Hello everyone, I've started doing small repairs for a bit now but this one is new for me, I have a TV with a weird coloration, I looked in the color setting of the tv but had no luck, can anyone tell me what going on in here and give me a little explanation just for me to understand what's going on for the next time it happens
LG 42LG5000 - Wierd Coloration
by DrDosI'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
Channel: General Capacitor Questions & Issues
by reessiHello,
My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively... -
by reassorI think i have gone crazy.
No obvious damage on board.
Ammeter shows 20v and around 300-400mA for just a sec then goes down to 20mA
When i check cpu coils with voltometer set to remeber max it shows around 0.95v on all 3 phases.
PPBUS_G3H is constatnt 13V
Charging works when battery connected.
Now wierd thing. When you let the board drain it shows some caps SHORTED on PPBUS_G3H but after 2-3 sec they jump to high values even in diode mode.
Have i gone stupid and it should not act like that?
by AdenitzHello,
I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
What this 2000h or 1000h means? Why 1000h capacitors have longer life span?-
by Kiks412Hey guys, I have this Video Projector that turns on, takes a bit to give some image, and when it does it displays a weird static image, and has no reaction to on-device buttons or remote whatsoever, even to turn off, only unplugging from the outlet. I'm new to this kind of device so I will be very happy to get some help with this....12-20-2022, 10:00 AM
- Loading...
