Philips plasma 42PF9631D/37 need some help
  • mbates14
    • May 2005
    • 169
    I have this model that had the bad capacitors in the power supply. Replaced these capacitors and the TV worked fine. however, the picture looked like it was too wide and cut off on the right of the screen. no adjustment would fix this.
    Decided to pull up the service menu, and the Display was set to 50" plasma. so it was a replaced SSB from a 50". i meant to type code 25 in that matches my panel, i screwed up and put in 23. saved it and now there is no picture.
    I need this ComPair philips tool to fix it back, does anyone have this? or does anyone know which EEPROM this value is stored in so i can pull it, dump it, fix it back and re-write it?
    Thanks.
  • mbates14
    • May 2005
    • 169
    Re: Philips plasma 42PF9631D/37 need some help
    if someone could take pictures of the service menu on one of these sets, that would help CONSIDERABLY in aide of me trying to get it set back. I cant remember how to navigate the menu so i cant do it blindfolded. hehe. TV still runs, no pic.
    its 062596 INFO. then comes up with warning, press red button. i need a pic of this main display. and the service display, if you would please.
    • mbates14
      • May 2005
      • 169
      Dumped the eeprom, it appears to be in some kind of a convoluted algo. because code "23" doesnt stand out in eeprom anywhere. 23 hex or decimal. 23 hex to decimal is 35, i found 1 instance of that, changed to 37, made no difference, so that wasnt it.
      any ideas? or does anyone have a board they could give me an EEP dump from?
      • tmwalsh
        • Jan 2009
        • 119
        Try looking for the ASCII characters - the values for "2" and "3" next to each other or how about 23 decimal to hex... 17 ??
        Actually, I would have expected the values to be in a 'table', more or less sequentially in memory. Such that you would be able to find the values in a long string similar to what you saw displayed on the screen in service mode.
        If you remember the series of entries, look for them next to each other. If you do a dump, or view, looking for 'strings', I would expect them to be near.
        I assembled an EPROM programmer back when 2732's were new, but have no idea how you would read an eeprom, especially one that was surface mounted.
        tom
        • mbates14
          • May 2005
          • 169
          i already pulled, made a jig, and dumped the eeprom. i didnt see anything anywhere that represented a 23. not in hex, not in decimal. nothing. not even in ascii. my guess they are using a scrambling algorithm.
          I thoguht about filling the entire eeprom with 23, then booting the tV, monitoring the kernel on the service port. to see what it sees as a display code. then fill the eeprom with 33, and with 13, just to pinpoint its algorithm. If this doesnt change anything, then i know the display code is stored in a partition of the main flash.
          • tmwalsh
            • Jan 2009
            • 119
            EBCDIC? I haven't typed that word in so many years, I mis-spelled it...
            Is it possible that the EEPROM contains the 'program' to display the service menu, receive service menu information from the source, and store the service menu information [settings] in a lookup table in the flash memory, as you suggested. In other words, there is no data in the EEPROM, just 'code'?
            My last resort suggestion is to buy a board, with the correct values, open the service menu, and record every keypress [step] you take to navigate and change the offending value. Then install your board, reset the size figure, and sell the other board on ebay.
            tom
            • Wizard
              • Mar 2008
              • 2296
              8 pin is settings holding and customer' settings as well. If eeprom looks like 28 or 32 pin IC, that's not your IC as this is actual PROGRAM stored and not best to messed with.
              Be careful, very often micro controller failed.
              Cheers, Wizard
              • mbates14
                • May 2005
                • 169
                no no no. its definitely NOT the flash IC that i removed. it doesnt appear to contain any program information, im not a rookie. hehe. its a TSSOP packaged 8-pin 24C64. i had to make a jig to read out the ICs eeprom with a willem programmer.
                the program is stored on a large TSSOP flash IC in the POD area which contains the JFFS2 file system and partitions. I havent touched this. Also, the microcontroller hasn't failed. its a simple case of writing in the wrong display affinity code. now i have to change it back. and its stored in the 24C64 eeprom somewhere...
                When i head into the shop tomorrow, ill post up the EEPROM dump maybe someone might see something? thanks.
                edit: as far as a table goes, i see an area in eeprom that kinda looks like a table setup, every so many bytes, you get EC EC 01 EC then some kind of data. then some 000s and then EC EC again.
                • Wizard
                  • Mar 2008
                  • 2296
                  This is in hex format. Most of time it is 0-255 range or less hence one or two hex each.
                  No rhyme to these, what's the problem?
                  Cheers, Wizard
                  • mbates14
                    • May 2005
                    • 169
                    Here is the eeprom dump. i found 17 in 3 spots, changed all 3 then 1 at a time, TV still wont produce the picture. so i dunno.
                    • celiabrown
                      Issue with Plasma Philips 37inch chassis FTL2.1
                      by celiabrown
                      Hello guys,
                      My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                      Can someone has any symptom like this ?
                      Thanks​
                      05-09-2024, 10:56 PM
                    • SidneyCanadas
                      93C46 and 93C56 EEPROM
                      by SidneyCanadas
                      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                      06-14-2023, 01:16 PM
                    • unimatrix93
                      Philips 43PUS6501/12 EEPROM request.
                      by unimatrix93
                      Hello everyone!
                      Does anyone have a dump file for this model of TV?
                      Motherboard number is: 715G7772-M01-B00-005K
                      EEPROM IC: 25L1606E
                      My TV is stuck in cycling color mode and I can't get out of it.
                      I tried to erase the IC but it didn't help.
                      Thanks in advance!
                      02-02-2023, 04:16 AM
                    • dmccul2698
                      Pioneer DEX-P99rs "No EEProm " diagnostic code.
                      by dmccul2698
                      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                      1). Understand the schematic and check the connections between the EEProm and DSP
                      2). Check the functionality of the EEProm
                      I don't know if this is the unit's problem but it's a place to start.
                      I have little to no electronic experience...
                      04-08-2024, 05:32 PM
                    • Biruslapio
                      Reprogram Philips 32PFL3008D Winbond EEPROM with ATMEGA328P
                      by Biruslapio
                      I've shearched before posting this, and found dozens of different ways to hook up multiple types of EEPROM to an Arduino Uno, so I do not know which one is correct.
                      I need to learn this so I ended up with a Philips TV 32PFL3008D which has corrupted memory, the IC is U402, 25Q64FVSIG, I have the 3MB .bin file, how to hook up an ATMEGA328P to this memory and what code do I need?...
                      12-03-2021, 08:33 AM
