          03-19-2024, 01:19 PM
        • jasonbay13
          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
          by jasonbay13
          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
          12-01-2023, 09:55 PM
        • Sharpa
          Repair attempt Philips 55OLED804/12
          by Sharpa
          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
          The symptoms when bought: Philips logo appears then tv turns off
          Things tried so far:
          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
          Today, 08:30 AM
          Philips TPM17.7E LA Chassis Service Manual
          by SMDFlea
          43PUS6162/12 43PUT6162/12 43PUT6162/60 43PUS6262/12
          43PUT6262/12 49PUS6162/12 49PUT6162/12 49PUT6162/60
          49PUS6262/12 49PUT6262/12 50PUS6162/12 50PUT6162/12
          50PUS6262/12 50PUT6262/12 55PUS6162/12 55PUT6162/12
          55PUT6162/60 55PUS6262/12 55PUT6262/12 65PUS6162/12
          65PUT6162/12 65PUS6262/12 65PUT6262/12...
          06-03-2021, 06:52 AM
